Question about Pool & Spa
What is Max-e-Therm pool heater E06 error code refer to?
5 Suggested Answers
  • 83 Answers
SOURCE: sta rite 400na gives error code 05 after about 30 seconds
I am not sure if you have received an answer to the issue, or not, but just in case! An EO5 error code is an open stack flue sensor, or switch, There are two forms of the stack flue sensor, so you will need to know which one you have on the heater.
What this error code means is that the sensor "read" the flue temp to be over 500 degrees. Usually, it is just gone bad and reading the wrong temp.
Posted on Jul 14, 2009
  • 366 Answers
SOURCE: Sta-Rite Max-e-Therm pool heater -- cycling and HLS
make sure that you have adequate water flow going through the heater and that your water chemistry is balanced.
Posted on Jan 19, 2010
jharwell668
  • 640 Answers
SOURCE: Sta-Rite Max-e-Therm pool heater shows error code
These pool heaters have a detailed users manual that has a great troubleshooting guide. I would try there first. They ask alot of questions that you have to be looking at the heater to answer. Here is a link to an online version.
http://www.backyardcitypools.com/images/bwp/Max-E-Therm-Manual.pdf
Posted on Aug 16, 2010
jharwell668
  • 640 Answers
SOURCE: Sr400na Max E Therm Pool & Spa Heater Dual Electronic Ignition Lo Nox 400,000 Btu Natural Gas: service heater light on?...
Try the owners manual for these pool heaters. They have a detailed troubleshooting guide that should let you know what you need to do.
Posted on Aug 17, 2010
R3 code and e06 what are thes codes
R3 should be a software code on the board.
E06 is Temp Sensor but check the wires and the connections. Also remove and inspect the sensor, it may be damaged.
Jun 18, 2014 | Sta Rite SR400NA Max E Therm Pool Spa...
Heater not working and error message E05 coming up. want pool warm for memorial day party!
Thank you for posting your question here on Fixya.com.
Page 43 of your manual, found here suggests both E05 and E06 errors mean the issue is related to "...(the) fuel supply, thermal regulator, check for correct orifices, etc...". It also touches on the possibility that if the unit was converted from NG to PP or vice-versa that the orifices are not correct.
Start with these two areas...if you need additional assistance please comment to this answer with details from what you find while checking these areas and I'll try and help you from there.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
May 29, 2011 | Sta Rite SR400NA Max E Therm Pool Spa...
What does code 888 mean
I have not seen that code on these pool heaters. You might want to check in the owners manual and follow their troubleshooting flow chart to find the source of your problem.
Jul 02, 2010 | Sta Rite Sta-Rite Max-E-Therm Low NOx Pool...
Heater isn't starting...how do I reset? Error
The users manual for these pool heaters has a very detailed troubleshooting guide. I would start there. A pdf version is below.
Jun 05, 2010 | Sta Rite Sr200lp Max E Therm Pool & Spa...
Sta-Rite Max-e-Therm pool heater shows error code AD0 and SF1 what does this mean
Feb 02, 2010 | Sta Rite Sr333na Max E Therm Pool & Spa...
Sta rite 400na gives error code 05 after about 30 seconds
Jun 14, 2009 | Sta Rite Sta-Rite Max-E-Therm High...
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
