Question about John Deere Garden
John deere f925 electrical diagram
No power to clutch. the clutch was checked and is fine
SOURCE: how to replace belt on john deere 425
take a sharpy and outline it before removing
Posted on Jul 19, 2009
mowerman1857
  • 389 Answers
SOURCE: v-belt route installed on 48" deck of John Deere LA130
http://jdpc.deere.com/pimages/PU00/PU00859________UN28APR08.gif
Copy and paste this in your address bar and it should take you to a picture of how to route the belt
Posted on Sep 18, 2009
mowerman1857
  • 389 Answers
SOURCE: How do I remove the PTO clutch from a John Deere
Locate and disconnect the power supply cord from the clutch. Remove the bolt, washer and retainer from the center of the clutch, It should now slide off the end of the crankshaft provided you have previously removed anything such as body parts or braces that would be in the way. In some instances penetrating oil must be used to help free it up. When you reassemble it, it is a good idea to use a little bit of anti-seize on the engine shaft in case you have to remove it in the future.
Posted on Oct 30, 2009
wireguy212
  • 1627 Answers
SOURCE: ELECTRICAL PROBLEM
Can't get you a diagram but i can tell you most electical problems on these tractors can be solved by replaceing the key switch/modual or cleaning corrosion from fuse holders.
Posted on Nov 10, 2009
nova2nv
  • 197 Answers
SOURCE: My 870 john deere clutch will not disengage. The
This is common for the 70 series.Clutch dics are stuck together,just short of splitting tractor you have to hit a pile of dirt with loader bucket to see if you can break it loose.
Posted on Nov 14, 2009
I have a John Deere GT275 that keeps blowing the F3 15A fuse. Any suggestions why?
Get a wiring diagrams and trace down each component the fuse powers and its wiring and find the short, no other way to fix it.
Jul 12, 2017 | John Deere Garden
Wiring diagram for LX172 John Deere
Type into google john deere riding mower wiring diagram for pto switch clutch circuit then click images
May 12, 2016 | John Deere Garden
F525. Updated mower switch by John Deere is not engaging mower
The John Deere F525, a front cutting machine, has 3 fuses.
20 Amp
15 Amp
10 Amp
Check the 15 amp fuse. I believe this supports the PTO clutch. If you replace the fuse and it blows again, check the electric clutch. You will likely find burnt or melted wires. The bearings do go out on these clutches causing them to run hot and eventually burn up.
PTO Clutch will not engage: There is a very fine one page discussion on evaluating electric clutches at this site:
http://www.messicks.com/Articles/FixingElectricClutch.aspx
My JD tech manual, which covers the entire LA 100 series, agrees with the electrical specifications. It states that the Electric PTO Clutch should show the following:
Resistance 3.7 ohms
Current Draw 3.25 amps
It does not give the air gap.
It does include a note to check the PTO Clutch Key for damage or if missing. So there is a drive key between the PTO Clutch and the shaft. Additionally, it recommends checking the tightness of the cap screw. That's the screw or bolt that holds the clutch on the shaft.
Cap Screw torque 55 lb-ft (75 N.m).
If the fuse blows, I recommend you check the resistance of the clutch. If the clutch is shorting to ground it will show zero resistance when you ohms the connector wire to a ground position. In which case, you will have to replace the clutch.
Fixing Electric Clutches
Other possibilities.
On the F525 there is a cut-off switch in the hydraulic system. It is a low pressure cut off. If you were running the mower and deck and then it suddenly stopped, it may be low pressure in the hydraulics. It will not automatically reset as you are using the same volume for the drive pumps. Once the oil gets low enough it cuts out the deck drive 1st, then the drive pumps.
Apr 16, 2015 | John Deere Garden
John Deere L120 wiring diagram
The electric clutch draws current while engaged. It is quite hungry on power which means that if the battery is low, the generator may not be making enough to charge the battery and hold the clutch in too. This is why the batteries on these machines are so large relative to say an ATV battery. I have several times experienced units with low batteries which started the engine OK but would not hold the clutch in. The battery may be getting old and not holding the charge. Try charging with a mains operated charger. Make sure to check water level in battery cells. Running them dry can ruin the battery.
Aug 01, 2014 | John Deere L100 Series
I am looking for a diagram for a wiring harness for a john deere 777. The problem being that the clutch will not turn on to turn the blades. The clutch works fine, I think that wire 460 and 461 that...
Hi, My guess is that there is a safety switch in that system and is not working properly. Check it out. if you still need wireing diagram go to the dealer and have the photo copy a page or two for you. Good luck.
Jun 14, 2011 | Refrigerators
Mowerdeck will not engage...
I own a similiar John Deere model (L130, 23HP with a 48" deck). I would check the electric clutch (called a PTO). To do this check the wires to this clutch and look for something disconnected. These wires (to this PTO clutch) should have twelve volts with the key on and the blades engaged.
Feb 26, 2011 | John Deere 195HP Hydrostatic 42" Cut...
I have a John Deere l130 and the mower blades engage when I start the engine even when the PTO switch is off. Any suggestions?
sounds like you have feed going directly from switch as soon as you turn ingition to start mode ?
check wiring back from electric clutch to main switch
possible 2 wires have been placed on main switch instead of pto switch ?
or you have a crossed circuit somewhere (that is feed from another live circuit) not directly connected and its ended up at electric clutch as soon as you liven main circuit
a wiring diagram may help
check with www.johndeere.com
or www.jdparts and enter their site load your model and type
and go to electrical system and print out a copy of wiring diagarm
you may need to supply and user name and apply for password from john deere via their site apply on line
its a good site for info and parts diagrams
cheers hope it helps
paul
Aug 05, 2010 | John Deere Pto Clutch For Stx38 And Stx46...
Fuse problem on John Deere 318 lawnmower
Does the mower have an electric clutch the clutch could be going bad if it has one unplug the clutch and see what happens
Oct 19, 2017 | John Deere Garden
Garden Logo
51 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
