Question about Cell Phones
Samsung gt s5260
I have one samsung s5260 that shows battery charging when charger is connected but it acctualy not charge it
jaffi
  • 8 Answers
SOURCE: NOKIA 6630 displays not charging when connect charger
hi dude,
>>> dont remove any thing from u r mobile, first confirm the problem where it is...
>>> first try to put the charge by using other charger... still u r getting same problem means change the charging unit
>>>good luck... thank u....
>>> dont forget to rating the solutions...
Posted on Feb 16, 2008
SOURCE: not charging
your phone charger might be the primary problem...
Posted on Jun 22, 2008
SOURCE: Samsung j700 died overnight screen wont turn on, but will charge
change the flexi cable bro
Posted on May 14, 2010
  • 27 Answers
SOURCE: 1) My samsung champ GT-
Possibly your handset is wet...try to disassemble it and here's the manual you needed. Manual
Posted on May 31, 2011
SOURCE: samsung gt e2652 charging voltage is ok but not showing charging
Could it be that that the app is disturbing the charging.
hope for the best
kolbrun
Posted on Feb 25, 2012
Why my phone keeps restarting
Battery may not be charged enough to run the phone. Keep the phone off and connect it to a charger to fully charge the battery or use an external battery charger.
Be sure the The micro usb connector is fully seated and that the battery is actually charging. A loose connection may appear to start the charging process, but if its loose, it may not be continuing to charge. Check the % progress.
Aug 11, 2014 | Samsung Galaxy S 4 GT-i9500 Smartphone...
My samsung galaxy y 5360 become auto charge when i plug it to charger, after removing charger it become still charging continiously.......plz send me solution on 7411mohit@gmail.com
BRO I THINK the problem is with your software so go to recovery mode and just wipe data and cache and remove your battery and place it after a minute or u must factory reset it may any solution helps you
Jun 04, 2014 | Samsung Galaxy Y GT-S5360 Factory Unlocked...
My Samsung Galaxy Note 10.1 battery not charging can you please tell me why
Same problem on my Samsung Galaxy Note 10.1 (GT-N8013) w/ OS 4.1.2
It just boots up and shuts down.
Dec 06, 2012 | Samsung Metallic Gray Galaxy Note 10.1in...
My samsung corby cannot be charge..how can i solve this problem?
I would try charging it with a different charger. its more likely that the charger itself is the issue. If not then the issue could be with the phone. Try a hard reset of the phone ( pulling the battery) and then put battery back in and plug in charger. try moving it around if no connection issue could be with the charger or the charging port on the phone.
Oct 19, 2012 | Samsung GT S3850 Corby II
Samsung gt e3213k charging problem.
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Sep 07, 2012 | Samsung Cell Phones
Samsung gt-c6712 charging solution
My Samsung GT-c6712 mobile is having charging issue. when i connect the charger sometimes it workes and othertime doesn't. same charger works for others mobile, charger is ok. i am using for last 15 months,i bought @ 6600 price means 6600/15 =440Rs per month. many times when i am listening songs and if i make a call it hangs, i need to remove battery to restart it. instead of keeping attention on diff new functionlity these people should rectify common issues and improve basic functionality.
Aug 03, 2012 | Samsung Gt-C6712
Samsung R519-53S not charging
Please remove battery and connect charger and turn on computer. If on adapter working fine, now connect battery without removing charger , and check charging.
May 09, 2012 | Samsung R519-53S Notebook
Hello, Leoch 12V battery, DJW12-12Ah, is no longer charging. We bought a John Deere riding toy at a local Toys R Us in Michigan three years ago. My children have only used it for two summers and is...
Sounds like a battery problem.
Lead acid batteries should to be charged every 3 or 4 months even if they are not being used, or they can slowly self-discharge and will start to deteriorate if the voltage drops below about 12.2v (for a 12v batt.)
They can then be difficult or impossible to charge. The charger can see this as fully charged and show green.
You can test for this if you have a voltmeter. You should be able to work out if it's the battery or a connection (or the charger).
Measure the battery voltage (use a DC voltage range greater than 12V). The normal voltages you should see:
A) Key off, no charger: >12v, <14
B) Key off, charger connected: >12, <14.2, but higher than A)
C) Key on, no charger: >12, <14, but lower than A)
If voltage A) is low and immediately goes high when the charger is connected then the battery needs replacing.
If A) and B) are exactly the same then it could be the charger is not connecting or is faulty. Measure the charger output, should be >13.8v (unless it's an "intelligent" charger in which case it might need some voltage applied to its output before it starts charging).
Note: If A) and B) are low, say <8v it's possible that an "intelligent" charger will refuse to start charging. In this case it's probably worth jumping the battery to a good 12v battery (e.g. car). Be very careful to connect the batteries (+) to (+) and (-) to (-). Leave connected for 10 - 20min or even overnight and then disconnect jumper leads and check A) and B) again. Sometimes a battery can be recovered by this method (it's unlikely to regain full capacity though).
Jul 19, 2017 | Lee-t.com Facebook Apps
My samsung battery is not charging when i plug it in
check ur charger voltage. or replace your charger or otherwise the fault in ur cell fone board. in charging IC or charging jack
Feb 04, 2010 | Samsung Star GT-S5233 Cell Phone
Samsung charging problem
If very well could be the charging port. Have you tried a different charger?
If it is the charger port, You have 3 options.
1. get it repaired, warrant if possible
2. Get a new one
3.Get an external battery charger and charge battery separate from phone.Another battery and charger will set you back about 10 dollars on ebay2.gif.
For more information and links to the parts check the following link below.
Samsung SGH-D900 charging problem repair
May 13, 2009 | Samsung SGH-D900 Cellular Phone
Cell Phones Logo
22 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
