Question about Dryers
FAN HEAD WON'T STAND UP STRAIGHT BECAUSE IT SEEMS TO HAVE BEEN KNOCKED LOOSE?
As the video shows, the fan head seems to have become disconnected from the stand. Can I fix this without spending any money?
    Problem Solver:
  • 5 Answers
You need to take the blade off and glue the metal attachment that makes it stand and move
Posted on Jul 23, 2013
  • CAREFUL CONSUMER Aug 15, 2013
    Thank you very much for your reply. Which metal bracket are you speaking of?
Frigidaire FFTR1619RS1 makes knocking noises while running. Is this normal? See videos inside.
I would suspect it is a loose blade on the condenser fan or else something caught on the fan to make it off balance. Pop the back cover off and take a look. Once, I had a fridge that sucked up a plastic bag.
Nov 18, 2016 | Frigidaire Refrigerators
My car has a knocking noise when my car gets warm and looses power whlie driving.Does not have noise at start up only when I drive about 15 km the sound comes.
You say when it "warms up". The symptoms you are stating sound suspiciously like a serious overheating issue. The engine will clack loudly and lose most of its power when the engine becomes extremely overheated.
Jul 08, 2015 | Cars & Trucks
Where is located the knock sensor on 1995 toyota corolla
Hi Jose, The knock sensor, is usually located under the intake manifold on the lowest part of the cylinder head. It controls the ignition timing firing point, by adjusting the timing. It is not unusual for the connection to become loose, so check the connection before buying a new part. Regards John
Feb 02, 2013 | 1995 Toyota Corolla
KitchenAid KSM150 bowl won't stay put
I'd be looking at making sure the beater is not banging on the bowl and that the head hinge isn't loose. The bowl is secure on the base with this system that has been in use for decades so you are looking for a fault not a re-design of the system. The friction of the mix in the bowl should logically tend to tighten the bowl, not undo it. I have seen a malformed bowl once where the lugs weren't big enough and I suspect that it's possible for there to have been the odd malformed bottom plate with not big enough lugs.
Jul 08, 2017 | KitchenAid Kitchen Aid KSM150 Artisan 5...
Show me where is the knock sensor located on the motor of a 1999 kia sportage
the knock sensor should be on the passenger side of the motor a short distance from the oil filter on a stand off on the block. can be tricky to get to but you loose no coolant changing it
May 02, 2011 | 1999 Kia Sportage
Mixer head is loose beater scrapes bottom of bowl makes loud thumping noise
I assume you mean that the top half of the mixer, above the pivot pin, moves with respect to the lower half of the mixer, the stand part. There is a pin on which the top half pivots which becomes loose.
Turn the mixer over and look up where the pin goes through the two pieces. There is a screw there which secures the pin. Tap the pin into position and tighten the screw.
Apr 10, 2010 | KitchenAid Artisan Series Tilt-Head Stand...
Cooling fans on 1994 Caprice classic with 4.3 v8 not coming on. I have replaced the temp sensor on the water pump, temp sensor on the block, all relays, fuses are good, replaced the ecm (engine control...
On a vehicle this age, it is likely that the fans themselves have worn out. Test the fans by running battery power directly to the positive contact. If they start, they are OK. On 4.3 motors, there is also a seperate temp sensor to signal the fans, usually called a fan switch. I believe it operates independent of the ECM. Another possible culprit is a bad ground at the fans or even a loose or corroded negative battery cable.
Jan 26, 2010 | 1994 Chevrolet Caprice Classic
I hear a knocking noise while driving
Check your outer c/v joints..a torn boot is a dead giveaway for joint failure (boot fails, lets dirt into joint, joint fails) Also since you didn't mention if noise is also preaent standing still, check the exhaust to make sure it's not hitting floor pan anywhere. (most likely the joint though)
Apr 01, 2009 | 2001 Ford Taurus
SOUND
it must be some bad connections or loose wire. when you connect and disconnect the earphones, it is possible that it created a small electric reaction that slightly welded the wires, and thats how it worked for a while, but the only permanent solution is fixing those bad wires.
Dec 10, 2005 | Panasonic SC-AK22 CD Shelf System
Dryers Logo
105 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
