Question about Acer Aspire 3000 Notebook
Acer Aspire 3693WMLi -Launch startup repair
As I was useing my notebook it bleeped very loud and then went blank, a black screen poped up with the message: Windows failed to start a recent hardware of software change migh be the cause. If windows files have been damsaged or onfigured incorrectley, start up repair can help diagnose and fix the problem if powere was interupted during startu0p choose start windows normally. then there are two options, Choose start windows normally Launch startup repair (recommended) choosing either one does not help. Can anyone be of assistance.
  • Buxton May 11, 2008
    I switched on my laptop the other day when a black screen appeared. It said Start windows normally
    Or
    Launch Startup Repair ( recommened )
    when i click on both it doesent work
I did get an error number and it is the following: 0x00000024
Posted on Jun 04, 2008
  • 60 Answers
Are you using Windows Xp or Vista?
Posted on Aug 30, 2007
    Scholar:
  • 181 Answers
Try to boot in safe mode. From a cold boot, hit f8 till it gives you several options including "safe mode". Do that and if you can boot to windows let it do it's stuff before restarting normally. Good luck
Posted on Aug 29, 2007
    Scholar:
  • 53 Answers
It might also means that your hard drive is not working properly. My laptop's hard drive went out making the same blipping sound and white screen after that, this happens some times for over heating. Now if you get a error number let us know it might help
SOURCE:
I have a acer mini laptop aspire one d270 with windows 7 starter.I have just now discovered that my laptop is not starting.It is showing me two options: 1)launch startup repair(recommended) 2) start...
You always want to start your windows normally.
In my 10 years as a computer technician I have learned that you never use the startup repair option cause it will never help.
Any more questions or concerns feel free to contact me Country Tech Repairs
Oct 21, 2013 | Acer Aspire One PC Notebook
Black screen on Acer aspire 1642
Try below steps.
1. Check computer in safe mode (Tap F8 while booting)
if works fine in safe mode , check startup programs and services.
2. Run antimalwarebyte in safe mode download from http://www.filehippo.com/download_malwarebytes_anti_malware/download/6a5b2c1adb0e88e84ab39920bab1ebbd/.
3. Try to repair using repair your computer option (windows 7,8)
Dec 02, 2011 | Acer Aspire 1642WLMi Notebook
I have an acer laptop 5920, when I start the machine it goes on to a windows error recovery screen. When I enter launch startup repair, the screen goes blank then returns to display the same error screen.
try to shut down the laptop completely. Remove cables and battery into it. Then press and hold power button for 8 secs. Reinsert the cables and battery back then turn it on. Contact Acer if symptom persist
Oct 14, 2011 | Acer Aspire 5920-6727 Notebook
My acer aspire 5738 boots, but after booting the screen goes blank,, plz help i have my projects to do ..... pleeeez :-(((
what is the Operating System? did the problem just poped up or it happened after you changed/installed something?
first try booting with THE LAST GOOD CONFIGURATION by pressing F8 at startup (Windows)
You could also try booting in SAFE MODE WITH NETWORK CONNECTION, than update your antivirus + a complete SCAN of the computer
It could be a defective component (HD, RAM, etc...) try booting with a UBUNTU LIVE CD to see if it works (investigate from there)
Jan 15, 2011 | Acer Aspire One PC Notebook
My Acer Aspire 5100 laptop won't boot. At startup the Acer logo is shown and than drops to a black window with flickering cursor (with now and than a loud bleep). Can anybody tell me what the problem is...
be sure to remove all other external devices hooked to your pc. just leave ac adapter plugged in. then try if it will boot to safemode by pressing F8 upon seeing the Acer Logo. if it will boot, what you need is reinstall your OS. if it will still not boot then you need to replace hdd.
Apr 08, 2010 | Acer Aspire 5100 Notebook
My Acer Aspire 4720Z does not boot anymore it shows a blue screen which sends me to launch startup repair. it does this repeatedly. Please help.
If you get a blue screen that usually means windows has a problem but the laptop itself is fine. You may need to reinstall or restore windows and it should be fine. Annoying but fine.
Mar 23, 2010 | Acer Aspire 4720 Notebook
I turn on the laptop and it gets to the login screen. When I login the screen blacks out.
There seems to be an issue with your Operating System. Please try the following :
  1. Boot the computer in Safe mode
  2. Do a system restore
  3. Restart in normal mode
If this does not work you might need to repair your Operating System.
Oct 05, 2009 | Acer Aspire 3000 Notebook
Stuck on launch startup repair
boot to restore cd, blow drive, restart.
Nov 21, 2008 | Acer Aspire 5315 Notebook
Acer Aspire 5100 will not start right
It seems your hard drive has corupted.
This sucks, all you have to do is push ALT F10 and then go through the reseting menu, you will loose everything on there though except the original data.
Jun 24, 2008 | Acer Aspire 5100-5033 Notebook
Acer Aspire 3000 Notebook Logo
976 people viewed this question
Ekse
Alun Cox
