Question about Philips PM335 Remote Control
Rc 4301 01b - Philips PM335 Remote Control
I am wiring a Honeywell wifi unit and I used a separate 24v transformer and connected to the c and rc terminal. My system is ac and heat and uses both and rc and rh wire. I wired the rc to the r ter
A thermostat is a switch. It connects 24vac from one terminal to another depending on the request. The 24vac comes from a transformer, usually located in the furnace and connects to the R terminal. Since you are using RH and RC without a jumper between it means there are two transformers, one in the furnace for heating (RH) and one in the air conditioner condenser used for cooling (RC).
Your old thermostat was probably mechanical and did not have a C (24vac common) terminal. Your new thermostat requires power to operate therefore needs a wire connected to a C terminal. I would get rid of the transformer you added and look for an unused wire in the bunch at the thermostat. If it's there connect it to C on the thermostat and to C on the furnace. Remove any jumper from R to RC or from RH to RC depending on your thermostat and connect wires same as the old thermostat.
Jul 04, 2014 | Heating & Cooling
Tip
Known Mintek DVD Code Hacks
window.google_render_ad(); Mintek MDP-1010 / MDP-1020 / MDP-1030 / MDP-1070
  1. Press SETUP
  2. Go to "Preferences"
  3. Press 255 135 (or 225422)
  4. Press LEFT and DOWN quickly
  5. Current RC should be displayed
  6. Press the button for the desired RC (0 = codefree)
  7. Press SETUP
Mintek MDP-1060
  1. Press SETUP
  3. Press 253 135
  4. Press LEFT, DOWN, ENTER, SETUP quickly
  7. Press ENTER, SETUP
Mintek MDP-1720
  1. Press SETUP
  3. Press 215 345 (or 251251)
  7. Press (PLAY,) SETUP
Mintek MPD-1730 / MDP-1770
  1. Press SETUP
  3. Press 251 131
  7. Press SETUP
Mintek MDP-1750 / MDP-1810
  1. Press SETUP
  3. Press 251 345 (or 252315, 251251, 255135, 253135, 251251, 251422 / 212425)
  7. Press SETUP
Mintek MPD-1760 / MDP-1815
  1. Press SETUP
  3. Press 224 455
  7. Press SETUP
Mintek MDP-5860 / MDP-5861
  1. Press SETUP
  3. Press 222 443 (or 222443, 242112, 221441 [->MDP-5861], 224441, 245512)
  7. Press SETUP
Mintek MP 1710
  1. Open & close the disc tray
  2. Push SETUP on the remote control
  3. Push 1, 3, 6, 9
  4. Push the left menu arrow button 3 times -- NOT the |<< or << button
  5. Push the right menu arrow button 1 time -- NOT the >>| or >> button
  6. If you see a new menu item named "VERSION", enter that menu
  7. Change "REGION CODE" to 0
  8. Press SETUP
Mintek DTV-233 / DVA-8700 / DVD-1500 / DVD-1600 / DVD-1710 / DVD-2110 / DVD-2580 / DVD-3610 / DVD-5830 / DVD-8350 no known hacks
on May 29, 2009 | Mintek MDP-1770 Portable DVD Player
Need Manual for rc airplanes
The <a href="http://lightake.com/products.do/category.Wholesale_RC_Aeroplanes_Aircrafts-424">RC Airplanes</a> task process views for really wonderful. It through many useful information gather from here! I have like this site.
Oct 14, 2011 | RC Super Chipmunk 52 63'' Nitro Gas R/c Rc...
I bought rc helicopter of alloy king and i dont know how to make it start.
Insert the batteries into the battery slots in both the controller and the helicopter.now you will be able to control the rc helicopter whenever you want by just switching on the remote control for the device.
May 10, 2011 | Toys
My rc helicopter wont fly high?
flew at first hit sealing won,t fly now hit the trim button,s but still wont fly
May 13, 2010 | Radio Shack Indoor Micro Mosquito Rc...
Need codes for samsung dvd player
The sequence will depend on what region your machine is preset; Take a lok at the back of the DVDR and check. Once you know that use the codes bellow- Region codes for Samsung: RC 1: 2, 9, 3, 3, 4 RC 2: 3, 8, 7, 6, 7 (or 5, 7, 5, 3, 8) RC 3: 5, 6, 7, 3, 2 RC 4: 7, 6, 8, 8, 4 RC 5: 5, 3, 8, 1, 4 RC 6: 2, 4, 4, 6, 2 1)Power on your player with no disc in the tray 2)Press MENU for 5 seconds 3)Enter the corresponding combination for your current RC (see top) 4)Current RC should be displayed 5)Press the button for the desired RC (9=multi-region) 6)(Press OPEN)Power off your player ATTENCION: after step 3 the current RC appears for less than 2 seconds, be ready to press 9 (all regions)right after you press the combination. Tha press enter.
OR....
Go to www.samsung.com they have a lot of software downloads and paths that may help you
Aug 30, 2009 | Samsung DVD-R155
What does RC 1 mean
RC means REGION CODE - Depending on the numbering, it means that your DVD will only play in countries designated by the code.
Example
RC 1 means Region Code 1...... This disc will play in dvd players in Canada, United States, U.S Territories , Bermuda.
RC 2 = Western Europe, incl. United Kingdom, and Central Europe; Western Asia; including Iran, Israel and Turkey, Egypt; Japan, South Africa, Swaziland, Lesotho; French overseas territories
RC 3 = Southeast Asia; South Korea; Taiwan; Hong Kong; Macau
RC 4 = Mexico, Central and South America; Caribbean; Australia; New Zealand; Oceania;
RC 5 = Ukraine, Belarus, Russia, Continent of Africa, excluding Egypt, South Africa, Swaziland, and Lesotho; Central and South Asia, Mongolia, North Korea.
RC 6 = People's Republic of China, Hong Kong
RC 7 = Reserved for future use (found in use on protected screener copies of MPAA-related DVDs and "media copies" of pre-releases in Asia)
RC 8 = International venues such as aircraft, cruise ships, etc.[1]
RC ALL means all 8 flags are set and can play on ANY player
0 or no region means no flag is set can be played anywhere or flags 1-6.
I hope this helps.
Aug 24, 2009 | Sharp BDHP20U Blu-Ray Player
Philips MCD716
1.Press DVD "OPEN/CLOSE" key (RC (remote Control) or main unit) to open the DVD tray (note:if no disc on tray,then you have not to open it);
2.Press RC "SYSTEM" key to enter DVD system setup menu;
3.Press RC "direction "key to hightlight the forth item "PREFERENCE PAGE" (not entering the sub-item );
4.Press RC numeric key sequentially 811502(enter code, however no display on TV);
5.Press RC "down direction" or "up direction" key to change REGION CODE,"0" is all code.
6.Press RC "OK" key to confirm.
7.Press RC "SYSTEM" key to exit DVD system setup menu
Nov 23, 2008 | Televison & Video
Samsung dvd-r155 unlock region code
RC 1: 2, 9, 3, 3, 4
RC 3: 5, 6, 7, 3, 2
RC 4: 7, 6, 8, 8, 4
RC 5: 5, 3, 8, 1, 4
RC 6: 2, 4, 4, 6, 2
1.Turn on R155 without disc inserted
2. Press and hold Play and Stop for 5 seconds then release
3. Press menu
4. enter code for current region as above i.e if you have a region 4 type: 7, 6, 8, 8, 4
5. The region is displayed in the top right.
6. You have about 5 seconds to enter the new region (1,2,3,4,5,6 or 9 for multiregional)
Works just fine on my region 4 R155. Hope this helps.
Aug 03, 2008 | Televison & Video
Philips PM335 Remote Control Logo
23 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
