Question about HP Compaq Presario V2000 Notebook
"Hardware Failure" My wife woke me up the other day to say that her laptop was broken. She says she found it with a message that included the words "hardware failure" on-screen, and when she tried to restart it, it just freezes up. It shows the normal "Compaq" splash screen when first powered up, but the screen then goes dark with only a flashing cursor in the upper left. I got into BIOS and ran a hard disk check, which came back fine, but I cannot find any way to get it running again. I'm pretty good at taking apart desktops and finding physical problems, but laptops are outside my realm of past experience. I've found all the guides for disassembly and am pretty sure I can even get it back together again afterward, but I'm unwilling to start a project like that without some clue as to what I'm looking for. If anyone here has had a similar problem or just has an idea how to solve this one I'd really appreciate it, since this laptop was our plan for staying in touch while we're apart for the next month =0( Thank you all in advance -Jim
    Problem Solver:
  • 5 Answers
Hi,as you have said that the hard drive self test is working fine ,which means the hard disk is working fine ... Perform the following two steps to solve the hardware failure problems... 1.try to reset the RAM in the notebook .. 2).you can reset the hardware to the factory settings by removing the battery compartment and press the power button for 30 seconds , this will reset the hardware .
Posted on Aug 29, 2007
SOURCE:
Can someone help? My Gateway built-in webcam will not work.
If you did a factory reset ,and i wont work stll ,then you have a hardware failure
and is either a loose connection or a bad webcam that needs to be replaced ,cheap on ebay ,but then gain to be honest ,could be a lot things including a motheboard component ,
good luck
Dec 18, 2013 | Gateway Computers & Internet
Woke up and laptop was still running all lights on but no screen. Won't do anything
There are 2 Explanation
1- your windows is broken and must formet
2- your BIOS is broken
3- your laptop has just taken a kick so some hardware has broken
Dec 13, 2012 | Toshiba Computers & Internet
How do I download my videos and photos to my laptop from my phone
it no need a pc suite to transfer files
just connect your phone to computer using a provided cable data from your phone
go to setting menu on your phone
go to pc connection
pick mass storage
just ignore the message of found new hardware in your laptop
May 22, 2011 | Samsung Galaxy S GTI9000 Smartphone
What if my laptop is under warrant do i still pay
only if it is accidental damage, ie you have broken the screen or spilt coffee etc on it
if it is a hardware failure then your warranty will cover it at no expense to you
if you found this info useful please vote for me
Feb 26, 2011 | Computers & Internet
My laptop won't go into standby mode, it gets stuck and won't respond to commands
There are two reason for this error message
1 Hardware failure
2 Software failure(OS)
To eliminate hardware failure run the hardware diagnostics on the computer.. Use the link
http://findtechhelp12.blogspot.com/2010/12/how-to-run-dell-diagnostics.html
If all the hardware is working well then the issue is with the OS - reinstall it
http://findtechhelp12.blogspot.com/2010/11/how-to-reinstall-os-in-dell-computer.html
Dec 07, 2010 | Dell Inspiron 1525 Notebook
MEDIA TEST FAILURE AND OPERATING SYSTEM NOT FOUND ON GATEWAY 450 ROG. HOW CAN I SOLVE THIS PROBLEM?
The above error message displays your computer hardware gone bad.Please change the hard drive. It will resolve your issue.
Aug 09, 2010 | Gateway 450ROG Notebook
Laptop cant detect discs
Hi, Unfortunalty this is an hardware failure there is nothing you can do. If you are under warranty i suggest you to contact the reseller/manufacturer to get a replacement unit, it should be no problem at all this is a common issue. HDD,batteries,power adapter are the weakiest part of your system and generate the heaviest part of hardware failure on computers.
Thanks and have a nice day J -
Jun 09, 2010 | Computers & Internet
Reboot or repair harddisk
Please be a little more specific as to when you are recieving the error and word for word exactly what it says. Its hard to determine if it is a hardware or a software failure at this point. You could try booting off a windows xp disc, going into the recovery console and using the command chkdsk /p /r, it will try and locate bad sectors on the harddrive and fix them. I should let you know that harddrives are usually the first hardware component to fail in computers and have a life expectancy of 3-5 years.
Jul 12, 2009 | Compaq Presario CQ60-212US Notebook
Wharfedale MP3 player won't install to IBM Thinkpad
GO INTO CONTROL PANAL AND GO TO ADD NEW HARDWARE AND LET WIZARD DO IT JOB
Feb 12, 2009 | IBM ThinkPad T40 2373 Notebook
Viewsonic VG 2030 WM monitor went to sleep and never woke up again. Now has black screen with blue box and "No signal Analog" error message. Have tried restarting, unplugging, replugging, with...
this has nothing to do with monitor because its says no signal, meaning its working!!!
you need to be looking at the computer for possible hardware failures i.e. graphics card, memory and bios reset etc
best regards
Nov 17, 2008 | Computers & Internet
HP Compaq Presario V2000 Notebook Logo
60 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
