Samsung lcd monitor series 4(model la22a450c1xxp)
Always on power stanby if press any key the lights blink led
  • leonardo samson
    leonardo samson Nov 26, 2015
    my samsung lcd tv has a problem with its logic board where can i get a new one
    Top Expert:
  • Televison & ... Master
  • 74,383 Answers
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on Nov 26, 2015
ginko
  • 19396 Answers
SOURCE: monitor power light is blinking .but monitor is not displaying anything
If there is a flashing led on front of the monitor, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1 The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours, sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr suddenly are a blown capacitor on power board, the inverter board powering up backlight lamp has blown, or a fault on main lcd controller board.
check also the video cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Check connectors, try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact manufacturer to find out a service point.
If you want to repair at your own expenses, just locate any good qualified repairer.
Regards
Posted on Mar 06, 2009
SOURCE: red light power blinking
power supply problem this can be done by a professional tv repair
Posted on Sep 12, 2009
tvservice306
  • 458 Answers
SOURCE: ln40a530 samsung lcd tv wont turn on
MAY BE PANEL LAMP BAD
Posted on Oct 21, 2009
milkburp
  • 416 Answers
SOURCE: Samsung lcd series 4 model ln40a450c1 will not
http://www.lieffcabraser.com/defects/samsung-lcd.htm
Posted on Mar 21, 2010
SOURCE: .mkv doesnt play on LED:UA32C5000 but plays on LCD:LA32C530
Hi
I am also facing similar problem with recently purchased LED 46" P6200. Do not know the reason? Does anyone has any idea why it is so? Thanks
Posted on Nov 08, 2010
No power 2 stanby blink light
It could be a power board problem. Why don't you please refer it to a qualified service technician?
Jul 30, 2012 | Son KDL-40EX600 40" LCD Edgelit LED HDTV
I wish to have the code number for my V7 to use the skymaster romote
Hi
HOW TO TRACE CODE NUMBERS BY QUICK SEARCH
In case you can't find your brand at code number list, please try with quick search.
1) Set the device that you want to control at POWER ON or VCR at POWER ON with tape loaded
2) Press and hold both, [SET] and aquivalent device key, until LED light shows
up, then release both keys.
3) Press [SET] again, the LED is blinking now. Start to page by pressing [POWER]
and check for any action such as POWER OFF or VCR start to play.
4) If your device has action then check other keys such as [CH +/-] or [VOL
+/-], if negative continue pressing [POWER] to search another code page.
5) While during paging a code was missed out you may press [SET] to change
the Forward / Backward direction of searching.
6) IF any key is not pressed within 30 seconds at search mode then unit will
quit and return to STAND-BY mode.
HOW TO GET THE CODE NUMBER TRACED BY QUICK SEARCH.
Check the code number that has called up to the keypad by pressing [SET]
together with (one after the other) the first three keypad digits:
For example, if is blinking 8 times, 1st digit of code number is [8],
blinking twice means 2nd digit is [2], blinking twice means 3rd digit is
[2], therefore, this code number is [822].
Power source: 2 x UM3 "AAA size" (Batteries located behind cover slide
Regards
Vipin Kakkar
Jan 14, 2011 | Videoseven L17PS 17" LCD Monitor
Display skcrin black but LED not blinking
First, connect this monitor to another computer, if you still do not get a Windows image on the Samsung LCD monitor then it is faulty. The fault could be a faulty inverter board that supplies high voltage to the CCFL lamp or the fault could be a faulty CCFL lamp.
Parts for this monitor could be avaiable from LCD Parts, theie WEB site is :-
www.lcdparts.net
Jun 23, 2010 | Samsung SyncMaster 510N (Silver) 15 inch...
My Sharp LC-42-D62U won't power up. The power light blinks twice, then the power light and the OPC light blink together once. any fix to this problem?
Ur Tuner signal board have problems or dead.Ur power LED light indicator stable for a few mins before the power LED light,and the OPC LED light indicators flashes?After the POWER light and OPC light indicators flashes,just push the power button again for the power recycles again.Probally have to pushes the power button 3 or 4 for power light and opc light indicators flashes,the LCD backlght will lght up and work.Sharp tv have this problems alot,very common in Sharp LCD tvs.
Apr 17, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
My Laptop doesnt start at all . I dont know what
1. remove all ext peripherals
2. remove battery
3. check first the ac adapter if it has led on (make sure ac adapter is not connected to the laptop)
4. try any other wall socket check if ac adapter will led stay on
5. if ac adapter stayed on then connect to laptop (without the batter)
6. after connecting the ac adapter to laptop check if the ac adapter led turned off, if yes then check ac adapter laptop pin on the side if is loose or damage.
7. if ac adapter stayed on after connecting to laptop press now the power button on the laptop just once. check if the power led on laptop will turn on (check if power led stays on or it blinks amber)
8. if it blinks amber then remove all CRUs such as dvd drive, memory, hard drive and wireless cards. put them back one at a time. make sure you turn off laptop when putting removed hardware. this will check and isolate which causing the power led to blink.
9. if the power led stays on then turn it off again then wait a couple of seconds then press and hold on Fn key then press power button. wait for about 5 minutes while the power led is steady on, until you hear beeps once you hear beeps it means that LCD has problems. try then connecting laptop to an external monitor if it shows display there. press on Fn + F8 to toggle the display from LCD laptop to the ext monitor. if no display replace the motherboard. if it has display replace LCD.
Oct 15, 2009 | Dell Inspiron 6000 Notebook
Blank LCD laptop does turn on
I beleave you may need to press the function key as well as the F-4 key to bring up an external monitor.
Try holding down the Function key and tapping the F-4 key while watching the screen on the external monitor.
Is your unit within warranty, HP offer an extended 1 year on top of your normal 1 year warranty for video and motherboard issues.
Hope this has helped.
Sep 27, 2009 | HP Compaq Presario CQ50-210US Notebook
Samsung Syncmaster 710n no display and no LED light
The power button should be on the FRONT BOTTOM RIGHT. and there should be a little led/light next to it. make sure everything is plugged in correctly and press the power button, the led should light up, and then boot your computer.
Let me know --
If this helped please mark this thread as FixYA
Dec 26, 2008 | Samsung 710N V2 (Ivory) 17 in. Flat Panel...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
