Question about Garden
Sears 917255980 the mower isn't getting fire after it runs awhile
5 Suggested Answers
wentlanv
  • 710 Answers
SOURCE: I have a green Craftsman
You're pretty close when it's backfiring. However, since there's no timing, the problem could be that you need a new spark plug. Also, a valve could be sticking. A little STP in the gas would help that.
Also, found a tip on www.doityourself.com forum: http://www.doityourself.com/forum/outdoor-gasoline-power-equipment-small-engines/280686-craftsman-riding-mower-starting-problems.html
One of the guys found he had a loose wire on the anti-backfire solenoid.
If the repair shop said it just needed a tuneup, I suspect the spark plug, clean filter, or maybe a clogged fuel line would be your problem.
I hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Posted on Apr 16, 2011
  • 6468 Answers
SOURCE: my 1976 sears 18 hsp riding mower quit running now it just cranks but won't fire it has a onan engine
check for spark then spray a little carb cleaner or starting fluid in the carb if it fires its a fuel problem filter pump carb
Posted on Apr 11, 2012
  • 6468 Answers
SOURCE: My scag mower won't run and spark plugs are not firing
unplug the harness and crank it over see if there is spark then is yes check the safety switches if not check the coils
Posted on Apr 13, 2012
  • 6468 Answers
SOURCE: the coil of my poulan riding mower isn't firing. How do I check to see if its good or not
remove the top cover from the engine then remove the small wire that goes to the coil crank it over if you have spark the you have a bad safety switch is still have no spark then the coil is bad
Posted on Jun 28, 2012
91 pontiac grand prix ecm getting fire but coils arent firing
maybe you need to reprogram the computer and needs the special code from dealer.
May 14, 2017 | Pontiac Grand Prix Cars & Trucks
The coil of my poulan riding mower isn't firing. How do I check to see if its good or not
Jun 27, 2012 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Need manual craftsman 917257550
I don't see this manual available for free online. However, Sears Parts Direct has the manual as part 140952 for less than $5. See http://www.searspartsdirect.com/partsdirect/part-number/craftsman-parts/riding-mower-tractor-parts/140952/0071/917/Model-917257550/0247/1509200?keySuffixId=NA&pathTaken=partSearch&pathRender=modelComponent&documentCompId=10032978&diagramPageId=00003&productTypeId=x&searchModelNumber=917257550&subCompDesc=Drive&brandDesc=CRAFTSMAN&modelDesc=IMPROVED-ROCKER-ARM-AND-PIVOT-LAWN-TRACTORS&blt=11&shdMod= to order a copy. There is a second manual, part 140953, that isn't available from the Sears Parts Direct site. It may be available by special order by contacting Customer Service and telling the agent that a "research request" is needed. Provide the model and serial number of the tractor.
I hope this helps.
Jun 06, 2012 | Craftsman Garden
Hit rock and stopped mower. The blade isn't bent or loose but the mower will not start. It turns over seems to almost catch but not quite
If it hits somthing hard enough it will shear the flywheel key, which will knock the ignition timing out, to replace the key you will have to remove the flywheel, there are special pullers to aid removal of the flywheel, these can be purchased from your local Briggs dealer.
May 12, 2012 | Sears Garden
I have a craftsman Air-cooled, 2-cycle mini tiller.
first make sure the motor isn't engaged when trying to start it, and If it has been sitting for awhile, (in between seasons), It's likely that the carb is clogged, try cleaning it out, make sure the spark plug is firing correctly. And if it's getting spark, and its getting fuel, but still wont start, then the carb may need adjusting.
May 08, 2012 | Craftsman Garden
My 1976 sears 18 hsp riding mower quit running now it just cranks but won't fire it has a onan engine
Apr 10, 2012 | Craftsman Garden
Craftsman 19.5 hp b & s mower
check the anti back fire valve look at sears parts online at the carb picture its the cylinder thing that hangs off the bottom of the carb with a wire on it
Mar 31, 2012 | Briggs & Stratton Garden
The nail gun TNT tools and tasks model 15205 seems to be jammed but we can't figure out how to get the tip open to take the nail out. Please help.
I HAVE A TNT BRAID NAILER AND IT GOT JAMMED BUT I REMOVED THE JAMMED NAILS AND AFTER PUTTING IT BACK TOGETHER IT FIRED THE FIRST NAIL AND STOPPED FIRING IT FIRES BUT NOTHING **** OUT I DONT THINK THE DRIVER ISN'T PULLING BACK FAR ENOUGH TO LOAD THE NEXT NAIL.
Jul 24, 2011 | Sears TNT 3 gal Air Compressor with 2 in...
Garden Logo
16 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
