Question about Sony Playstation 3 (PS3) Console
Internet problems only one name will not work for ps3 but all 3 other ones do why is that?
Straighttalk settings for blu phone
try this one
had the problem going through forums trying to find the settings that work for my phone but to no success but I finally figured it out and I'm posting it on here just in case some one else has my same problem.
I had to create two separate APN's one for internet and one for MMS. Settings are as follows:
Internet:
Name: Straight Talk Internet
APN: att.mvno
Proxy: proxy.mvno.tracfone.com
Port: 80
User Name: Not Set
Password: Not Set
Server: Not Set
MMSC: Not Set
MMS Proxy: Not Set
MMS Port: Not Set
MCC: 310
MNC: 410
Authentication Type: PAP or CHAP
APN Type: Internet
APN Protocol: IPv4
Bearer: Unspecified
MMS
Name: Straight Talk MMS
APN: att.mvno
Proxy: Not Set
Port: Not Set
User Name: Not Set
Password: Not Set
Server: Not Set
MMSC: http://mmsc.cingular.com
MMS Proxy: 66.209.11.33
MMS Port: 80
MCC: 310
MNC: 410
APN Type: Internet+MMS
APN Protocol: IPv4
Bearer: Unspecified
Do not forget to create two separate APN's!!!!!
goodluck
Jun 23, 2014 | Blu Cell Phones
How to make internet setting in samsung galaxy s duos s7562
Go to settings, select more under data usage
then select mobile network then select access point names and press menu. after that select new APN, type your network name at the name column and type internet at the APN column..u r done..
enjoy ur internet
Feb 05, 2013 | Samsung Galaxy S Duos S7562 White Dual SIM...
Dns error
DNS stands for Domain Name Service, and it helps in accessing various websites on the Internet. An error regarding the DNS for any particular website usually implies the lack of an active Internet connection. The purpose of DNS is to simply translate the address that a user types on the web browser from the human language into the computer language.
DNS is used to resolve names to numerical IP addresses, which is needed to route traffic onto the Internet. Whenever a URL is entered into the browser, the beginning part is the website's domain name.
One Website Not Working: try contacting other sites on the Internet to see if the DNS error is particular to one website. If only one site is not working, the problem rests with the one website.
Computer Not Connected: another item to check when a DNS error shows up is to see if the computer is on the local network. Check to see if the home or office router can be reached from the computer. If not, the DNS error is from the computer not being able to connect to the local office or home network.
Internet Connection Down: if no websites are working, it might be because the Internet connection is down due to a faulty cable/DNS modem or the ISP is down. Power off and on the modem. If the DNS errors still persist, contact the ISP.
DNS Errors: in the vast majority of cases, DNS errors have nothing to do with DNS. DNS errors are usually one of the first symptoms of internet or wireless connectivity issues.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Dec 20, 2011 | Sony Playstation 3 (PS3) Console
Mms/gprs settings.my network provider is smart
(How to get there? Open settings - Network - APN/Access point - New apn).
On internet settings try this first: Usually works but not always. Under are SMARTs own settings.
Connection name: Internet
Acces point name: Internet
NOTHING ELSE
Hope it helps.
I. GPRS/WAP Internet Settings
Connection name: SMARTGPRS
Data bearer: Packet data
Access point name: smart1
User name: leave this blank
Prompt password: No
Password: leave this blank
Authentication: Normal
Homepage: http://wap.smart.com.ph
Network type IPv4
Phone IP address: 10.102.61.46
Name servers: Automatic
Proxy server address: 10.102.61.46
Proxy port number: 8080 or 9201
(differs from one handset model to another)
Default access point: SMARTGPRS
Data bearer: Choose GPRS
Access point: internet
User name: (leave it blank)
Prompt p'word: No
Password: (leave it blank)
II. MMS Settings
Connection name : SMARTMMS
Data bearer:Packet data
Access point: mms
User name: leave it blank
Prompt password: No
Password: leave it blank
Homepage : http://10.102.61.238:8002
Network type IPv4
Access point: mms
Prompt p'word: No
Homepage: http://10.102.61.238:8002
Jun 08, 2011 | Sony Ericsson XPERIA X10 Cell Phone
Modem is working but internet is always showing down
It problem should be Internet Service Provider,
Do some steps if any problem connect with your modem..
goto - Control Panel - Clik on Network Connectioin - (LAN -- High Speed Internet open) delete this connection.
-then click on Create a new connection (left side in Network Tasks) - click on next - connect to the internet - click on set up my connection manually - next - use second option - *(connect using a broadband connection...)next - ISP name -type ISP name - use user name or password if don't have -click on direct Next button - Finish.
Your internet will be work...
Thanks
Aug 14, 2010 | Computers & Internet
Problem Event Name: APPCRASH Application Name: iexplore.exe
I think it is a usual problems, u can try to delete some bad application or spam or anything from : internet explorer - select tools - then internet option - in tab general, choose delete and then checklist all components there - and then OK
if it is doesn't works, you just have to enabled/uninstall your internet explore through program files or registry
hope works,
May 30, 2009 | Microsoft Internet Explorer 7
the nice thing about IE7 is that it has a nice easy way to fix alot of problems.
click on tools, internet properties, advanced and then click the last button on the page, the one about resetting to defaults..any bad or bogus addons become disabled and any bunged up security settings go to their defaults.
after this, you'll have to re-enter your homepage and install addons like flash player and java, but that generally solves any issues you might be happening. what is the website? it could not be a problem on your end but some bad code in their site.
Apr 26, 2009 | Microsoft Internet Explorer 7
Windows explorer has stopped working
There is probably a problem with one of the add-ons that the browser runs. Go to the internet options and "manage add-ons." Disable anything that looks suspicious.
Oct 18, 2008 | HP DeskJet F380 All-In-One Printer
I can't use internet
Assuming that I am understanding your problem correctly, you can connect via your wireless access point, but Internet Explorer isn't working on your computer? Does the problem exist on the other computers as well? It would appear that you have a connection, just no browser. If the problem is simply the browser not working on one computer (your laptop I presume), then download another copy of the browser on a different computer, save to a flash drive and reinstall it on the problem system. The browsers can cache web pages temporaily and stores the URL's to recently visited web pages in the history folder. I also would suggest having more than one browser on every computer because of problems like this. The most popular and sometimes the primary browser used is Mozilla Firefox from www.mozilla.com. Browsers do not resolve the web domain name (URL) This name resolution is performed by a Domain Name Service Server (DNS). Your ISP most likely also has a DNS server and provides the address resolution for your queries on the internet. Hope this helps.
Dec 06, 2006 | D-Link DWL-G700AP 802.11g/b Wireless...
Sony Playstation 3 (PS3) Console Logo
14 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
