Question about VIA P4MA Motherboard
VIA P4V845 CHIPSET MOBO FOR iNTEL p4 CPU PROBLEMS
I HAVE A VIA P4V845 CHIPSET MOBO FOR INTEL p4 CPU WHICH IS EQUIPPED WITH 2 USB PORTS BUT NONE OF THESE CAN SUPPORT ANY UFS BOX BY SARARSSOFT NOR ANY KIND OF DEVICES SUCH AS USB CARD READER,USB DATA CABLES ETC. BUT THERE IS NO SUCH TROUBLE TO RUN PRINTERS, SCANNERS, OR MOUSE. PLZ GUIDE ME TO SOLVE THEPROBLEM.
  • Anonymous Jul 14, 2008
    thak you
    Brigadier General:
  • 6,966 Answers
Hi, USB issues - Probably the BIOS. Have you checked the BIOS version? VIA P4V845? Also I get the impression that P4V845 have 2 versions, SX & SM, that it is an Intel chipset based mb and not VIA and that it was probably by one of the OEM vendors for Pc Partner. In any case, should you want to flash/update your BIOS, this might be of help to you > http://www.wimsbios.com/phpBB2/topic8315-15.html Good luck and kind regards.
Posted on Aug 29, 2007
I am using P4v845sm mother board. I want mother board drivers. Please give me your valueble suggetions
Posted on Dec 15, 2010
I need motherboard drivers pls advise for solving the problem.
Posted on Jan 14, 2008
Which version of Award BIOS supports HT?
I suggest to visit the manufacturer's website. If manufacturer has changed BIOS or Update the BIOS, the patches or new BIOS will be available there.
Jan 25, 2016 | Intel Computers & Internet
Need specifications for Intel PM-865G1 mobo
Specifications
CPU
• Supports Intel® P4 Northwood/Prescott/P4 Extreme Edition processors.(PCB v1.1 only)
• FSB 400(Northwood only)/533/800MHz
• Supports up 3.2GHz and higher speed
Memory Speed/CPU FSB Support Matrix
FSB\Memory clock DDR266 DDR333 DDR400 800 MHz YES YES* YES 533 MHz YES YES NO 400 MHz YES NO NO
• Intel® 865G Chipset
- Supports 800/533/400MHz Intel NetBurst micro-architecture bus.
- Integrated graphic controller.
- Supports PC2100/PC2700 /PC3200 memory.
- Supports AGP 8X/4X at 0.8V (AGP 3.0) or 4X at 1.5V (not support 3.3V) interface.
• Intel® ICH5 Chipset
- AC'97 2.3 interface
- 8 USB 2.0/1.1 ports
- 2 channel Ultra ATA/100 Bus Master IDE controller
- SMBus 2.0 support
- 2 serial ATA Host Controllers
- Integrated LAN controller
• Support 100(Northwood only)/133/200MHz
• Support 400(Northwood only)/533/800MHz Intel NetBurst micro-architecture bus.
• Supports two 64-bit wide DDR data channels.
• Available bandwidth up to 3.2GB/s(DDR 400) for single-channel
mode and 6.4GB/s(DDR 400) for dual-channel mode.
• Supports four unbuffered DIMM of 2.5 Volt DDR SDRAM.
• Supports up to 4GB memory size without ECC.
• One AGP slot supports 8x/4x at 0.8V (AGP 3.0) or 4x at 1.5V (3.3V is not supported).
• Three PCI 2.2 32-bit Master PCI Bus slots.
- Supports 3.3v/5v PCI bus Interface.
• One CNR slot
• Dual Ultra DMA 66/100 IDE controllers integrated in ICH5
- Supports PIO, Bus Master operation modes.
- Can connect up to four Ultra ATA drives.
• Serial ATA/150 controller integrated in ICH5
- Up to 150MB/sec transfer speeds.
- Can connect up to two Serial ATA drives.
• AC'97 link controller integrated in ICH5
• 6 channels software audio codec C-Media 9739A
- Compliance with AC97 v2.2 Spec.
- Meet PC2001 audio performance requirement.
- Can support SPDIF Out via 3-pin SPDIF bracket only.
• Intel 82562EZ
- Integrated 10/100 Ethernet MAC and PHY in one chip
- Supports 10Mb/s and 100Mb/s auto-negotiation operation
- Compliant with PCI v2.2, and LAN on Motherboard (LOM) standard
Apr 27, 2010 | Intel Motherboard
Can i use 2.8ghz cpu for my p4s533-e?
this is what asus says:
arrow-org.gif Latest P4 CPU Support
The latest P4S533-E motherboard supports Socket 478 Intel® P4 processors, which utilize the most advanced 0.13um process technology to provide frequencies up to 2.53GHz
Mar 23, 2010 | ASUS P4S533-E Motherboard
Does msi motherboard P4M900M3 support this cpu Intel Celeron D CPU 3.20GHZ 512 Socket 775
MSI has two boards P4M900M3-F, P4M900M3-L.
Both of this will support your CPU
Nov 26, 2008 | MSI Computers & Internet
Trying 2 figure out what type of memory 2 use?
that looks like an Albatron MoBo but I cant get onto the albatron website to confirm this
Feature
AMD Athlon™/Athlon™XP/Duron™Processor
Socket 462 with FSB 200/266MHz
2 DDR266/200 Memory Sockets
6channel AC 97 Audio
2 ATA133 Channels, up to 4 ATA 133 IDE Devices
6 USB 2.0/1.1 Ports (4 ports by optional cable)
Integrated 3D Graphics Engine
Processor
Socket 462 AMD Athlon™/Athlon™XP/Duron™Processor
FSB / Transport
200/266MHz
Chipset
North Bridge: VIA KM266 ( VT8375 )
South Bridge: VIA VT8235
I/O Chip : Winbond W83697HF
Memory
2 * DDR sockets
DDR266/DDR200 unbuffered ECC/none-ECC DDR SDRAM up to 2GB
Expansion Slots
1 x AGP 4X slot (1.5V Only)
3 x PCI slots (PCI 2.2 compliant)
1 x CNR slot (AMR Type)
IDE / SATA Connectors
2 ATA133 channels, up to 4 ATA 133 IDE devices
Onboard I/O Connectors
1 x Floppy Connector
2 x USB 2.0/1.1 header (4 ports USB cable optional)
1 x CD_IN header
1 x COM (serial) port header (Optional COM cable)
1 x S/PDIF in/out header (S/PDIF in/out cable optional)
1 x CPU fan header with fan rotation detection function
1x System fan headers with fan rotation detection function
2 x 5 pin system panel header (Intel spec)
1 x Front audio header (Intel spec)
1 x IrDA header
1 x Case Open detection header
1 x Wake on LAN
I/O via Back Panel
PS/2 keyboard/mouse, 2 x USB(2.0/1.1),1xVGA ,1 x Com(serial), 1 x Parallel, 1x Game/Line-in/Line-out/MIC
Power
20-pin ATX power connector
BIOS Feature
2Mb Flash EEPROM
Award BIOS with ACPI, DMI2.0, PnP, WfM2.0, Green Suspend to RAM (S3), Suspend to Disk (S4) Wake on keyboard, Wake on LAN/RTC Timer
Hardware Monitoring
2 FAN sensors, CPU/System voltages and temperature monitoring.
Special Feature
Certifications
FCC, CE, BSMI,WHQL
Form Factor
Micro-ATX (218mm x 244mm)
Jul 11, 2008 | Intel Motherboard
Upgrade cpu
According to the product website your board supports all intel socket 478 cpu's. Maybe you bought a faulty cpu ?
M266A
  1. Socket 478 for Intel® P4 processor
  2. VIA® P4M266A chipset
  • FSB 533MHz
  • Supports Hyper-Threading Technology
  • Hybrid Booster - a safe overclocking feature
  • 2xDDR 266/200
  • Integrated ProSavage8 3D Graphic
Socket 478, Intel® Pentium 4 / Celeron
- FSB 533/400MHz
Jun 22, 2008 | Asrock M266A Motherboard
Foxconn Utility CD for motherboard Intel 915 series p/n: 91-185-915-MB-OM W A N T E D
Hi Witalorant,
I have searched the driver for your motherboard chipset and found one similar for the one you were looking at, i copy and paste the link here for you to download it and install it to your unit.
Click the link below and see what driver you need to download when the page loaded..
INTEL 915
Hope it helps.
Enjoy
Pls. rate & hope to hear more from you soon..
tnx
-micro
Feb 10, 2008 | Foxconn 915P7AC-8KS Motherboard
Asus P5GD1-FMS 775 Intel 915GExp. need help..
v i i i
P5GD1-FM specifications summary
(continued on the next page)
CPU
Chipset
Front Side Bus
Memory
Expansion slots
Storage
High Definition
Audio
LAN
USB
IEEE 1394
BIOS features
Rear panel
LGA775 socket for Intel® Pentium® 4/Celeron processor
Compatible with Intel® Performance Universal FMB 2005
processors
Supports Intel® Hyper-Threading Technology
Northbridge: Intel® 915P Memory and Controller Hub (MCH)
Southbridge: Intel® 82801FB ICH6
800/533 MHz
4 x 184-pin DIMM sockets support unbufferred non-ECC
400/333 MHz DDR memory modules
1 x PCI Express x16 slot for discrete graphics card
3 x PCI slots
Intel® ICH6 Southbridge supports:
- 2 x Ultra ATA 100/66/33 hard disk drives
- 4 x Serial ATA hard disk drives
Realtek® ALC861 8-channel CODEC with Jack-sensing
and Universal Audio Jack (UAJ®) technology
1 x Optical S/PDIF out port
Realtek® RTL8101L LAN controller
Supports up to 8 USB 2.0 ports
T1 controller supports:
- 2 x IEEE 1394a ports
4 MB FWH, AMI BIOS, Green, PnP, DMI2.0, WfM2.0,
ACPI 2.0a, SM BIOS 2.3
1 x Serial port
1 x IEEE 1394a port
1 x LAN (RJ-45) port
4 x USB 2.0 ports
8-channel audio ports
Nov 24, 2007 | Computers & Internet
VIA P4MA Motherboard Logo
1,233 people viewed this question
Top VIA Computers & Internet Experts
David
David
Abhinandan  Patil
Abhinandan Patil
jason
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
