Question about Dishwashers
Maytag dishwasher MDB8959SAS0 cancel drain light is flashingThe cancel drain light flashes, when you open and shut door thislight flashes 3 times rapidily the just blinks constantly, what is happening?
2 Suggested Answers
SOURCE: Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
Posted on Apr 18, 2009
Dishwasher starts on its own (no house is not haunted). Start resume button flashes
have a service technician in as it appears to be a problem in the program board
could be moisture across the circuit board
Feb 06, 2016 | Maytag MDB7749AWQ Builtin Dishwasher
Reset button maytag dishwasher
  • 1 Open and close the dooricon1.png of your Maytag dishwasher.
  • 2 Locate the "Rinse" button on the dishwasher control panel. Press and release the button five times in quickicon1.png succession.
  • 3 Press and release the adjacent "Drain/Off" button on the control panel two times; this will deactivate the dishwasher's demo mode and reset your dishwasher.
  • If you need to restart your dishwasher or forgot some dishes and want to open it during a cycle and restart it
  • 1 Press the "Cancel Drain" button on the display. Allow about 2 minutes for the dishwasher to completely drain.
  • 2 Choose a cycle under "Cycles" on the panel.
  • 3 Select an option or options under "Options" on the panel.
  • 4 Push the "Start Resume" button.
  • Oct 24, 2013 | Dishwashers
    Service number kuds301xbl2
    I would find the electrical breaker for this unit and shut it off for a minute, then re set the breaker thus resetting your unit.
    Apr 28, 2013 | Maytag MDBH975AWS Stainless Steel...
    Clean light is flashing
    As an example on a kitchenaid dishwasher when the clean light flashes 7 times this is a control error that be corrected you would press Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry with the door open and then close the door and press cancel. If your unit were a whirlpool dishwasher you can press hi temp heated dry hi temp heated dry with the door open which does end up lighting all the led's and when you shut the door makes the unit cycle into the wash stage. after you hear the unit letting water into it listen for the wash cycle to start and then press cancel. After the unit drains then you can set your unit to wash again. I will await your reply as to what type of unit you have before continueing on with a exact solution for your unit. Thanks
    Rick
    Oct 08, 2011 | Dishwashers
    Blinking "Normal" light on a Maytag model
    Hi
    Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
    Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad.
    Hope this helps... Please post back if you need more information.
    Daniel
    May 19, 2011 | Maytag Dishwasher
    Quick Rinse light was flashing at end of cycle. Opened and closed door and pushed Start. Quick Rinse and Cancel/Drain light are now flashing and machine won't start. Turned off power supply (30 seconds) /...
    Ok try this, open the door and then hit these buttons in the following combination. HI TEMP - DRY - HI TEMP - DRY...then close door and press cancel...then wait for the pump to shut down. you should be able to run a cycle after this...If this fails to fix the problem give me the make and model # of the dishwasher, this can normally be found just inside the door.
    Jun 22, 2009 | Dishwashers
    Dec 29, 2007 | Dishwashers
    Maytag quiet series
    My manual says: 1- Close door. 2- Select cycle. 3- Press delay. 4- Push Start/Cancel. (As soon as start/cancel is pressed, the flashing should stop and the delay time will begin).
    Mar 12, 2007 | Maytag 24 in. MDB5600A Jetclean II...
    I can't get my dishwasher to start
    try pressing normal wash, then heat dry normal wash then heat dry normal wash then heat dry. do it 3 times
    Jan 27, 2007 | Maytag MDB9600A Jetclean II Built-in...
    Dishwashers Logo
    135 people viewed this question
    Top Dishwashers Experts
