Question about Maytag Atlantis MAV7551 Top Load Washer
What is the black powder under my BELT DRIVE Maytag washer MAV 4057AWW
huuum
  • 750 Answers
SOURCE: maytag atlantis washer mav-31
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
Is t your washer cleaning the clothes and operating fine other than the noise?
If so do not spend any money on it unless it breaks or does not operate!
"If its not broken do not fix it!"
I know this is not the what you wan to hear!
I have a telephone number of the consumer affairs of for maytag that's hard to find!
If you call them thay will demand that thier servicers find and remedy the problem or swap it out for you!.
Even if it is past warranty.
I'm not at work for another couple of hours.
When I get there I'll give you the 800 number for Whirlpool (They now own Maytag) Consumer affairs and you can cal Monday!
I do this frequently for my customers!
Everyone knows,
"It's easyier to keep the customers you have than find new ones"
But no matter what happens,you have no need to pay the repair persons child's college tuition!
You have your own needs!.
How much did you spend on this machine even though it did wash and perform?
Noise is not broken or failure.
I had a Maytag Neptune that did this for 6 years and I fixed 2 other problem unrelated .
Then on the third break down I dumped it in the trash and bought myself a Speed Queen Commercial
washer that will last me 25 years for half the price of the $999.00 Maytag Neptune.
When I complained to my father about the noises in our family car he used to tell me,
turn on the radio.
Please remember to leave a rating before you go!
Thank you
Posted on Sep 28, 2008
SOURCE: Maytag washer has black gunk underneath on pulleys and belt
replace the transmission
Posted on May 26, 2009
  • 942 Answers
SOURCE: how do i remove the drum on a maytag top-loading
If you want to remove the drum of your maytag wahser follow this procedure:
  1. Disconnect the power supply to the Maytag dryer by unplugging it from the wall outlet.
  2. Use a screwdriver to remove the three screws located at the top of the control console.
  3. Pull the control console forward to release the tabs that hold it to the Maytag dryer top. Maneuver the control panel out of your way without disconnecting any wires.
  4. Use a putty knife inserted between the top and front panel to disengage the retaining clips that secure the top panel of the Maytag dryer. Lift the top panel up, and remove it from the dryer.
  5. Use needle nose pliers to remove the wires from the door switch terminals. The door switch is located just inside the front right corner. Grasp the wire leads with the pliers and pull them off the terminals.
  6. Use a screwdriver to remove the retaining screws that hold the front and side panels together on the Maytag dryer. Lift the front panel up and out of the work area.
  7. Use a screwdriver to remove the Maytag dryer drum light lens screw. Press the locking tabs on the light socket, and remove it from the cavity of the drum.
  8. Use a socket wrench to remove the four retaining bolts that secure the drum bulkhead to the sides of the Maytag dryer.
  9. Reach your hand beside the drum and the motor, and push the idler pulley forward to release tension on the belt. Make notes of how the belt is routed on the pulleys, and then remove the belt from the motor pulley and idler pulley.
  10. Grab the belt with one hand, and the Maytag dryer drum with the other. Pull the drum out of the front of the dryer.
Posted on Jan 30, 2010
SOURCE: Maytag MAV 9600 grinding noise/no agitation. Tub
I had a problem similar to this. There was a bobbie (?) pin stuck in the pump. Google how to take the front off and then disassemble the pump. (It will be on the bottom right side in the front of the machine). Pretty simple. Took about an hour and a half.
Posted on Feb 03, 2010
heatman101
  • 43501 Answers
SOURCE: Maytag Atlantis MAV-14
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on Jun 05, 2010
What is blck powder under the motor of belt drive Maytag washer MAV4057AWW
The powder is belt wear. Not to worry though, they last a long time. There is always some wear on all belts as they slide into the channel on the pulley.
Jul 22, 2013 | Maytag Atlantis MAV7551 Top Load Washer
Hi, I have a Maytag Alantis Washer (model: MAV
Does it not spin just in the final cycle or not at all during the wash cycle? Also, does the wash cycle agitate normal?
Regards,Richard
Nov 07, 2011 | Maytag Washing Machines
How to replace a drive coupling on a maytag atlantis series mav 6300. I heard a loud cracking noise, then the washer stopped.
you will need a sevice manual go to appliancerepairplanet.vstore.ca it will show you how to do it
Dec 08, 2010 | Maytag MAV6300 Top Load Washer
Problem with Maytag Washer
Sounds like belt or bearing failure. Possible motor break down. Usually rear panel removal for access. Always unplug unit. Inspect workings for failure. Belt tight, tub turns freely. Usually the motor is the culprit. Tub removal is rarely needed. Search online for specific washer layout.
Jul 10, 2009 | Washing Machines
Maytag MAV 7000 stopped in rinse cycle with water in tub. When turned on, there is a low buz sound. Was making a louder noise prior to stopping.
RepairClinic.com
The top of the washer lifts up like a car hood after two clips between the top and the front panel are pushed with a putty knife. Once the top is flipped open, the screws that hold the front panel in place at the top can be removed and the panel lifted off. The belt may be bad or something may be stopping the belt like a bad pump. Or the transmission drive pulley and bearing may be going bad. If the bearings above the transmission drive pulley fail the brake will not release correctly in the spin cycle causing weak, slow or no spin. The belt & pulley system can be accessed by tipping the washer back. The belt is routed around all three pulleys under the washer and is fairly loose until the motor starts. It is the torque of the motor that gives the belt tension. Leaking or loud "jet engine" sound in spin indicates a bad main tub seal at the outer tub which has caused the spin bearing to fail. This is a complicated repair as the inner and outer tubs need to be removed from the washer to access and replace the seal and bearing components.
Go here for: Maytag-Washing-Machine-Parts
May 05, 2009 | Maytag Atlantis MAV7000
MAV Atlantis 6000
hi. thanks for the question .the clicking sound is something caught, in water pump. the rubber smell is the belt . pull washer away from the wall. small door at the back left corner ,remove pump on the floor. remove 3 3/8 bolts remove. replace . belt underneath washer . replace thanks the appliance doc please rate me
Aug 17, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Model MAV 4057AWW Top LOAD
clutch spring inside transmission was either broken or came away fr. shaft, 10yrs warranty on this model so maytag is replacing transmission. the Maytag man keeps getting bussier all the time, product is falling in ratings by conusmers guide .
May 19, 2008 | Maytag Washing Machines
Maytag Atlantis MAV7551 Top Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
