Question about Garden
Leveling a kubota mower deck - Garden
  • 10 Answers
SOURCE: having problems leveling the mower deck
put it on a level surface then put blocking ( 2x4s work) under the deck and drop it on the blocking. loosen all the adjusting bols to let it settle squarly on the blocking then re-torque the bolts. Should be level.
If not check you blade berrings as they may be worn and the blade shaft may not be square to the deck
Posted on Sep 02, 2009
  • 8404 Answers
SOURCE: mower deck
MAKE DARN SURE THE POWER IS OFF BEFORE YOU START THE PROCEEDURE BELOW! there should be 4 connection points for this machine. Clear out your garage ... get something comfortable to lay on and a small supply of proper supply wrenches and a tape measure. put the deck in UP position. put the blades perpendicular to the front to back axis of the machine. Measure from the floor to the blade tips on the outside. record the numbers. turn the blades 90 degrees. repeat. adjust the proper corner slowly (no big changes!) continue to measure until the numbers are equal.
Low on the left - change the adjustments on the left front and back. Low in the front - lift the front - both sides.
It took me several hours to do my mower when I got it new but I was pretty particular about it
Posted on Sep 07, 2009
  • 133 Answers
SOURCE: need to replace drive belt on cutting deck and
You will have to disconnect the deck from the tractor. There might be some rods hanging down by the pulley on the motor. You have to loosen those not remove. Then install the new belt with the inside of belt (V) into the pulleys. The outside of belt (flat side) goes up against any idlers (oversized pulleys). Once you get the belt routed properly the belt will be snug in the pulleys. If you have excess play you have to use trial and error to get the belt routed the right way around the idlers.
Once belt is on reattach the deck and tighten the rods by the motor that keeps the belt from coming off. They need to be close but not touching the engine pulley.
Good luck and let me know if this helps.
roundo4
Posted on Oct 24, 2009
  • 3911 Answers
SOURCE: MOWER BED LEVELING
Get the mower on a flat slab of concrete. Raise the deck all the way. Make sure the blades are on correctly. Measure the distance from each corner of the deck to ground. Lower the deck and take the same measurements. You will find, if you look, some threaded rod/bolt and/or pin settings to make adjustments. Most often the deck is out of whack as someone took it off and did not put it back on correctly. Google the mower's make and the word "'manual" if you cannot figure it out. Someone out there will provide you with a manual if you cannot figure it out from looking at it and there will be instructions in the manual as to making the adjustments.
Posted on Jul 07, 2010
goldenglove1
  • 144 Answers
SOURCE: I have a problem leveling
The deck could be bent, or you will probably have to level the back of the deck as well. Another thing to check is the air in the tires, this can cause an uneven cut. Although the tire may look pumped up, with the weight of a person on the tractor can cause an uneven cut.
Posted on Aug 10, 2010
Need the front deck wheel and swivel for zd28 60 inch deck
Marvin, check the links below for Kubota deck parts.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Lawn Mower Parts Discount Online Parts Cheap affordable lawnmower parts
http://www.tractorjoe.com/kubota
kubotaParts Online
Kubota Tractor Corporation Parts
Apr 22, 2016 | Garden
Kubota T 1460 Need belt size for deck and belt going to Engine
kUBOTA FOR T1460 SN 40001 AND UP
K5112-71410 DECK BELT
K5112-51310 ENGINE TO DECK
Cross reference shows both to be 5/8 x 69 Kevlar belts
Apr 17, 2015 | Kubota Garden
ONLINE PARTS DIAGRAM FOR KUBOTA ZD331
Go to Kubota Kpad Site. You must be running Windows Internet Explorer or the correct add-ons to access to site. Also you need to know which size deck you have.
Here the front part link.
Apr 05, 2015 | Kubota Garden
How to level 60" zd 21 Kubota deck
YOUR GOING HAVE TO ADJUST SCALP ROLLERS OK THIS IS ABOUT ALL YOU DO LIFT DECK UP MEASURE THE BLADES TO THE DECK WHAT YOUR CHECKING FOR IS A BAD SPINDALL GRAB YOUR BLADE WITH GLOVED HANDS JANK BACK AND FORTH 9F THAT SPINDEL MOVES REPLACE IT CHACK OF OF THEM YANK THE HELL OUT THEM ALL THE SPINDEL THEN LOOK AT SPINDEL SUPPORT PLATE MAKE SURE NON OF THEM OR BENT FORWARD OR BACK WARD STICK A SMALL RULER ACROSS TO SEE IF FLAT ALL THE WAY AROUND IT CHECK ALL OF THEM LIKE THIS THIS THE LAST THING YOU CAN DO YOU DONE EVERYTHING ELSE IT COULD BE IM REALLY CURIOS IF THIS DOENT FIX IT WHAT IT COULD BE HAVE YOU CHECKED THE ALINEMENT DECK TO MOWER IT ISNT OFF CENTER WERE IT COULD BE PUSHING DECK TO THE SIDE THATS ALL I NO WHAT TO DO THE RED NECK LET ME NO WHATS HAPPENS
Sep 01, 2014 | Garden
Free lawn mower manuals
http://www.kubota.com/part/parts.aspx
if you start here, you maybe able to find the manual
Jul 16, 2014 | Kubota Garden
Do you have free manuals of Kubota mowers?
Try requesting manuals directly from Kubota.
Garden Logo
188 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
