Question about Garden
My scr 621 cub cadet will not start smoke comes from carb and exhaust when I pull cord
Will not start smoke comes out of carb and exhaust when I try to start it
5 Suggested Answers
SOURCE: My cub cadet src 621 has been difficult to start
If its ripping you arm off the timing is off. Check the flywheel key it is more than likely sheared off. Pull the cover and look down on the flywheel and you should see this.Your unit is not clear to me so whatever unit you have check the timing and when its right it will not pull your arm off.Good luck.
Posted on Mar 25, 2009
  • 4 Answers
SOURCE: I have a cub cadet lawn mower broken pull cord
just rewind the spring starting with the outer end and fill it back into unit. I always have the rope extended and rewind it back in and reinstall
Posted on Jun 07, 2009
  • 6468 Answers
SOURCE: Cub cadet ltx 1045 wont start, no spark.
remove the top cover from the engine and remove the small wire from the coil if still no spark the coil is bad
Posted on Aug 15, 2012
SOURCE: Cub Cadet SRC 621, won't start. New spark plug, cleaned carburetor and air filter, Whiffs of smoke occasionally
Sounds like a sheer flywheel key. Common on the SRC 621. Kawasaki motor, correct. The flywheel key is under the recoil. Pull the flywheel and check the key. A very small key is there. Breaks and puts the engine out of time
Posted on Oct 18, 2012
My cub cadet sc 100 won't start after putting it on it's side to sharpen blade.
Since you put it on its side, you most likely dumped all the oil from the crank area to the cylinder and carburetor. What you need to do is check engine oil to be sure it is full. Then take air filter off, clean the carburetor with carb cleaner. Remove spark plug, clean spark plug with carb cleaner. Pull the cord about a dozen times WITH THE SPARK Plug removed. Then install spark plug and try to start.
Feb 15, 2017 | Cub Cadet Garden
Will a model OEM 190-621 snowblower fit on a cub cadet LT 1024
Have you tried the cub cadet forum? If not, give it a click:
http://onlycubcadets.net/forum/forumdisplay.php?f=42
Nov 21, 2014 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Gas Blowing Out of Exhaust
Hi Haley
Here are a few suggestions
May 02, 2013 | Cub Cadet Garden
Oct 16, 2012 | Cub Cadet Street Sign- tractor lawn riding...
Aug 07, 2012 | Cub Cadet Garden
White smoke comeing from front of engine on my 1042 cub cadet lawn tractor.
White smoke is typically an indicator of an oil leak. This could be a leak, broken ring, valve or piston problem etc. I would start with checking your filter to ensure oil has not leaked inside there. Next I would check the spark plugs for oil build up. Doesn't sound like it's getting to the exhaust.
When i start the lt1042 cub cadet riding mower it smokes from the exhaust and oil is in the carb
sounds like the needle valve inside the carb has failed dumping gas into the crankcase and into the cylinder this overfills the oil and dumps it change the valve and seat change the oil a couple times add a fuel line shut off and run the carb out of gas when your done using it the newer fuel we get melts the rubber seal
Apr 25, 2012 | Cub Cadet Riding Lawn Garden Tractor 25hp...
My cub cadet src 621 has been difficult to start since the headgasket was replaced. In fact pulling the starter cord is not only difficult it sometimes kicks and almost rips your arm off. Why is is so...
Mar 25, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
