Question about Vehicle Parts & Accessories
Palomino pop wiring diagram - Vehicle Parts & Accessories
I have power to palomino ss550 pop up it wont raise
check all safety switches,look at diagram in repair manual,down load manual off internet
Nov 21, 2016 | RVs
Owners manual for 2013 Solaire expandable
Cathy, You may have to contact the manufacturer for your manual.
Check the attached link, Good luck. "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Owner Manuals
http://www.rvzen.com/lp/mmy/palomino-puma-2012/manual.pdf
Palomino Contact Us
Jul 30, 2016 | Palomino 2013 SolAire Expandable 199 X
Puma trailer, Why is 2yr old Fridge not covered under warranty?
Contact the manufacturer of the fridge, perhaps their owner relations dept can assist you. If it's Dometic, go to : (www.dometicusa.com ) Have your model and serial number ready.
May 06, 2014 | Palomino RVs
Hooking up electric power from house to travel trailer
At yr breaker box if there is room add either a new 120v or 220 breaker and wire frm there. You need to check how much voltega and amp. Yr travel trailer needs. Plus how far away breaker box is frm trailer and get the correct size wire if needed. Make sure you have neut. And ground correct. Please doulble check. What iv offerd. For yr solution
Nov 17, 2013 | Palomino 2013 Puma 31-DBTS
Rear shock on my Klein palomino needs replacing. current rear shock is Fox Vanilla
from where did you purchase your bike maybe they still have the stock of the said model of yours
Aug 07, 2011 | Klein Palomino XX
Propane refrigerator?
Yes , when the refer needs to cool it will fire up only with the LP. In the electric selection it will work the same way. Do not fret , it is working ok.
Aug 31, 2009 | Rv Motorhome Dual Co & Lp Gas Alarm...
Worn wiring under my pop up's slideout
$1,000.00 is ridiculous. The wiring is likely color coded. You simply purchase insulated automotive wire and insulated barrel type crimp-on lugs. Cut out the damaged wire, and replace it with the new wire.
I provide a DIY service for $39 on my website. www.taeckertindustries.com
I provide email communication to help people do their own repairs or installations
Jul 08, 2009 | Rv Motorhome Dual Co & Lp Gas Alarm...
MANUAL--Used Palomino TXL Hard sided popcamper-- MANUAL
I have a manual for a 1998 TXL. I can make you a copy for a small fee
Jun 07, 2009 | Rv Motorhome Dual Co & Lp Gas Alarm...
Camper fridge will not cool down(unsure of model)
ok firstly if you remove the element and give it 110v does it warm up if it warm up and still not making the fridge cold the propane chemicals are not right any more
May 15, 2009 | Dometic WA3210 Compact Refrigerator
Vehicle Parts & Accessories Logo
18 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
