Question about Garden
My husquavarna cz 3815 deck sits way low in the back and don't have any more adjustment how can I fixit
2 Suggested Answers
  • 138 Answers
SOURCE: husqvarna cz 4815 diagram to put deck belt back
there should be a routing diagram sticker somewhere on the deck. look at the back side of the deck in the middle
Posted on Aug 25, 2009
How do I clear the E6 code in a Xterra 3.0 treadmill?
An E6 or E7 error code is an incline error code. The E7 code means the potentiometer value the console is reading from the lift motor is out of range. This can happen when there is a bad wire harness connection or a damaged wire harness. It could also just mean the incline motor needs to be adjusted back into range. If all wire connections look ok, the incline motor will need to be adjusted.
  1. Turn the power OFF, wait 5-seconds and turn back ON.
  2. Get into test mode and enter through the I/O testing step. This screen will display the potentiometer value of the incline motor. Different models will have different values. Check to see if the running deck is raised to high incline level or if it is at the low level. If the running deck is at a low position press the incline up button. This will cause the incline motor to raise the running deck up. When the deck gets to a mid-level position, press the incline up button a second time to stop the deck. If the running deck is in a high incline position, use the incline down button to adjust the deck to a mid-level position.
  3. Once the unit is in the mid-level position, power the treadmill off for 5-seconds and then power it back ON.
  4. Start the treadmill.
  5. Once the treadmill starts the running deck will move to the level 0 position. If this does not resolve the issue or it will not adjust please contact customer service.
Also note that not all models will have the ability to adjust the incline motor. If the adjustment procedure is not found in the Owner's Manual then contact customer service.
Apr 05, 2017 | Exercise & Fitness
How to adjust the deck height
left to right, there is a nut on each side between the deck and floor where your feet sit. front to back is the drag links attached to the front of the deck. adjust left/right first, then front to back. make sure tires are aired up before you do it.
Jul 15, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Where on the deck do i install the 490-900-0025 MTD Riding Lawn Mower Deck Wash Kit
IMHO,. this is not worth installing, I have one on my Husquavarna ,and it broke off ....I'm NOT putting in back on,a good scraping of the grass is easier,and the bearings don't see all that water !
Jun 18, 2014 | Yard Machines MTD Riding Mower Deck Wash...
Surging and not idoling
Hi, Anonymous and the usual suspects are:
1. Idle speed improperly adjusted.
2. Inlet system air leak.
3. Leaking accelerator pump.
4. Loose low-speed jet.
5. Plugged low-speed jet.
6. Contaminated or plugged low-speed circuit.
7. Enrichner valve is not seated or leaking.
For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have nice a day.
Honda Bros bamboozaling problems
Tech Tips for Lambretta and Vespa Scooters
http://www.motogelnar.cz/manual/YAMAHA/DT125X_RE-05-Service_Manual.pdf
OEM parts for Yamaha
http://www.dt125.cz/download/Owners_Manual-DT125X_RE.pdf
Jan 31, 2014 | Yamaha DT 125 R Motorcycles
Blades won'e engage
Your belt may be on wrong or slipping.
May 23, 2013 | Craftsman Garden
How to adjust the mowing deck properly?
Find a level surface (concrete garage floor for example) ... adjust front to back ... use a tape meadure to mneasure floor to deck edge ... then adjust side to side.
Jul 29, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How to adjust the mower deck on my murray rider,
Park the tractor on a firm, level surface. . .
At the lower end of the lift/lower travel slot, there should be a plastic cover which you pop up so that your blade lift handle goes all the way down (it should say something about blade level on there somewhere. . . . .
After you have the handle in this position, look at the front lift arms of the mower deck and find the 2 large wing nuts, one on each side. . . . .
Loosen these while the deck is down and then retighten them Your deck is now level and will lift to its highest recommended position when you raise the lever
Oct 11, 2009 | Garden
Husqvarna cz 4815 diagram to put deck belt back
Aug 24, 2009 | Husqvarna Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
