Question about NAD T752 Receiver
Receiver powers down after few minutes of play
After being on for only several minutes, NAD T752 will cycle off on its own. Any help? Thanks.
  • 287 Answers
Has bad 12 volt regultor and 2 5.1 volt zener diodes on the main board in the regulator circuit, also may have a few caps near these parts which also need replacing. ref # for the 12 volt reg is u703 , kinda a major job.
Posted on Sep 18, 2007
NAD T752 display totally lit up. FM sound works but no frequency display.
Sounds like display driver board {IC} has damaged. Contact any service technician. Electro help
Dec 08, 2014 | NAD T752 A/v Surround Sound Receiver
NAD T752 Hi, When powering up, about 4 second after, the amp turn in protection mode. Nothing is connected to the anp and it is clean from any metal dust. I found one transistor to be very hot. It's...
It could be entering protect mode because it has no speakers wired to it, have you tried connecting to all 6 speaker - out connections. Often, if an amp can't detect a load on all 6 channels it won't work. Also, have you checked the thermal fuses? a blown fuse could cause this problem.
Apr 07, 2011 | NAD T752 Receiver
Hi there .. i have a nad t752 amplifier , i have just got it back from the nad repair shop , they have just reinstalled it , but now the front right speaker is much softer than the left front speaker ,,...
I hate to say this but the repair was not complete. If the sound levels are different with the balance in the middle, then either they missed a problem in one of the pre-amp stages, or they used an incorrect substitution for transistors in one or more stages. This unit should be brought back to complete the repair.
Any additional detail would require that I see the actual unit and poke around inside with test equipment.
Aug 08, 2010 | NAD T752 Receiver
Short Pin/Headphone jack issue with NAD CBE 720 Receiver
It's logical since the headphones jack is connected at the main amplifier. Does your new main amp has headphones out?
Feb 20, 2010 | NAD T752 Receiver
Processor short-circuit.
I just crossed referenced that part, and the sofware couldn't find it. You need to find out what manucturer it is, then go to that web site and order it. How many pins does it have? Is it a sip, or a dip chip? sip stands up with pins at the bottom., dip lays flat with pins on both sides. You may have to order that from the product manufcturer.
Jul 01, 2009 | NAD T752 Receiver
NAD T752 Receiver. The unit cuts off after about 2 hours operation.
It's sitting on a totally open cabinent with sufficient space around it.
Sep 10, 2008 | NAD Audio Players & Recorders
Right Channel Not Working
I have had the front, left and right channels go out over time. I have fixed all of them, and each time it has turned out to be a cold solder joint. While I love NAD and will continue to purchase there equipment, this generation is plagued with poor workmanship.
To fix the channel going out, I removed the top cover. Back cover and 2nd card from the left (looking at the receiver from the back side). This card handles all of the audio processing. I have found cold solder joints all over this board which has caused channels to suddenly go quite. I have never found a bad component. Also, I have cleaned the interconnect to be backplane (board that the audio processing board connects to) in the case of the center channel going quite.
If you have poor FM reception, the first board from the left (looking at the receiver from the back side) may have a cold solder joint on the coaxial connection for the FM antenna.
Apr 26, 2008 | NAD T752 Receiver
OSD for NAD T752
The blue screen indicates a proper connection (signal received by the monitor). Try selecting "amp" on your HTR 2 remote then use any directional button at the center of the remote, the keys which circle the "Enter" button. Hopefully you will then see the menu appear. Use the same directional keys to navigate the menus.
Mar 28, 2008 | NAD T752 Receiver
Receiver wont turn on
It sounds like You have a Bad output Some where and its going in to protect mode disconnect spkrs and make sure volume is Down all the way and power up,Ck your wireing for Freyed wires and shorts at the inputs and outputs good Luck ttech
Jul 09, 2007 | NAD T752 Receiver
Receiver won't turn on
has 2 zener diodes and a 12 volt regultor defective in the regulator circuit on the main board, may also have a cap or 2 near the 12 volt reg. ref# u703
Apr 19, 2007 | NAD T752 Receiver
NAD T752 Receiver Logo
338 people viewed this question
Top NAD Audio Players & Recorders Experts
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
