Question about Alpine Design Highback Folding Chair
Need tube for back of chair
Bar in the back broke and the bracket that holds the bar. Bar code 7 14129 03019 chair number SMC114A
I need the sway bar bracket number for mower 917-272263
The parts lists for the Crafstman 917.272263 mower is available here: http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Riding-mower-tractor-Parts/Model-917272263/0247/1509200?shdMod=917.272263&sid=C2CxSPDxModelSearchxModelNotoSPD . The Sway Bar Bracket is on the Mower Deck diagram (part 3) is part number: 138017 . Sears Parts Direct lists this part as backordered. However, a vendor at Amazon does appear to have it in stock. See http://www.amazon.com/Husqvarna-138017-Bracket-Assembly-Craftsman/dp/B0057ILJAA ; this bracket fits several mowers, including Sears/Craftsman mowers.
I hope this helps.
Apr 21, 2012 | Garden
About alternator replacement for 2001 vw beetle gls...I've removed the upper and lower bolts... What am I missing? Alternator still won't budge. Any assistance would be appreciated. Thanks.
all the bolts removed then all thats holding it is the adjustable tube in on the lower fitting ,put a bar in and try moving it then it will move as on the lower fitting with the long bolt is a tube in the alternator housing bracket and this is pulled or pushed out to make contact with the support bracket .Check you havent got three bolts holding it as some vehicles have two bolts on the bottom bracket or one long one
Apr 15, 2012 | 2003 Volkswagen New Beetle Convertible
I have a franklin towel bar and the mounting bracket broke at the screw hole. is there replacement mounting brackets avaible?
Probably not, but if they sell a toilet paper holder of the same style the bracket might be identical to the towel holder, but would be cheaper than buying a new towel bar. Good luck, Al K
Mar 16, 2011 | Franklin BATH UNLIMITED NORTHPORT TOWEL...
The left bracket/brace is off the wall. There is one long screw in the back center. How is this put back together?
There should be a small screw in each of the arms that secure the towel bar to the wall mounts. You will need to loosen each of these to remove the towel bar from the wall and to release the mounting bracket which has pulled free. To repair you need to puchase a larger size moly plug, toggle mount or other suitable hardware to secure the mounting bracket to the sheetrock wall (should not have pulled free is screwed in to the stud). Once you secure the mounting bracket then you are able to re-install the towel bar by placing the arms over the mounting brackets and tightening the small screws on each arm of the towel bar.
Here are a couple of videos which should help you undesrtand how towel bars are installed. Hope this is helpful. (do not delete) utube.png Here is a couple of videos that should help understand how towel bars
Dec 19, 2010 | Moen 24 In. Towel Bar...
I need a rear suspension diagram for a 1999 Mercury Cougar
Item Part Number Description 1 Body mounting cup 2 Spring seat 3 Spring 4 Strut 5 Crossmember 6 Stabilizer bar 7 Front arm 8 Rear arm 9 Wheel spindle 10 Tie-bar 11 Dust cap 12 Brake drum 13 Hub retaining nut 14 Hub and bearing assembly 15 Backing plate 16 ABS sensor 17 Tie-bar mounting bracket
Sep 02, 2009 | 1999 Mercury Cougar
Mutsy Urban Rider
Hi guys, I had this problem when I first got my urban rider - the trick is to put the seat on correctly in the first place. If you look under the front of the seat (when seat is facing away from mum/dad) you'll see 2 plastic hooks - these need to be hooked over the first horizontal bar of three that you can see (it has a small black plastic nobbly bit on it) then, as you were doing, push the handle and pull the 'tube'. If the seat is facing you (child travelling backwards) it won't fold, neither will it fold with the carry cot attached.
Hope this helps! Tegans mum x
Feb 14, 2008 | Mutsy 4Rider - Pink Stroller Frame
Alpine Design Highback Folding Chair Logo
85 people viewed this question
Top Alpine Garden Experts
Dennis Key
Dennis Key
john h
Are you an Alpine Garden Expert? Answer questions, earn points and help others
