LG HGTV STB LST-3100A No scan no menu
Set top HGTV box no menu to view no channels found on scan.
  • Ablebay Sep 15, 2007
    There seem to be no software memory no menu on montor to view soft/ware
    default chip maybe damage thank you I have tryed direct channel dump from VCR,3&4 sat out 3.4.5,6&UFH highband there seem to also be a RF input fault .THANKS ANYWAY I GOING TO CAN THE LG HGTV JUNK
  • 44 Answers
Make sure you have an antenna hooked up to the antenna connector on the back.
Posted on Sep 15, 2007
SOURCE:
My box keeps saying boot. When I channel search, no channels appear. How do get channels to watch?
Plug the antenna into the ANT IN input of the STB. Forget about the RF IN output of the STB. Plug the 3-way output of the STB into the corresponding 3-way input on the rear panel of your LG TV.
Sep 18, 2016 | LG Televison & Video
Wont receive digital channels after scan non found
Hi Patrick,
You must have a UHF / VHF antenna connected to the antenna input of the TV to scan for digital channels. Most new TV's have a threaded, round 75 ohm coax cable connection for this - but yours might even have connection consisting of 2 small screws to connect a 300 ohm twin lead antenna cable instead. Use which ever yours has.
If you are using this input for the input of a cable TV "set top box" (STB), satellite STB, or similar, you will likely only find a single analog channel (Ch3 or Ch4) after a scan as the scan will only find the output of the STB - which is usually on Ch3 or Ch4 - and not be able to scan the STB channels.
Additionally, the antenna input of the TV will only provide a standard definition picture if connected via coax cable from the STB. It will only provide a high definition picture if connected to a UHF / VHF antenna and a broadcaster is close enough for its signal to be received by the antenna. The way to obtain the best possible picture (high definition) when using an STB for tuning channels is to use an HDMI cable between the STB and TV. An HDMI cable will provide the very best picture and audio signals from the STB to the TV; all over a single cable and is the recommended practice.
I hope this helps!
Dec 26, 2014 | Televison & Video
Hi, will my LG LST-5100P work in England?
Yes the digital set top box should work in the UK. When it arrives just re-scan for the channels as the UK are currently in the middle of a digital switch over.
Regards.
Dec 14, 2010 | LG LST-4200A DTV Receiver
Unable to rescan channels AWA STB 262 set top box.Need to scan for lates channels. Menu button not working. AWA HD Digital Terrestrial Receiver Model STB 262
These STB262 box remotes won't work if they are not hooked up with the 720dpi option (Use HDMI Cable) -
Cheers - compac
Sep 01, 2009 | Televison & Video
LG LST-5100P set top box does not display menu with an older ( 1998) tv set. Cant select aspect ratios . All I can do is change channels. Any ideas? Rod
Hi Rod,
Thanks for Using FixYa. If its a 4:3 normal TV or a wide 16:9 TV then you can view high definition picture by using the ARC button on your remote control to change the wide mode(Auto,Letter Box, Pan & Scan). Also check its free user manual for more information.
LG LST-5100P User Manual
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jul 22, 2009 | LG LST-4200A DTV Receiver
Channels gone
Setanta Have gone bust but if you've also lst other channels this'll help :-
Subject: Star View 3 The Box Super when channels discappear ;o) 1. Press menu then Factory Setting & Enter code 0000 to reset. 2. Exit to main menu & enter 1570 to get into the CASS SYSTEM & turn EMU on 3. Reinstall channels (Goto Installation, Cable network (try TW first & if no channels try NTL then C & W and so on - I'm with Virgin & used the setings for TW) & Voila ;o) Nb: You may have to redownload channels so reconnect yr box to the computer & follow the link below http://www.4shared.com/file/76886028/fd4ac296/GTRom_the_box_Super_8102e_081129.html?err=no-sess & press download !!!
Mar 22, 2009 | StarTech.com StarView SV211K 2-port KVM...
32lg30 mkj40653801 codes
A printable manual with codes can be found at http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=3252
Jan 21, 2009 | LG 37LG30 37 in. LCD HDTV
How to remove LG LST-4100A
To remove the LST-4100A commercial control interface from the television you need to follow the commands below.
1. Power on television.
2. Press and hold "MENU" for 10-15 seconds.
3. Quickly press "2-6-6-3" and then press "ENTER"
If you have done everything properly, it will bring up a small menu in the top left hand corner of the television. Kind of a hidden menu.
4. Arrow down to the menu option that says "D Box" and turn the option to "OFF".
Now turn off television and completely disconnect the LST-4100A. In fact, throw it away. In the trash is where it belongs.
Your television will now operate like a normal television purchased from a big box store. You should run an automatic programming setup for grins upon completing.
Enjoy your new NON-commercial lcd television.
Dec 22, 2008 | LG LST-4200A DTV Receiver
LST-3100A "HELLO" msg
Got you some help!! Open receiver up...Locate the power supply board. Locate the electrolytic capicitor "C118" and replace. II've fixed multiple LG LST 3100a receiver doing this procedure. Guaranteed to work. I hope you have not throw it away. Cheers!!!!
Sep 26, 2008 | Zenith LST3100A DTV Receiver
LG LST-5100P set top box. Several times a day have
cap-grant, my friend has the same problem with set top box. When I phone maker I was told it is due to poor and weak signal. You must have 80% signal strength to maintain good picture. When signal strength dropped picture would freeze and had to be turned off at the power point to restart as nothing would work. So I guess what my experience says is you may need better aerial to boost signal and prevent dropout Leonard210
Oct 05, 2007 | Televison & Video
Open Questions:
NORTON 360 TecHnicaL supPORT Phone .***.18OO8O3..1O69-**.NumBer pds vcs Usa NORTON 360 USA phone number is ranked #2 out of 2 because 7,728 NORTON 360 USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach t he NORTON 360 USA Technical Support department for problems like Where to buy, Complaint, Technical support, Repairs, Returns. As far as we can tell, NORTON 360 USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. NORTON 360 USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact NORTON 360 USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling NORTON 360 USA Calling NORTON 360 USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from NORTON 360 USA Technical Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with NORTON 360 USA's Technical Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare NORTON 360 USA's phone numbers against each other. Contacting NORTON 360 USA in General While I8OO8O31O69 is NORTON 360 USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach NORTON 360 USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact NORTON 360 USA.
Oct 21, 2019 | Norton Computers & Internet
Computers & Internet Logo
142 people viewed this question
Ekse
Marvin
Marvin
