Kenmore elite 41722000
Cl wont turn off
Hi! I have a Kenmore Elite dishwasher and getting the "CL" code? No function works. Any ideas on how to fix this? Thx??
Sounds like the control lock is activated and you'll need to deactivate it. Press and hold the drain and spin button for 5 seconds to accomplish this.
Apr 16, 2017 | Kenmore Dishwashers
Kenmore elite front washer show code cl? How do i fix it
The CL fault indicates that there was an instantaneous current spike of 26 amps at the motor windings in the washer. This could be caused by overloading the washer. It can also be caused by problems with the drive motor, thermal protector or the motor controller.
You should have been able to clear the display by pressing the STOP/CANCEL button.
If you try running the washer again and continue to get this fault code even with a small or medium load, I recommend calling a service technician to diagnose and repair the washer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 29, 2010 | Kenmore Elite 45986 Front Load Washer
WHAT IS A CL CODE ON MODEL 796.41022900 FRONT LOAD KENMORE ELITE WASHER,IT SHOWS INTERMITTENLY DURING WASH CYCLE
Means someone put it in controlled lock position. Just hold the Control lock button down for 5 sec or so until the light comes off. Machine isn't malfunctioning.
Jul 31, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore elite calypso codes a C1 and quite working
Maybe "CL" From User Manual:
“CA” or “CL” (Current Limit)
Is the washer overloaded?
Press STOP/CANCEL to clear the display.
Jul 04, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
My kenmore elite he4 dryer wont start
kenore elite oasis dryer won't start, when start button is held down it flashes F, book says call service center
Jun 30, 2009 | Kenmore Dryers
Error code on kenmore washer
LG washing machines indicating error code CL may have the child lock activated.
Try holding down the temperature and eco/rapid options together to turn off child lock.
Some LG series use "TEMP and OPTION" at the same time.
Feb 22, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Calypso won't drain
CL or CA is an over amp draw most likely caused by the motor thermal protector or motor controller It can be caused by too large of a load try to press "STOP/CANCEL" to clear if the problem returns you will need to get inside the unit
Jul 09, 2008 | Washing Machines
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
