Question about Dehumidifiers
Zenith zd309y9 Won't turn on
2 Suggested Answers
Nomadfeet
  • 59 Answers
SOURCE: I have a Zenith Dehumidifier, ZD309Y9 and the
Do a quick search for part # 4839A10004J - this should be the tank assembly for your unit.
Posted on Sep 27, 2011
How do i use?
Turn it on. It should work itself. After a day the compartment at the bottom is a bucket and it comes out. It will fill with water, the machine will shut off. Dump it. Put it back. It will start again
Apr 30, 2013 | Dehumidifiers
My zenith dehumidifier won,t stay running
if it runs for just a few seconds then clicks n stops its probably the thermistor in the motor starter circuit Re: Jeff
Apr 13, 2012 | Dehumidifiers
I have a Zenith Dehumidifier, ZD309Y9 and the water tanks handle broke. How can I get a new tank?
Sep 27, 2011 | Dehumidifiers
What is the drain size to run in copper for Zenith ZD300 dehumidifier. The inspector will not let us use a garden hose for drain as per you instructions. Fire hazard, we have to run a copper drain. What...
Fire Hazard? How can a rubber hose that drains water, be a fire hazard? This inspector is jerking you around. Since there are no copper fitting that will fit the connector, use a flexible stainless steel water water supply hose, that's normally used on an automatic washer. You'll wind up with 2 female ends, but that won't matter. Be sure there is a rubber washer in the end you connect to the unit's hose connection and only tighten it enough that it won't leak. If you over tighten it, it will crack or brake the plastic male connector.
Just for my own information, why is a building inspector necessary for the installation and approval of a portable dehumidifier? You can respond bu clicking on the Comment link. Thanks
Sep 19, 2011 | Whirlpool Dehumidifiers
Zenith zd300yo display flashes ''01''and bucket full flashes
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Aug 13, 2011 | Dehumidifiers
It won't start. Turning the knob, I don't hear the
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jun 06, 2011 | Dehumidifiers
Zenith,water doesnot fill thetank
heatman101
Jun 01, 2011 | Dehumidifiers
My dehumidfier won't shut off. I check everything out and it's good but it just won't shut off it keep running.
It may be, that you have it running in continuous mode, rather than timed mode. Also, most dehumidifiers fans will run almost continually, to keep the air moving, so the humidity sensor can pickup and increase in humidity, if there is one.
If the above doesn't seem to be the problem with your unit, turn The Master ON/OFF Switch to OFF and unplug the unit for 12-15 minutes. This will give the electronics time to reset themselves, if necessary.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
May 23, 2011 | Fedders A7DH45B2A Dehumidifier
Was full - turned off to empty - replaced empty bucket, won'r turn back on and keeps beeping full
Try reinserting the bucket, making sure that it's positioned properly. So that the safety switch is engaged. If that still doesn't solve the problem. Turn the MASTER ON/OFF Switch to OFF and unplug the unit from the wall outlet. Wait 12 - 15 minutes and plug the unit back in. Turn the MASTER ON/OFF Switch to ON and hopefully, if the bucket is positioned properly, the unit will have reset itself.
Hope this helps you to solve the problem. Please let me know.
May 08, 2011 | Maytag Dehumidifiers
My 1 yr old Zenith ZD30 dehumidifier just stopped working all together. The bucket is empty and I checked the to be sure that a circuit didnt trip. Any suggestions as to what it can be?
The Zenith ZD30 is made by LG as many other brands are also. There is a fuse located on the control board. That may have blown. I have also had 3 LG units come into my shop with bad control boards. If the fuse is ok. Measure the ohms at the power plug L1 to Neutral, with the unit unplugged. It should read around 430 ohms. The ones with bad boards read real high. Hope this helps.
Rasske's Renewed Appliances
Oct 20, 2009 | Dehumidifiers
Dehumidifiers Logo
23 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
