Question about Aquacal HeatWave SuperQuiet 143k BTU Pool & Spa Heat Pump
Aqua cal heat wave super quiet Heater won't turn on. Flo symbol is on. What should we try
143k
Hot tub won't heath up cal spa
Could be many things, please explain further.
Apr 11, 2013 | Aqua Flo Spa Or Hottub 1.5 Hp Jet Dual...
Aqua Flo Flo Master won't start on low speed
Water flow error on hot tub means low water flow. This is not enough water flow to turn the system on.
Some motors do have a start capacitor on them. you can certainly check that or take it to your local motor repair shop and they can check that for you.
Rod
US Parts Center
Jan 13, 2013 | Aqua Flo Aquaflo Flo - Master Xp2 2 Speed...
Breaker tripping
This could be a heating element issue. it could be a bad element. Disconnect the two leads going to the heating element and then turn the breaker back on. If it will run and not trip the breaker then you have found the problem.
On the heater tube there is a silver sticker that will have the information you need to identify what model heater you have and what the kw of the element is. It will either be 4 Kw or 5.5 Kw
You may contact us for more information about this or purchase the replacement element at www.uspartscenter.com
Nov 09, 2012 | Garden
My hot blows the fuse just as soon as I turn it on, I unhock the heater and it still blows the fuse. How long is the motor gauntee for Flo Msater XP2-551521
1 year.
If you disconnect the jet pump plug from the control box can you turn on the service and not blow it again? That would be the easiest way to confirm a motor failure is your problem.
John
Oct 17, 2010 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
I am looking for a Flo-Master XP2 by Aqua Flo. Modal 06630397-2. How much would it be?
A quick google search brings up a number of online sites between $340, and $430
Sep 22, 2010 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Removal of Aqua-Flo pump from motor
You will need to pull the front of the pump off then unscrew the impeller. The impeller will be set on the shaft and will take some force to break free. Hold ing the back of the shaft and using water pump pliers on the face of the impeller will usually work but sometimes I will wedge a screwdriver in the fin of the impeller and hit it sharply (not hard) with a hammer to break it free. Then the housing will just pull free of the motor. When replaceing, the impeller just goes on hand tight. Hope this helps and good luck.
Apr 15, 2010 | Aqua Flo 1 HP Aqua-Flo Pump: 1.5" in/out,...
LF READING ON PANEL
LF means "Low Flow". Remove the filters to see if the code goes away. If not, the pressure switch may be bad.
Feb 09, 2010 | Aqua Flo 1 HP Aqua-Flo Pump: 1.5" in/out,...
When I turn on the jets at the first setting it brrrr's but does not start. The second setting works fine and when the second cycle is finished the first continues fine. It is just when it first started...
Sounds like you may have a bad start capacitor that is not kicking the motor when it's set to run the low speed. If it just humms, it's usually a capacitor. It can also be the bearings but if it runs quietly normally, then it's probably a start capacitor. Hope this helps.
Nov 01, 2009 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Aquacal HeatWave SuperQuiet 143k BTU Pool & Spa Heat Pump Logo
35 people viewed this question
Top Aquacal Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you an Aquacal Pool and Spa Expert? Answer questions, earn points and help others
