Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Folder Read Only problem in windows xp professional
Hi, I have windowx xp profession installed on my computer. In my D drive there is 2 folder which are share for all my network client. Now the problem is these 2 folders shows read only in their property diaologue box and after removing readly only option some time after agains these 2 folder shows read only. My clients are not accessing these folders. Pls help to getrid of this problem. regards tito
  • Guatam Aug 29, 2007
    No it is not helping out. our all the sysem was infected with W32.Imaut. I have removed this virus from my all the system after that every computer's folders attribut set on read only (the box shows grey instead of checked)and it keep showing the same after I change the read only attribut. Pls check and revert.
    tito
  • 53 Answers
Hi This may help you http://support.microsoft.com/kb/304040 Good luck.
Posted on Aug 29, 2007
SOURCE:
Hi sir can help me for product key of windows xp pro sp3.tnx
HI,
You can find the product key. just follow these steps. Insert Windows XP cd into a working computer. Exit the Auto-run introduction.Open "My Computer" Right Click on the Windows XP cd-rom drive and select explore.Open the USWXP32P_ZX folder. (It may be as a hidden folder. If you cannotlocate the folder, you may also search forunattend.txtand mark "Search Hidden Files".)Open the sysprep folder. Open unattend.txt Your CD's product key is containedwithin the unattend.txt file.
Jun 06, 2011 | Microsoft Windows XP Professional
Target folder not accessible.
Perform the steps mentioned in the below article.
http://support.microsoft.com/kb/810881
Also, try this:
CAUSE
This issue may occur if the folder that you cannot open was created on an NTFS file system volume by using a previous installation of Windows, and then installing Windows XP. This issue may occur although you enter the correct user name and password. This issue occurs because the security ID for the user has changed. Although you use the same user name and password, your security ID no longer matches the security ID of the owner of the folder that you cannot open.
For example, although you use the same user name and password, you may no longer have permission to open the folder after you complete the following steps:
1. Before you install Windows XP Professional, you change the actual location, or target location, of the My Documents folder to another volume.
2. You format the primary partition.
3. You install Windows XP Professional.
RESOLUTION
To resolve this issue, you must turn off Simple File Sharing, and then take ownership of the folder:
1. Turn off Simple File Sharing:
a. Click Start, and then click My Computer.
b. On the Tools menu, click Folder Options, and then click the View tab.
c. Under Advanced Settings, click to clear the Use simple file sharing (Recommended) check box, and then click OK.
2. Right-click the folder that you want to take ownership of, and then click Properties.
3. Click the Security tab, and then click OK on the Security message, if one appears.
4. Click Advanced, and then click the Owner tab.
In the Name list, click your user name, Administrator if you are logged in as Administrator, or click the Administrators group.
If you want to take ownership of the contents of that folder, click to select the Replace owner on subcontainers and objects check box.
6. Click OK.
You may receive the following error message, where Folder is the name of the folder that you want to take ownership of:
You do not have permission to read the contents of directory Folder. Do you want to replace the directory permissions with permissions granting you Full Control? All permissions will be replaced if you press Yes.
7. Click Yes.
Click OK, and then reapply the permissions and security settings that you want for the folder and the folder contents.
Also, try to create a folder in external Hard Drive and then try to back up the data.
Jun 25, 2010 | LaCie Design by F. A. Porsche 160 GB Hard...
I have just intalled anti virus and it has messed with my windows activation code so now it dont work and can not find the code
Find Windows XP Product Key from the Windows XP CD: 1) Insert Windows XP cd into a working computer.
2) Exit the Autorun introduction.
3) Open "My Computer"
4) Right Click on the Windows XP cd-rom drive and select explore.
5) Open the USWXP32P_ZX folder.
6) Open the sysprep folder.
7) Open unattend.txt
Your CD's product key is contained within the unattend.txt file.
Note: On some system disks, USWXP32P_ZX is a hidden folder. If you cannot locate the folder, you may also search for unattend.txt and mark "Search Hidden Files".
Oct 26, 2009 | Microsoft Windows XP Professional
Where is the /System32 folder physically located on the drive?
Hi there.
This is the path >>>>>> c:/windows/system32....
So, click on "my computer", you will see "local disk c", click on that, if it says "these folders are hidden" click on "show files". Then click on the "windows" folder, in that folder you will find "system32" folder.
Thanks for choosing FixYa!!
Jun 12, 2009 | Microsoft Windows XP Home Edition
Service packs not cleaning up properly
(sited from http://www.winxptutor.com/randomfolders.htm)
When you install Windows XP SP1, SP1a or SP2, this temporary folder is created on the volume that has the most free space. The folder name contains random characters, and is not always created on the same volume as the Windows folder. For example, this temporary folder may have the following random names:
9470bb12e8a4f3447657236478e41c5
or similar.
352b81d1c4bf3810e28482d9979
This folder is automatically deleted by Windows XP after you install the service pack. However, if the folder is not automatically deleted by Windows XP, you can safely delete this folder.
Please Note:
In most cases, you will receive an Access denied message while accessing or deleting this folder. First, you'll need to Take Ownership of the folder and then delete it safely.
May 21, 2009 | Microsoft Windows XP Professional With...
HELP ME
hi there my friend,
we have the hard way and then we have the easy way...
the hard way is to bootup with your bootable xp cd .follow the installation guide ..then.put in your key when you get the chance to ..and finish the installation. then apply service pack 2 to your installation .. and you're done...
the easy way would be to make a Slipstream Windows XP Service Pack 2 CD....which you can use each time you need to fix your system.
1 - Download the (full) "Network Install" of the Service Pack (English version [266 MB]), and save it to a directory (folder) on your hard drive (in my case D:\XP-SP2). Other languages can be downloaded from the Microsoft Download Web site.
Note: do not use spaces in the folder name!
2 - copy your Windows XP CD to your hard drive. Just create a folder (I used \XP-CD), and copy all the contents of your Windows XP CD in that folder.
3 - , open a Command Prompt (Start > Run > cmd), and go to the folder where you downloaded SP2 (cd \foldername). Type the command: servicepack filename /integrate:drive/path. In my example the command is WindowsXP-KB835935-SP2-ENU /integrate:D:\XP-CD.
Extract SP2 files
If you get the error:
This service pack can't be integrated error
This is caused by the fact that your Windows XP CD contains updates that will be automatically installed when you run setup. This type of CD's will usually be from larger OEM suppliers (like Dell, HP, or others).
You cannot use this type of CD to create a slipstreamed SP2 install.
First, the files will be extracted, and next they will be integrated in your Windows XP files:
Updating Windows Share
When ready, you should get a confirmation. Windows XP Service Pack 2 has now been Slipstreamed into your original Windows XP files.
Slipstream Completed
Creating a Bootable CD
For this part I used IsoBuster and Nero Burning ROM 6
After you install IsoBuster, you can choose to use only the product's free functionality for what we want to do, IsoBuster will look like the image below (you need to have your original Windows XP CD in the CD-ROM drive).
Start to extract the boot loader from the original Windows XP CD. Using IsoBuster, select the "folder" Bootable CD, and right-click Microsoft Corporation.img. From the menu choose Extract Microsoft Corporation.img, and extract it to the folder on your hard drive where you have your Windows XP files (D:\XP-CD in my case).
Extract Boot Image
Next, start Nero Burning ROM, and choose CD-ROM (Boot) in the New Compilation window. On the Boot tab, select Image file under Source of boot image data, and browse to the location of the Microsoft Corporation.img file. Also enable Expert Settings, choosing No Emulation, and changing the Number of loaded sectors to 4 (otherwise it won't boot!)
Nero Boot Settings
The ISO tab should be configured correctly as shown below:
Nero ISO Settings
If you have an older version of Nero you won't have the option Do Not Add ";1" ISO file version extention under Relax ISO Restrictions. You won't be able to boot your new CD, so update Nero!
You can configure the Label tab to your liking, I would however recommend that you keep the Volume Label the same as on your original Windows XP CD. Here are some (English) Labels:
* Windows XP Professional: WXPCCP_EN
* Windows XP Home: WXHCCP_EN
* Windows XP Professional OEM: WXPOEM_EN
* Windows XP Home OEM: WXHOEM_EN
Nero Label Settings
Next press New, and from the File Browser window, select the files and folders from your slipstreamed location (in my case D:\XP-CD). Now drag & drop the selected files in the ISO1 window.
Copy Files
Next, burn your new CD.
Burn
You now have a Bootable, Slipstreamed Windows XP Service Pack 2 CD!
Apr 28, 2008 | Computers & Internet
Infeced virous make folde in a folder.exe
The virus is called "Brontok" or "Rontok". Its much hard to get rid of it. It may cause ur computer to restart while opening any anti virus, cmd.exe, command.exe etc. Only way is to san the drive from some other computer with an updated anti virus.
OR
Format driver with windows installation, instal windows, and install an anti virus before anything else ( do not open any drives except ur windows installation partition ) and get latest updates. Scan and remove virus.
Feb 19, 2008 | Microsoft Windows XP Professional With...
Folder options
ur computer is attacked by virus i can suggest u is install an antivirus updated version and it will remove the virus after that folder options and ur removable disk drives will be displayed
Nov 21, 2007 | Microsoft Windows XP Professional With...
How to remove a second installation of a windows o/s
you would not have been able to install xp home over xp pro as pro is an upgrade from home, so xp pro will be on a different drive partition, so the last version you put on will be on the 'C' drive as thats the one that is bootable. Follow your instructions, or simply use your xp disc to format the drive and install XP home.
Jun 13, 2007 | Microsoft Windows XP Professional for PC
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
79 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
