Question about Video Game Consoles & Games
Save music playlists greyed out - Video Game Consoles & Games
How do i repeat just one track on the motorola defy cell phone?
I can think of a kind of workaround: put the stock music player to select the track you want to have repeated all the time. Firstly, tap 'Menu > More > Settings', and make sure the 'Auto repeat' checkbox is ticked. Then, press the back button, and, then, 'Menu > More > Add to playlist > New playlist'. You'll be offered the name 'Playlist 1'. Change it to e.g. the track title, if you really want (or leave it as is). Tap 'OK' to save the track to the playlist. Then, tap 'Menu > Music Home > My music > Playlists', and select the playlist you have just created (with the track you want to hear over and over).
Hope it works for you.
Anyway, please, let me know if I can help you any further.
Regards, Carlos
May 08, 2011 | Motorola Mobility Defy Cell Phone
I can't make my archos
be sure that you have already saved a list of song on your playlist. and for the pdf also make sure that there was a file that save on that location...
let me know
Aug 29, 2008 | Archos Audio Players & Recorders
How to do playlist on the s100
Hi, You can do play list from your PC. By connecting your MP3 player to the PC through Usb cable..
Things You'll Need:
* Computer
* Media player
* Digital music files
Creating a playlist on your computer is an easy way to organize your music. Playlists allow you to organize music by different artists or different genres. More advanced playlists can even sort your music based on when it was added or how often you play a particular song. Creating a playlist is an easy task regardless of the media player you use to play your music.
Determine what songs you would like to add to your playlist.
Create a new playlist in your media player. Depending on your media player, this step will vary. There is usually a "Create Playlist" button that you can click to create a new playlist. In iTunes, this button is on the bottom lower left corner. In Winamp, click the "View" menu and select "Playlist Editor".
Select the songs that you want in your playlist from a new Windows Explorer window. If you are using a Macintosh computer, select the songs from a new Finder window. You can hold down CTRL to select multiple tracks. Drag and drop these selected songs into the new playlist you have just created.
Save the playlist you have just created. Most media players have a "Save Playlist" button. Other media players such as iTunes will automatically save the playlist for you when you first create it. In Winamp, click the "Manage Playlist" button in the bottom right corner. In the following context menu, click "Save Playlist". Name the playlist whatever you want and then choose where you want it to be saved.
Have a nice day....
Feb 19, 2011 | iRiver E10 Digital Media Player
Make a new playlist?
To create an M3U playlist On your PC, create a new empty .txt document using word pad, type nothing but save the file as a .txt. go in to my computer -->> explore and find the file and rename the .txt document so it has an m3u file extension (example: my_list.m3u). Open the m3u file with wordpad, notepad, or a text editor. In the first line at top of the page type #EXTM3U. After the first line, start listing your music files, copy and paste the song names , (with extension ie .mp3). One music file name each line. Exit the text editor and save the m3u file once you are finished. Drag and drop the M3U playlist to the player's MUSIC folder, your done.
Apr 09, 2010 | Apple iPod nano 3rd Generation
How to make playlists on ipod?
select a song and hold the centre button until the title flashes. Then choose the other sings you want to add then choose music then playlists and then On-The-Go to view your song list then save playlist to save the list. Hope this helps
Nov 17, 2009 | Apple iPod nano
How to create playlist on e260 sandisk sansa pm3 player
this is from sansa website FAQ... check it too for ur other concers... well i hope this is what ur looking for...
How do I create and transfer playlists into my MP3 player using Windows Media Player 11?
STEP 1 – Create a playlist
  1. Run Windows Media Player.
  2. Click Create Playlist located in the top left corner.
  3. Type in the name of your playlist.
  4. Drag and drop music files into the Playlist Window.
  5. Click Save Playlist to save the list.
STEP 2 – Transfer the playlist to your device
  1. Click the Sync tab on the top bar.
  2. Drag and drop your playlist from the left window into the Sync List window on the right.
  3. Click Start Sync.
Sep 13, 2009 | SanDisk Sansa e260 MP3 Player
Need Creative Zen user manual. No longer on the website. I really just need to know how to create playlists if you can help me with that.
  • Creating playlists for Creative Zen MP3 player
  1. Step 1 Turn your Creative Zen MP3 Player on and add music to its hard drive if you haven't already. Without music on your player, you won’t be able to select tracks for a playlist.
  2. Step 2 Select "Music Library" from the Main Menu. The Main Menu should appear as the first menu when you turn your device on.
  3. Step 3 Select "Now Playing" from the options available, then press the Options button.
  4. Step 4 Select "Save as Playlist" from the list of options. This will save the tracks you have listed currently as a playlist that can be reloaded later.
  5. Step 5 To play a playlist back, go to the Main Menu, select the playlist and click
Jun 16, 2009 | Audio Players & Recorders
I cannot get to my playlists or music. could you give me directions? Is the manual I can download
You can always save your playlists by clicking on Export option under files tab and it will save the playlist as .txt file.
Try searching if you have saved your playlist in .txt format
Dec 27, 2008 | Audio Players & Recorders
Making playlists
yes you can create playlist using WMP11...
To create playlist using WMP
  1. 1. Click the Library tab. If you need to clear the List pane before beginning to create your playlist, click the Clear List pane button playing_i_clearlistpanebtn.gif.
  2. Drag items from the Details pane to the List pane to add them to the new playlist.
    To select multiple adjacent items, press and hold the SHIFT key while selecting. To select nonadjacent items, press and hold the CTRL key while selecting.
  3. To rearrange items, drag them up or down in the List pane.
  4. To save the list, click Save Playlist at the bottom of the List pane, and then type a name for the playlist.
    By default, playlists are saved with a .wpl extension in the Playlists folder, which is usually located in the Music folder. You can also save playlists with the .m3u or .asx extension. To do so, click the List button at the top of the List pane, click Save Playlist As, and then change the extension in the Save As dialog box. Once you save the playlist, it's added to the Playlists category in the library.
    To play the playlist in the List pane, click the Play button playing_i_playbtn.gif.
  5. To access the playlist in the future, click the Playlists view in the Navigation pane.
I hope that helps
Please rate accordingly
Thank you
Computerrep
Jul 19, 2008 | SanDisk Sansa Connect MP3 Player
2nd G - Nano: Music syncs from Itunes but not playable
click on the ipod on the left and go to music, also maybe creating new playlists might help??
Apr 22, 2008 | Apple iPod nano
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
