Question about Hunter Televison & Video
Not receive satalite signal
There is no clicking sound coming from the fan when I press the remote control button. I already changed out the battery but that didn't work. the part number is 99600 fcc id#in2tx28 ic#3558a-tx28
3 Suggested Answers
  • 15 Answers
SOURCE: no connection between the fan remote and Ceiling fan
The remote-controlled fans that I've seen all have DIP switches in the transmitter (the "remote") and receiver (up by the fan). For the remote to operate the fan, both sets of switches have to be set to the same code. If you happened to bump the DIP switches (and change the code) while replacing the battery, the fan would no longer respond to the remote.
It's been four months since you posted this problem, so you've probably figured that out by now. Still, other users may run into the same problem occasionally.
Posted on Apr 17, 2008
ercupa190
  • 12223 Answers
SOURCE: Remotes suddenly stop working #85095-01, and FCC ID IN2TX13
1) clean the contacts batteries, with cleaner contacts
2) tight the spring contacts with pliers for better contacts
3) resolder the wires connector from contacts batteries
4) open the remote c, and clean the keypads with contacts cleaner
God bless you
Posted on Jul 03, 2012
Hunter Ceiling Fan Remote Works Sporadically
The part that receives the signal from the remote control is the receiver which is located in the motor housing.
Apr 29, 2017 | Hunter 27148 Remote Control
Older Model Hampton Bay Ceiling Fan: The Redington II w/Remote Control
sounds like the radio signal amp is blown..that is a full replacement deal..that would explain this, and the power
#glitch could certainly cause this problem..
Oct 26, 2008 | Hampton Bay 52 In. White Redington...
Cp9430r
Fixed Hunter ceiling fan with remote light pin out wiring 9 wire plug search words
Hunter Ceiling Fan with remote, fails to turn on light, fails to turn on fan..remote receiver is Cp9430r
1) Test your remote, Hunter uses Radio Frequency remote, point RF remote one inch from antenna of working AM radio, press each button on remote, each button will produce static sound from AM radio, if no sound..check battery wiring or solder connection on loop antenna of remote. If no sound on one or more buttons, disassemble and wash key pad with dish soap, rinse and fan dry, retest. If still one button no work apply graphite paint to button to rebuild conductivity of button.
2) Cp9430r receiver is below fan and above light. Remove light assembly, check receiver dip switches, mine was #5 On 1~4 Off, check remote control dip switches in 9v battery compartment also set #5 On 1~4 Off, new 9v battery still no Fan reversal "click" sound heard coming from the large Blue fan reversal relay located inside the Cp9430 receiver. All other buttons control transistors and will make no sound even if they are working.
3) Disassemble / unplug 9 wire plug from Cp9430r receiver, place receiver on wooden table, 9 wire plug has two empty pin squares, one empty in the center, the other empty we will call #1 ..counting clockwise #2,#3...#4,#5..#6,#7and finally top center next to empty #1 is #8. Now #8 is 110v hot/black ...& #4 neutral/white.
4) Shock Danger..carefully apply ac volts to pins #8,#4 use tape if needed, locate quad operational amplifier i call it radio receiver chip HA17324 on board, google HA17324 Datasheet, locate leg #14 it is across from leg #1. Locate small yellow ceramic capacitor very near leg #14, use capacitor's neg as neg for voltmeter, test volts at #1,#7,#8 and #14. My #1 was 3.1v, #7 3.2v, #8 3.25v and #14 .01v ...why #14 so low? I monitored each leg while pressing remote control buttons...no changes. **Desperate, I sparked (1/2 second or less) #14 with 3.14v from positive leg of yellow capacitor** and retested all legs, no change except now #14 rests at .02v and jumps to 2.5v~2.8v when any button on the remote is pressed then rests at .02v. Now Lights work, Fan speeds work, Reverse rotation Works :-)
Pin Out on 9 wire plug, #1 Empty pin, #2 Alternates w up/down fan rotation, #3 goes to 5uf fan capacitor other side of cap goes to white/neutral AC Line, #4 AC Line neutral, #5 goes to Triac? speeds? , #6 Alternates up/down fan rotation goes to up/dn blue relay, #7 goes to up/dn blue relay looks to be AC hot looking for fan probably paired with #3 changing sides at up/dn blue relay, #8 AC Line hot in. Why did **sparking** work, smarter people might know, i think a small spark got stuck in the chip and sparking helped the chip release it out. No electrical education, novice. Jer. 51 8,9 and 11
Feb 24, 2012 | Hunter (25417) Ceiling Fan
Lost my Dish network remote for the upstairs tv (LG) - which has NO box. Is there anyway to program my TV remote, so I can access the TV staions - turn on the network basically???????
No,the Dish Network satalite box signals require it own remote for it INFER RED INPUT and INFER RED OUTPUT signals.Call Dish Network customer service ask for a another original Dish Network remote.U pay $5 or $6 dollars a month for the satalite box as rental.They should wave the fee or charge u very little for a another remote.
Sep 05, 2011 | Universal Remote Control Dish Network...
Romote control is not working.there is a battery in it ,red light comes up but fan is not reponding.is there any way i can manually control the fan ,any button hided some where? or i can make sure remote...
normally in Hunter fans its not the controller but the receiver goes out, if your controller has a new battery and the receiver doesn't get the signal,, the fan isn't going to work, I've never been able to Locate Hunter receivers, tons of the remotes, you can contact them on line at this link
http://www.huntershoponline.com/cc_contactus.asp
Aug 26, 2011 | Hunter (25417) Ceiling Fan
Remote sensor on the APEX Digital LD4688 television does not appear to be working correctly. I have changed the batteries twince on the remote control that came with the television and have checked that...
The set is slow to respond but you must have a clear shot at the lower right corner of the set. That is where the signal is received. Our sofa cushiopn sometimes gets in the way and must be moved. When a signal is received the blue light comes on.
Nov 27, 2010 | Apex Digital Televison & Video
Battery good....remote light comes on....
Most Fan Remotes have to have the Battery compartment opened and the tiny rocker switches changed as well as the FAN receiver,could your child do that?.Try changing the Batteries.Good Luck.
Sep 11, 2009 | Universal Remote Control Hampton Bay...
The fan does not seem to be receiving the signal from the remote.
Unfortunately, if you have confirmed correct wiring, correct dip switches, and good battery, you either have a faulty reciever or remote. But before you remove the entire ceiling fan, take just the remote set back to home depot, they shouldn't have a problem swapping just the remote and receiver
Sep 06, 2009 | Hampton Bay 24002 Ceiling Fan
Hunter fan with remote control was 3 speed, now only 2 speed
It sounds like fan motor is okay. There are two motor windings -- one low speed, one medium speed. Low winding gives you low speed, medium winding gives you medium speed, both windings give you high speed -- so I would say if you get high speed, both windings are good.
The remote (the hand held transmitter) controls the speed by raising and lowering the frequency of the current which is 60 cycle coming to the fan ceiling box. If the fan speed -selector switch (usually a pull switch) is set to high, when the remote (transmitter) signals the receiver to change speeds, the frequency of the current is changed by the receiver (the receiver is usually in the fan housing).
Sounds like you'll need to replace the remote system -- these come in sets, both transmitter and receiver, and cost about $30. If you're not experienced with wiring fans, you should get an electrician to do the job.
Apr 21, 2009 | Hampton Bay 24002 Ceiling Fan
Televison & Video Logo
37 people viewed this question
Top Hunter Televison & Video Experts
pblo
Level 1 Expert
Paul Bade
Jim Goldsmith
Jim Goldsmith
Are you a Hunter Televison and Video Expert? Answer questions, earn points and help others
