Question about Boating
Serial R1474066 model #CE15RCUD
Want year of motor 15 horse power motor serial # R1474066 evinrude outboard motor
    Problem Solver:
  • 6 Answers
  • 65 Answers
SOURCE: evinrude outboard motor starter rope
most likly is missing a washer,has been reassembled incorrectly.take apart and check
Posted on May 08, 2009
Editor925
  • 285 Answers
SOURCE: Missing operators manual for Evinrude 2 hp outboard motor
Your best bet is ebay for a replacement user manual. Take a look around, you will come across one... For the meantime, gas oil ratio should be 50 parts gas to 1 part oil, i.e. 50:1. General care: Dont go full throttle for any length of time. Cruise of 3/4 throttle... Always flush engine after use in saltwater, including washing down exterior. Keep spark plugs in good order and check prop for fishing line wrapped around in near the prop hub. Otherwise, get a yearly service and have them check the water pump and replace as needed, get it tuned etc and gearbox oil changed.
Posted on Jun 20, 2009
  • 86 Answers
SOURCE: how to replace impeller in a 1959 evinrude
Put engine in fwd gear. Then disconnect the shift linkage. Remove the bolts that hold the gearcase on and slide gearcase off of the tower. Remove the 4 bolts or screws in the waterpump housing and lift the housong off. Replace the impeller and reassemble in reverse order. Make sure that you get the water tube lined back up and you can twist the prop to line the splines back up in the powerhead.
Posted on Aug 09, 2009
  • 57 Answers
SOURCE: cant find how to tilt evinrude outboard
have you got hydraulic trim/tilt? if so control button /switch will be on or near throttle handle-if not you will have to manually lift and insert pin at bottom of mount on transom
Posted on Oct 15, 2009
  • 45446 Answers
SOURCE: Are 1975 and 1977, 55HP Evinrude outboard motors compatible
yes they are on most parts
Posted on Apr 26, 2010
I need to know the specs on an evinrude outboard motor serial # 3030-07926
Everything in marine outboard engines is tied to MAKE and Horsepower. From that, you can find the year using the serial number. Once you have those, you can Google
year make model specs
or
year make model manual
Evinrude Outboard Motor Model Numbers
Jul 30, 2017 | Boating
What year is a evinrude outboard with serial number 1451821
The motor HP is critical in such searches. Here are all the resources you need to find the information yourself.
About this result
How To: Outboard Engine Serial Number Year Match, iboats.com How ...
www.iboats.com/basics/serial_number_year.html
  1. Cached
  2. Similar
For engines prior to 1969 refer the the Johnson 1960-1979 serial number year chart located here. If you have a commercial model refer to the Johnson commercial serial number year chart located here. Evinrude changed how they indicate year in the model number in 1980.Mercury Outboard · ‎Evinrude Outboards 1950-1979 · ‎Johnson Evinrude Commercial
[PDF]5006145_Model Number Reference.fm - Evinrude
shop.evinrude.com/media/document/ModelNumberReference.pdf
  1. Similar
MODEL NUMBER DESIGNATION - OUTBOARDS. Model Years 1980-1998. V E 70 T L ED A. MODEL VARIATION. A = Australia. B = Belgium. C = Canada.
Evinrude Outboard Motor Model Numbers & Codes - Marine Engine
www.marineengine.com/manuals/evinrude/
  1. Cached
  2. Similar
The nameplate should contain a model number and a serial number. The model number will identify the year and certain details of that motor. 1980-Present: Evinrude outboards from 1980 to the present use a model number that can help determine the year and features of the motor. See the model number code here.0.5HP · ‎0.9HP · ‎1HP · ‎1.1HP
Marine Motor Look-Up Guide - Auto Repair Manuals
www.autorepairmanuals.biz/page/599222
  1. Cached
  2. Similar
keywords: Find year, serial, number, model, number, #, outboard, motor, marine, motor, look-up, Johnson, Evinrude, Mariner, Mercury, Force, OMC, Yamaha, ...
EVINRUDE OUTBOARD MOTOR MODEL YEAR LOOKUP GUIDE ...
www.maxrules.com/models/OMC_models_files/EVthru79/ev_index_79.html
  1. Cached
  2. Similar
WHAT YEAR IS THAT OLD EVINRUDE? FIND OUT HERE ON OUR MODEL YEAR LOOKUP CHART! evinrude outboard with serial number Google Search
Nov 29, 2016 | Boating
Identifying this outboard motor from evinrude, AQABVA71K899
Rob, AQABVA71K899 does not seem to come up as a valid # for referencing engine. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Outboard Engine Serial Number Year Match up
EVINRUDE OUTBOARD MOTOR MODEL YEAR LOOKUP GUIDE 1913 1979 MASTERTECH MARINE
Jul 11, 2016 | Boating
What year and model is my antique evinrude motor?
I have never seen anyone answer these questions.if you looking for a condenser they are all the same.eg a 1965 40hp condenser will fit a 1955 20hp
Oct 01, 2014 | Sierra International 18-5199 Marine...
Evinrude year serial number 3014-10340
3014 is a three horse 1955 Evinrude Lightwin. 16/1 fuel oil mix, points set at 0.020 and the NGK B6S plugs set at 0.030". 80-90W marine grade gear oil is used in the gearcase. Nice motors!
Aug 20, 2014 | Sierra International 18-5199 Marine...
What is the year model of a evinrude outboard motor with the serial number 1503201749
try reading this on ehow http://www.ehow.com/facts_7292301_evinrude-year-identification.html
Jul 27, 2014 | Longines Evidenza Watches
What year model is a mercury outboard 4 horse with serial number 3303712?
call a mercury dealeris all I can tell you .we handled johnson /evinrude.
Jun 17, 2014 | Light Outboard Motor Boat Bass Fishing...
Boating Logo
326 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
