Question about Comfort-Aire HD-451 Dehumidifier
Owners manual Won't turn on at all-was working fine and collecting water -very damp basement
Our AD25THO. Runs fine but has recently stopped collecting water. It's dry as a bone and our basement is very damp. What's wrong with it?
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jun 11, 2011 | Whirlpool AD25BBR Dehumidifier
My dehumidifier runs and the refrigerator or cooling unit turns on, but no water comes into the bucket? Last year it was running fine? fans run and the humidity level is high in the basement
heatman101
Jun 09, 2011 | LG LHD45EL Dehumidifier
Dehumidifier is located in basement utility room where water lines sweat when sprinkler system is in use. Temperature is currently about 68 in the area. Turned dehumidifier on for about 45 minutes but no...
heatman101
May 27, 2011 | Maytag M3DH30B2A Dehumidifier
Two years old Delonghi DE400 doesn't collect water, everything looks fine and running (no water but smell in basement).
heatman101
May 10, 2011 | DeLonghi DE400 Dehumidifier
I have one of your dehumidifiers and it turns on but we do not get any water out of it I have had for a few years but it was only used one year and it worked great when we went to use it again we got no...
If you haven't clean the air intake filter since you've had it. More than likely that's the problem. A dirty filter makes the dehumidifier strain to take in the moist air and it just can't keep up.
If you don't have your Owners Manual to guide you through the process. You can download one online, from Sears Parts Central.
Hope this helped you to solve the problem.
Apr 27, 2011 | Kenmore 54501 Dehumidifier
The dehumidifier is running but no water is being eliminated from my damp basement
Florence, the air intake filter on the humidifier probably needs to be removed and cleaned. When they're dirty, the unit has to strain to take in the damp air. Turn the Master ON/OFF Switch to OFF and unplug the unit, before attempting to remove the filter. Once the filter has been cleaned and dried (if necessary), plug the dehumidifier back in, turn the Master ON/OFF Switch to ON and set the controls as you normally would. After about an hour or more, you should notice water collecting in the bucket.
Hope this helped you solve the problem.
Apr 27, 2011 | Fedders Dehumidifiers
Why isnt my dehumidifier getting water in the bucket and my basement is damp
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Mar 04, 2011 | Dehumidifiers
It has been on for 24 hours in a damp basement and has collected hardly any water.
There can be many reasons why a dehumidifier willnot work or collect water.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Sep 13, 2010 | Woods WD25G Dehumidifier
My dehumidifier does not collect any water.
One of two things is happening here.
1. Either the compressor isn't running or...
2. The water is not being routed to the collection bucket properly. This dehumidifier has an option to connect to a hose that can be routed to a drain. Look in the back of the unit to see if you see a connection that could accomidate a garden hose. If you see this and there is no hose connected you may be dumping the water on the floor instead of the bucket. This could explain why your carpets are damp.
Jun 18, 2009 | Kenmore 54501 Dehumidifier
Not collecting water
If everything is running and no water is being produced the system may have lost its refrigerant. There are two motors in dehumidifiers. One is the fan and the other is the compressor. Make sure they are both running.
Jun 18, 2008 | Goldstar DH304 Dehumidifier
Comfort-Aire HD-451 Dehumidifier Logo
29 people viewed this question
Top Comfort-Aire Dehumidifiers Experts
Mike Squire
Bill Long
J.D. Browning
J.D. Browning
Are you a Comfort-Aire Dehumidifier Expert? Answer questions, earn points and help others
