What is black powder under the motor of belt drive maytag mav4057aww
Took belt off, pump pulley freely and easily moves either direct, motor pulley turns either way but is hard to move it. black powder under the motor.
  • 1294 Answers
SOURCE: Maytag washer will not spin
If your washer does everything but does not spin, it is your outlet filter which is blocked. Locate this and clean out, it has to work fine. Refer user's manual.
Posted on Jun 05, 2007
vest6
  • 196 Answers
SOURCE: Maytag LAT9757AAE,top load washer won't spin.
Sounds like a sticky brake assy. This type of brake is very tricky and should be checked be a service technician
It's possible to do it yourself but not recommended because of the 200 lb. pressure spring. Hope the diagram will help.
Posted on Jan 13, 2008
ngfam1
  • 639 Answers
SOURCE: MAH4000AWQ MAYTAG WASHER
PEACE,
NGAFM1 AT YOUR SERVICE
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
* The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
* The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
* A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
* The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
* The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
BLESS YOU,
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF!
Posted on Sep 02, 2008
  • 686 Answers
SOURCE: LA612 maytag washer. motor too
get yourself a new belt the old one is stetched and no longer good
Posted on Jan 08, 2009
  • 109 Answers
SOURCE: Maytag LAT9406AAE It filled up the tank then
yep replace the lid switch
Posted on Jul 07, 2009
What is blck powder under the motor of belt drive Maytag washer MAV4057AWW
The powder is belt wear. Not to worry though, they last a long time. There is always some wear on all belts as they slide into the channel on the pulley.
Jul 22, 2013 | Maytag Atlantis MAV7551 Top Load Washer
Maytag mav7504eww- original problem - smoke with electrical smell and machine shut down due to motor overheating- opened machine - noticed white powder everywhere ( snubber) so replaced snubber and belt-...
Cooked electric motors rarely perform the same as uncooked.
My guess is field windings have shorted so not providing enough output. I'd be replacing the motor.
Apr 16, 2017 | Washing Machines
Maytag mav7504eww- motor overheating
A leaking boot seal and corroded shaft bearing is my best guess. The main transmission bearing being corroded puts stress on the motor.
Sep 30, 2017 | Maytag Washing Machines
Have checked all recomended trouble shooting suggestions- there must be more?ot drain or spin, motor running, all lines have free flow of water, nothing between tubs and pump pulley moves freely. can
although the pump will turn by hand . when you use the motor power and the belt tenson;. it may be binding. ( this has been a common problem. ) ck for play in pump shaft and look for black under washer from belt fraying . my guess is the pump and also replace belt with the pump // hope this helps. **** and thanks for using fix ya ..
May 04, 2012 | Maytag Atlantis MAV6000 Top Load Washer
I have a Maytag Performa Washer...It will fill with water but will not move through the cycles...it simply sits full of water and you can hear a humming noise and a smell possibly like rubber. A friend...
sounds like either you have a stuck pulley or pump remove water with shop vac and tilt washer against wall get under washer remove belt spin small pulley by hand does the pump pulley move all directions freely if not something stuck in pump or is belt melted or worn out
Jan 27, 2011 | Washing Machines
I have an 11 year old Maytag model PAV2200AWW. My problem is the clothes are still "very wet" after the spin cycle. I've changed load sizes, water levels and checked all of the hoses. Any...
replace washer belt # 21352320 tilt washer back belt on bottom ...check for glossyness on belt and black residue causing belt to slip... make sure motor and pump pulley moves freely...
Jan 27, 2011 | Maytag Washing Machines
My Maytag washer leaks badly around the bottom on the spin cycle
Sounds like you might need a new pump belt. They are inexpensive and easy to replace. Unplug the washer and with the water out tilt it back so that you can see the bottom. You have a main drive belt that goes from the motor to the big pulley in the middle. There should be a second belt that goes from the motor to a smaller pulley which is the pump. Make sure that this pulley turns freely in both directions. One direction is agitate and the other is discharge. If it does and your belt is loose a new belt might do the trick.
If the pulley does not move freely take off the front panel, two philip screws about 3 inches up from the bottom of the front panel. Inspect the pump. One time I found a scouring pad in the pump!! If after inspection the pump still does not move freely you may need to purchase a new pump. Find the part number and check out prices on-line. The pump is relatively easy to replace. Good Luck
Jan 26, 2009 | Washing Machines
Agitator is too tight, does not move freely
i can give you the possibilities for this problem.the problem can be solved by making a check on the drive belt,motor coupler,the motor and the pulley.the component location can be easily obtained from the manual. also Inspect under the washer for soot (clutch).
Dec 12, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Performa PAV2300AWW screaching noise, belt problem, pulley broke
My Maytag Performa was making the loud squealing noise. I changed out the water pump/bearing, took care of the problem.
Putting a new belt on just help burn up the bearing (they needed replacing) and probably ruined the new belt. Probably seized the water pump bearing and the belt jumped and broke the motor pully. A washing machine motor is very strong, when that h20 pump bearing seized (or possibly some bearings jamed up) the motor kept on turning that belt and the plastic pully gave in. You'll need to replace that also. If the h20 pumb bearing is turning freely, likely the bearings jammed up but or now loose. That bearing should be tight, no slack or play in it. You can probably wobble the pully on it all around while turning it. The slightest slack is too much.
Oct 09, 2008 | Maytag Performa PAV2200
How to replace Maytag Washer belt
I have a model sav2655aww maytag washer. And it needs a new belt but I dont know how to replace it! Can the pump be removed with out removeing the motor ? Also the tub keeps going off center whats with that ?
Sep 03, 2007 | Maytag SAV5710 Top Load Washer
Washing Machines Logo
63 people viewed this question
Top Washing Machines Experts
