Question about Pool & Spa
Spa builders once i turn on the spa, the pump starts but the spa panel displays 1 .3 and then 9.- not sure what to do. Can you help me? Model LX-10 Product 3-70-1043 Thanks.
  • 7 Answers
SOURCE: No heat for the spa.
go to the heate and see if it tries to start and report back on any noises you hear or click or fans or is you smell gas
Posted on Jan 06, 2009
  • 64 Answers
SOURCE: Whisper Flo model WFE 6
Possible bad motor. You would need to test voltage at the motor connections with a multi meter. If the voltage is correct, then the motor or start capacitor is bad. If the proper voltage is not correct, then you would need to look upline in the electrical system to find the problem
Posted on May 20, 2010
  • 31 Answers
SOURCE: I have Jandy AquaLinkRS4 control
No. Sounds like you have software or electronic problems. You can have those boards rebuilt for $300 hundred dollars so if you need a new one, insist your technician send it in for a rebuild rather than replace it which will cost much more!
Posted on Apr 18, 2011
  • 111 Answers
SOURCE: New pump overheats
ICE is potential freeze condition warning. Should not relate to the pump issue.
Is your new motor same Amperage as old one?
Is the wet end(pump) on the new pump the same horse power as the one it replaced?
Lack of ventilation for the motor, or clogged motor vents.
Check for undersized wiring or poor electrical connections.
Check if your pump has a thermal overload, this safety mechanism will turn the motor off when it gets too hot. The pump should restart once it cools down.
Remove the intake plumbing and visually inspect the impeller, observe for impeller failure. Spin the impeller to see if it turns without impedance.
Before you inspect the pump turn of the power to avoid electrical shock!
Posted on Feb 20, 2012
  • 111 Answers
SOURCE: How do I unlock the control panel on my spa?
Here's a link to a list of ways to unlock the control: http://spapartsshop.blogspot.com/2012/02/spa-control-panel-unlock-codes.html
Those guys should be able to help.
Posted on Nov 28, 2012
Something seems to be wrong with my pump in my spa.
A loud, grinding, screaming, or screeching pump motor, will not show up on your Pumps Control Panel, with a fault code. Your bearings in the motor, are shot. And you will need to replace them, or the motor.
2nd possible problem - sorry : (
if nothing is displaying on your topside control panel, then your topside Control Panel appears to be bad, or the fuse that operates it has been blown. If there is a display in the readable part of the panel, but you have no access to make anything work, then you have some dead buttons, and once again you have a bad topside control panel.
Apr 11, 2015 | Intex Pool & Spa
I have a Marquis Spa with Balboa Ins. Pak. I can turn the power off and back on and then hit the pump button on the control panel. The pump and heater comes on and it run displaying the temp. After some...
FL must be an Error code. It should be in your owner's manual,
No Manual? Try MFG website. or
try manualslib.com
This power stuff is dangerous.
Mar 25, 2015 | Pool & Spa
Why does my pump want to shut off after I enable the heater?
before turning to spa dis able pool heat then try if same happens need new PCB control board
Jun 01, 2014 | Zodiac Jandy AquaLink RS All Button Wired...
My Jandy Link control panel model 8157 turns on spa by itsself. It is not programmed to do so. Its says low battery. Can thisbethe cause?
No. Make sure there are no programs for the spa. Double check this. I assume this is a pool/spa combination. If so, check the valve actuators at the pool equipment. Do this by manually turning on the pool with your Remote control unit. There should be no water disturbance in the spa. If so, your valve actuators need to be reset. There is a metal toggle switch on the back of each valve that you can switch to set the valves to pool or spa.
*********** board at the equipment may also be the culprit. Try resetting it by pressing the small recessed reset button on the front of the panel with the tip of a pencil or pen. If neither of these slove your problem you probably need a new mother board. They are very expensive. Check to see if yours is still under warranty. Your builder can tell you this or you can email or call Jandy with your model and serial number found on the back of the board. Good Luck
Apr 18, 2011 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Have miss placed the manual from pool builder, require another one plse
Suggest you either speak nicely to the pool builder or tell us what mke/model etc pump you have.
Jan 17, 2011 | Pool & Spa
I just bought an old spa from someone and the control panel is not turning on. It was rebuilt a while back and according to the original owner it was working, and when I drained it it appeared it was being...
If you are SURE there is correct power up to the spa pack you need to check to see that the topside control is plugged into the board.
if it is plugged in, it is either the 24volt transformer supplying the topside control, or the topside control is failed.
Did you hook up the hot tub?
Most common cause of topside complete failure is connecting to an improper power supply. This will immediately fry the transformer, and also maybe the topside control. It you are luck there would be a small 2 amp fuse next to the transformer.
If the whole board is without power, but you know power is going into it, it could be the main 50 amp fuse, which is usually white and about 1.25" long
Oct 28, 2010 | Pool & Spa
Panel reads HHO-----, no temperature display until activate jets, then shows a temperature drop sometimes down to 65 degrees ,then starts heating upwith jets going
"OH" is an overheat error. In normal function, it is used as a safety shut off if the spa water temperature reaches over 110 degrees in the event of a thermostat failure. But more commonly, (if the water temp hasn't gotten too hot) it indicates that the temp sensor(s) have failed. If you have a digital display on the topside controller of your spa, then it is a circuit board controlled spa pack. Most spa builders use the same control pack manufacturer - Balboa Watergroup. The sensor kit usually consists of 2 probes and wires that plug directly onto the circuit board. Depending on the spa, they could both be located onto the heater manifold, or one on the manifold and one mounted to the tub making direct contact with the water via a thru-wall sensor mount. If I knew the spa manufacturer, I could further assist you. If you replace the sensors, and encounter the same problem... then the circuit board is bad, and usually a costly replacement. The sensors are usually listed as a "BA sensor assy" Hope this helps you,
Dec 24, 2009 | Qca Spas Jewel Series Topaz Plus Hot Tub
How do I stop the spa from starting up and switching the heater on after a power cut?. Pump 1 will run the first time switched on,but if switched on again, it sometimes just stops and wont start for some...
It's not possible to stop the spa from starting up after a power loss. Most spas go through a self test then try to reach the last set temperature. Pump 1 usually runs the filter/heater, once it's activated it should run for 20min or until you turn it off. The high speed on pump 1 should always work. One problem with the pump may be that it's heating up and the internal high limit won't let it turn on. When you shut the pump off, the motor gets even hotter for a period of time since the fan is not turning, it may be getting hot enough to trip the internal high limit so that it won't turn on until the motor cools down. It won't turn on even if the topside control indicated that it should be on.
Dec 01, 2009 | Pool & Spa
Pool & Spa Logo
52 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
