Question about Braun Flex Integral 5550 RB Electric Shaver
Battery braun replace model 5550 shaver. how to remove old battery from shaver?
How to remove old battery from shaver?
SOURCE: Braun battery replacement
Unfortunately this is almost impossible. The batteries are part of the circuit board, and Braun only authorize their service agents to replace the whole unit, and my local agent found that it had been discontinued. If you still want to have a go, two screws are hidden beneath the two grey plastic caps either side of the charging socket on the underside of the shaver which can be prized off quite easily. Once you have removed the screws, the small plastic section comes off. Now you can slide the outer casing off. A thin black cover at the back can then be unclipped, revealing the circuit board and batteries. The whole unit simply lifts out and would be easy to replace if you could find one! Rplacing the batteries would be far more difficult and risky. Good luck.
Posted on Sep 02, 2008
  • 5 Answers
SOURCE: how to replace battery on braun 7526 electric shaver
1) Use a small flat screw driver pry off the bottom (where the cord plugs in)
2) Remove the silver sides
3) Using a small torq driver remove the 4 scews
4) Open shaver
5) Remove circuit board with batteries
6) Install new circuit board and reassemble
Posted on Jan 07, 2009
VtToolMan
  • 704 Answers
SOURCE: Braun 5614 rechargeable cordless shaver light flickers
Your batteries are starting to degrade, but the good news is they're still holding a charge for a week, so you really don't need to rush to replace them at this point.
The flickering of the charged indicator is normal, as the shaver is still plugged in and the batteries are fully charged. The flickering is due to the batteries chemicals breaking down, and as such, the charge cycle keeps "topping" them off while it's still plugged in.
When you finally aren't able to get a decent amount of cordless operation and run times from your shaver, then you'll want to get them replaced, whether you decide to do that yourself or have it done by a professional service center, is up to you.
Here's a reference for your future use. www.electricshaver.com carries replacement (factory OEM) batteries for most brands of shavers and they also will provide the repair/replacement service for you, should you decide you don't want to do it yourself. You can also give them a call at 1-888-476-1785 and request a price quote, etc.
Anyway, your shaver is working fine and all you need to do is make sure you're not letting the shaver stay plugged in and charging constantly for more than a day, since any "extra" chargind isn't doing anything except keeping the batteries at a constant state of charge. Heat is a byproduct of charging and discharging any battery and as such, you want to allow for a cool down period before recharging them.
I tend to use my shaver until it is almost completely discharged before recharging it. By doing this, you can get the longest working life out of your batteries before you'll have to replace them.
Hope you find this Very Helpful and best regards!
Posted on Oct 23, 2009
Testimonial: "very helpful"
brector3
  • 1623 Answers
SOURCE: How do I open a Braun 8585 shaver to replace the
You will find batteries at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
To open the shaver body, you will first need to gently pry off the 'cap' on the bottom that surrounds the hole where the cord plugs in. Once removed the side grips will pull off revealing 4 screws. Remove screws to take off back cover and access insides. Inner parts simply lift out. Reassemble in reverse order
Posted on Jul 13, 2010
brector3
  • 1623 Answers
SOURCE: How do you open a
You will find replacement battery at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
Start by removing the foil and cutter. Then remove the swivel frame by removing the two tiny screws on each side of the inside of the swivel frame.
To open the shaver you will first need to remove the two round screw covers on the bottom. Then remove screws. You can then gently pry the two halves apart from the bottom
Posted on Sep 30, 2010
Testimonial: "Thanks a lot. The tip was super and my shaver is again working fine."
How to replace battery in braun 5720
Braun Select Models Electric Shaver Disassembly Tutorial
1. Remove two screws on the bottom, where the power plugs in. Need to remove two ribber plugs first.
2. Pull from shaver head and remove shaver "guts" from case. (It will be hard to remove as it is encased in rubber to make it waterproof, but keep wiggling and tugging)
3. Remove old batteries and replace with new ones.
4. Re-assembly is reverse
Nov 08, 2013 | Braun 360° Complete 8985 Electric Shaver
Removing Battery
The easiest way is to break the tabs off of the batteries. See video at link below
https://www.youtube.com/watch?v=2oAnLpvdYqQ&feature=c4-overview&list=UUc_zJiCUI8mpLyYlwCxo8IA
Jul 21, 2013 | Health & Beauty
I have a Braun 5550 electric razor that no longer holds a charge. i believe the battery can be replaced but I cannot see how to remove the battery. Can you advise?
You can repair the shaver by replacing the batteries only if the shaver still works. If the shaver no longer does anything...will not run and light does not illuminate when plugged it, the circuit board is now bad and can not be repaired.
To open the shaver, remove the two plastic screw covers on each side of the hole where the cord plugs in on the bottom of the shaver. Remove the two screws underneath. You can then slide the entire outer case off of the shaver. Be careful not to disturb the trimmer as it is extremely difficult to reattach. Inside, you will see a black inner cover. Unsnap to remove it and access the circuit board and batteries.
You will find compatible batteries at shaveroutlet.com. You need two. See link below for item and scroll down for helpful installation video
Aug 02, 2011 | Braun Flex Integral 5550 RB Electric...
Braun 7526 needs new rechargable battery
You will find batteries for model 7526 at shaveroutlet.com. See link below
Scroll down the page for disassembly video instructions.
For easier replacement, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Feb 21, 2011 | Braun Syncro 7526 Electric Shaver
My shaving machine BRAUN when i plug in not workig and is not charging as well
Sounds like the batteries need to be changed. You will find compatible batteries at shaveroutlet.com. See link below. You will need two
To open shaver, remove the two round screw covers on the bottom by prying them out. Remove screws underneath. Slide outer case off the bottom. You may need to reposition the lock to get it all the way off. Inside, you will need to unsnap and remove the black cover to access the batteries. For easier replacement, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
If you are not able to repair the shaver yourself, shaveroutlet.com can do it for you. See link below
http://shaveroutlet.com/shaver-replacement-parts/professional-battery-replacement-for-most-models-p-374.html
Jan 05, 2011 | Braun Flex Integral 6550 Electric Shaver
I've connected it to 115v with cable from old Braun and probably burned out fuse or rectifier. How I could take apart the shaver?
To open the shaver body on model 8585, you will first need to gently pry off the 'cap' on the bottom that surrounds the hole where the cord plugs in. Once removed the side grips will pull off revealing 4 screws. Remove screws to take off back cover and access insides. Inner parts simply lift out.
You will probably need to replace the circuit board you will find a replacement circuit board for model 8585 at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-activator-circuit-board-with-batteries-select-models-p-363.html
Jul 31, 2010 | Braun 8585 Electric Shaver
Braun Flex Integral 5550 RB Electric Shaver Logo
78 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
