Question about Tools & Hardware - Others
Torque specs. briggs and stratton 5.5 hp head bolts
5 Suggested Answers
  • 10865 Answers
SOURCE: need head bolt torque for Brigges Stratton 18 Hp
210 to 230 inch pounds. Torque in a crisscross pattern upper left lower right upper right or left or right.
Posted on Jul 10, 2009
  • 4088 Answers
SOURCE: Briggs and Stratton Vanguard 23Hp starter issues
The starter may need shims between the engine and starter to permit the relative gears to release. Compare the two starters, if you still have the old one, for shaft length and bendix construction. Hope this helps!
Posted on Jun 06, 2010
Testimonial: "drallim, Everything checks out, cannot believe I've received 2 bad solenoids from NAPA. I had bought a new one and exchanged it because it seemed the switch was sticking. Still have not solved problem. Thank you for your time and efforts. Tim"
  • 454 Answers
SOURCE: Briggs and stratton lawn tractor. misses under load after warm up
check air filter, may be very dirty causing it to run too rich
Posted on Jul 30, 2010
Vanny Man
  • 4 Answers
SOURCE: i have a 18 horse
165 in. lbs
Tork them in x pattern to prevent head warp
Posted on Oct 26, 2010
Torque spec on 21 hp briggs and strattonand sequence
Doug, Torquing multiple bolts, like on a cylinder head are shown in last video link.Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www4.briggsandstratton.com/miscpdfs/RNT/Engine%20Specifications%20Chart_ms3992.pdf
FAQ Small Engine Specifications Briggs Stratton Specs
Engine mounting pattern
HOW TO LOOK UP AND TORQUE BRIGGS HEAD
How to replace Briggs Stratton Intek Head Gasket Pt 2
Jun 01, 2016 | Cars & Trucks
What are the torque specs on intake manifold on Briggs & stratton
if there is thread locking compound on bolt or threads it must be removed, use a tap to clean the threads and a wire brush to clean the bolts. Use a thread locking compound (blue) when reassembling, torque the bolts to 30 ft. lbs. alternating bolt to bolt in 7-10 lb. increments. Recheck the torque after the engine has been ran up to op temp.
Jul 17, 2014 | Briggs & Stratton Briggs Stratton Intek V...
Torque specs. for a briggs @ stratton 24hp. head bolts
WHAT IS THE VALVE CLEARANCE ON A 23 HP. BRIGS MOTOR AND THE TORQUE ON THE HEAD BOLTS?
Jul 17, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
20hp Briggs head torque specs
The following site details te Torque Specs for the 20hp Briggs.http://www.ehow.com/info_7929485_briggs-hp-twin-torque-specifications.html
Oct 02, 2011 | Yard Machines 155 Torque Briggs Stratton...
Head bolt torque for 16hp horizonal shaft engine
Anywhere from 35 lbs to 220 lbs, depending on the series of your engine. For your engine, the head bolt torque should be 190 lbs.
But I've attached a chart for you to utilize to make sure of your exact engine model series, just in case there was a transposed number, etc.
http://www.small-engines.com/torque.html
Here's the official Briggs & Stratton chart for all versions of their engines, which confirms the 190 lbs torque spec.
Hope you found this Very Helpful and best regards!
Aug 19, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Need head bolt torque for Brigges Stratton 18 Hp
Jul 10, 2009 | Garden
Tools & Hardware - Others Logo
56 people viewed this question
Top Tools & Hardware - Others Experts
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
