Question about Dishwashers
Ariston dishwasher leaks out the bottom of the door
My Ariston dishwasher leaks out both corners of the doors during certain parts of the cycle. I have cut the amount of soap because it starts out with lots of bubbles. The front of the machine has been made higher than the back. It is about 3 1/2 years old. The gaskets have been wiped down. Do the gaskets need to be replaced? How hard is this to do?
abhishek33
  • 1239 Answers
SOURCE: Ariston diswasher trips out as soon as door closed
hi On many dishwashers, the latch engages a switch to activate the timer and other control components. If the latch is not completely engaged or if the switch is faulty, the machine will not operate. Here's how to test and repair a door switch:
Step 1: Latch the door and hold the latch tightly in the closed position. This works best on a unit with a lever-type latch. Then turn the control to the ON position. If the unit works, the problem is probably a misaligned lock unit. Adjust the lock unit with a screwdriver. If this doesn't solve the problem, the switch may be faulty.
Step 2: Test the switch with a volt-ohm-milliammeter (VOM) set to the RX1 scale. Remove the panel covering the door switch and remove one of the electrical lead wires of the switch from its terminals. Clip one probe of the VOM to each switch terminal and shut the dishwasher's door. If the meter reads zero, the switch is working. If the meter reads higher than zero, the switch is faulty and should be replaced.
Step 3: Replace the switch with a new one of the same type. Connect the new switch the same way the old one was connected.
Posted on Oct 13, 2008
rylee_smith
  • 8619 Answers
SOURCE: dishwasher door leak
Hi
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Also,The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem.
If the latch has worn out in a way that makes it impossible for you to close the door properly, you probably need to replace the latch.
A Fixya rating would be appreciated if you have found this solution Helpful.
Thanks
Rylee
Posted on Feb 10, 2009
cesar_quant
  • 74 Answers
SOURCE: Water and soap leak out the bottom of dishwasher door?
check the drain tube that isnt damage!! or leaking!
Posted on Mar 10, 2009
baccardo
  • 150 Answers
SOURCE: Soap and water coming out the front of the dishwasher
yes you should compare the gap to a simular model then order the seal
Posted on Apr 18, 2009
  • 52 Answers
SOURCE: Whirlpool dishwasher leaks
Just about all dishwashers will leak a little around the door seal over time but should not leak to the point of wetting the floor. With the door open, check in the front of the tub, under the door. Lots of gunk? Clean this area out well plus take a soft damp rag and clean the door gasket while feeling for any damage. Then go along the mating surface of the door and look for any nicks. If it leaked all the time I would suspect the door hinges have been sprung. Hope this helps, Ken
Posted on Apr 26, 2009
My ariston LSV 67 built in will not start. When i turn it on the red and yellow light turns on after i put it on a setting but when i close the door nothing happens. Everything seems to be fine other than...
This could be door switch or anti flood.
Both require someone electrical competence to check.
Go to the Ariston web site and look up the schematic or parts diagram for you machine so you can locate the door switch and anti flood switch if fitted.
Check door switch works i.e. when depressed circuit is made .
Check for water in in anti flood switch if present identify leak and fix before using again.
Other things to check are that the pump is moving freely.
With unit switched off and un plugged only if you feel competent remove the food filter at the bottom of the machine after the filter has been removed you should be able to access the pump underneath.
Check it can be moved freely. There may be some resistant but not much.
If it is not rotating this need to be investigated rubber bands from food can seize it up.
Did the machine stop mid cycle or just not start after last wash?
any other useful information may help others diagnose your problem
good luck hope that gets you started
Dec 06, 2013 | Ariston Technologies Dishwashers
Ariston LS 2020 taking more than two hours to go through cycle.
Ariston and on and on...lol
The water temp thermostat is to blame or the water is not heating.Basically what happens is the washer fills with cold water and starts to wash and heat at the same time.Once the water reaches a certain temperature it moves onto the next stage of the wash program.If the water is not heating or the thermostat is not working the programmer wont get the signal to move on.Hope this helps.
Apr 26, 2010 | Ariston Technologies Dishwashers
Ariston LI 45 door will not remain closed and will
Strip the door and re-set the switch. Ensure the metal part of the catch on the machines main body is not distorted
Jan 31, 2010 | Ariston Technologies Dishwashers
Ariston Elixia LI68 Duo dishwasher will not start
Same problem , i fixed by opening the door compleet then cleaning the bottom of the door with a kitchen cleaning paper that may do it afther that disconect the power compleet whait 1 minut connect it al again and it should work , don't ask me why this cleaning action i just found it out
Feb 05, 2009 | Ariston Technologies Dishwashers
Ariston dishwasher
I have the same problem. I found that a termostatic probe switch off the machine, you can disassemble the door and clean the ventilation holes
Aug 31, 2008 | Ariston Technologies Ariston FO98P...
Does not dry all the way
I too have a similar problem. Drying light blinks, doesn't shut off, little if any steam escapes when door is open during drying cycle. Wonder if this is Ariston's Dynamic Drying? My unit is new too.
Aug 20, 2008 | Ariston Technologies LL64WNA Built-in...
Ariston dishwasher LL64
usual place for a leak is thro the door main seal but it is possible to get a leak thro the dispensor. only way to check is split door, put it to work and see if it leaks in dispensor area
Mar 31, 2007 | Ariston Technologies LI640S Dishwasher
Dishwashers Logo
48 people viewed this question
Top Dishwashers Experts
