Why does my Energy Knight a/c drip inside?
Could you tell me why or what to do to prevent my Energy Knight A/C (Model B-HMC24AS, Serial # 505KATMOOOO9) from intermittently dripping water on the inside of the unit-inside my home, onto the painted wall, over the electrical outlet and then onto the carpet. The company who sold it to us, charges a lot to "fix" it, which means gets it to stop dripping while he is there, and then leaves for it to only drip again with no reason. As you can imagine this is very frustrating, damaging and unsafe. Thanks for any suggestions you may have to offer. thanks dar
  • 1073 Answers
SOURCE: water leaking from inside of refrig.I think it could be Ice maker
defrost the freezer drain tube with a hair dryer
Posted on May 09, 2008
  • 230 Answers
SOURCE: DUO THERM Model 57915.622 runs and cools fine, but why does it drip water inside on the floor?
I am not en expert at RV A/C units. I have worked on a couple before. There should be a reservoir somewhere under the evaporator coil(looks kind of like a radiator in a car but much smaller). It should have a hose or something to drain it away from the a/c unit. These very often become plugged on any kind of A/C unit. However if you choose to do this on your own, you will have to climb on top of the RV and remove the cover from the a/c unit to do this. It might be safer to take it to an RV repair shop.
Posted on Jun 16, 2008
SOURCE: GE Zoneline PTAC Leaking
Hi Julie,
Is this a newly installed unit? The problem sounds like the sleeve is improperly installed. The sleeve should slope approximately 1/4 inch downward from inside to outside. This way the water will run to the back of the pan where it will be picked up by the slinger fan, or drain to the outside. Most likely this is the cause, not the styrofoam pan. If you need further info, you can contact me at greg.mcnary(at)airdistributors.com (replace (at) with @) and I can get you detailed installation instructions.
Greg McNary
Air Distributors Company, Inc.
Distributors of GE Zoneline PTAC Units and
McQuay PTAC Units
Posted on Aug 06, 2008
  • 8 Answers
SOURCE: Ice maker won't stop dripping
The ice maker can on hard water lime up to the point that the water will wick out a bit just after filling. The Ice maker needs to be cleaned or replaced.
ice
Posted on Jan 23, 2009
  • 2976 Answers
SOURCE: Air Conditioner in wall not window like hotel unit, leaks inside
Open the cover. In the bottom drip pan, there is a hole that is clogged. Just unplug it and it will drain.
Posted on Jul 07, 2009
Where can I get parts and a manual?
Hello Fred,
Here is the Manual. Just click on this link.
Good Luck,
JP
Heat Controller HMC09AS Service Manual
Jun 28, 2015 | Heating & Cooling
Energy knight wall ac unit wont turn on with remote? Model mss-012B
The only thing you can do that is not going to cost you a service call is to replace the remote and hop for the best.
Sep 08, 2013 | Heating & Cooling
I have a Goodman A/C unit model number AWUF36106BA and serial number 1010684384. It keeps shutting off on us and we have had a repair man come out and said the problem we had is the emergency shut off...
If the drip pan switch is shutting the unit down , this means you have a condensate drain issue. Be careful about wiring around any safety switch, especially if the furnace is in the attic or on a second floor. You could have water dripping on the ceiling. The drip pan switch is a safety switch. The best thing to do would be to inspect the furnace. The pan is underneath it. Look inside the pan if you can. If it is full of water, use a shop vac and vac the water out of the pan. If there is no water, you can locate the safety switch, take the two wires loose from it and just wire them together. Caution: This will be wiring around the condensate safety switch that could cause water to leak on the ceiling or floor depending where the furnace is. Don't go too long without getting someone out to clean the condensate drain out.
May 01, 2011 | Goodman CKL36AR36 Air Conditioner
White knight tumble dryer wont switch on (44a)model push the switch no click
hello check inside the door to see if the long pin hasn't snaped off this connects to the interlock that activates the motor if this is ok check the capacitor next to the motor this gives the motor a boost at switch on hope it helps
regards
shaun
Mar 12, 2011 | Abbaka White Knight 44AW Electric Dryer
What's the amperage on my Hotpoint Freezer? I want to calculate how much this unit is costing me in energy. Model number FV15CRB, serial number(?) AV 336553. Thanks!
Hi, to find out the total amperage of your unit, you should have a data plate most of the time, located inside with the compressor amperage, and both fan motor amps. If not inside, it will be outside of the unit. It will tell you the RLA and the FLA of each. It will also show the freon type and amount you use. Also, on top of your compressor is a plate that has the RLAmps on it also. This is what you need to find on this unit to help you on your calculations.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Jul 19, 2010 | Hotpoint Freezers
Energy Knight heat pump refuses to blow!
Does this problem happen when the temperature is below 30 degrees? When it gets about that cold outside, the air outside is too cold for the heat pump to "steal" heat from. On the thermostat you'll find a switch labeled aux or emergency heat. Turning this switch on will operate a traditional coil heater inside the system, providing you with heat. The only downfall to this is that it uses more energy to heat this way. Try turning the fan switch from "auto" to "on". If the fan comes on, then we can rule that out. If the aux heat switch is NOT on, set the thermostat such that the system will try to heat. If the outside unit is running, the problem is either it being too cold like I said earlier, or there's a problem with the heat pump's mechanical system that needs to be serviced by a professional. If the outside unit doesn't run but it should be, check it's breakers at the panel, the breaker inside the electrical box that feeds it, and look to see if there's a reset button on the unit itself. Finally, check the air handler (part of the system inside with the fan in it) to see if there's any circuit breakers or fuses on this unit. Make sure they're not tripped/blown. If none of this helps, you definitely want to get a pro to work on your system.
Feb 27, 2010 | Heating & Cooling
I have some problem with my AMANA BX20ML Model REFIGERATOR
You may have a bad condensor fan motor or paper may have gotten pulled under the fridge and jammed the fan blade. The energy switch will not help with cooling it only controls exterior moisture.
Feb 16, 2010 | Refrigerators
Energy Knight AC Blowing Fuses
My Energy Knight mini split air conditioner does not come on at all, no sound no lights nothing. I have changed the batteries with no luck. please help
May 28, 2009 | Comfort-Aire HMC24AD-1 Air Conditioner
Heating & Cooling Logo
60 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
