Question about Car Audio & Video
How do I remove the protect from my kdc-108
The radio doesn't work anymore it says protect on the front, its a kdc-108 can anybody help me?
SOURCE: Kenwood kdc-mp"635"------ protect "help"
I have a kenwood kdc-mp635 and when i turn on my radio it reads protect...i recently bought it a month ago and it was all fine till a couple of days ago i was driving and it turned off and said "protect"! i reseted it and it worked for like literlly a minute then back into protect mode.. i check all my wires, amps, grouds, cdplayer wiring and cant seem to find the problem... before when i reseted it, it worked for a minute then went into protect....now it doesnt even turn on anymore all it does is reads "protect" i reseted it and still nothing....it doesnt turn on after i checked all my wiring and grouds...im stuck and in-need of help..i have no musicccc.....no radioooo...!!! i dont know what else to do?????
Posted on Mar 03, 2008
kenw392
  • 2226 Answers
SOURCE: Kenwood KDC 241 SA car radio 'Protect'.
you could have a shorted speaker wire, a blown speaker; or the output ic in the deck itself could be bad.
Posted on Mar 03, 2010
SOURCE: I just bought a used car with a kenwood kdc-mp142.
Hey i had the same problem and i've just solved it you just gotta reset the radio the button it´s between the FF button and the 1 button gotta push it with one clip or something like that
Posted on Nov 13, 2010
kenw392
  • 2226 Answers
SOURCE: kenwood kdc-mp345u keeps flashing protect,
Chances are pretty good either the output ic or the volume control ic inside of the radio are bad. Both require the ability to use a soldering iron to replace.
Posted on Aug 04, 2011
  • 483 Answers
SOURCE: no power after Kenwood KDC-108 Install
check all power wire connections, and fuses on player, and underdash
Posted on Mar 23, 2013
Kenwood car steroe KDC-108 error 99 code, how to fix?
Try to press the reset button on Kenwood (It returns to factory
settings when the reset button is pressed)
Jan 17, 2015 | Kenwood KDC-108
Faceplate has not illumination
I'm not sure what you mean by extra red wire. Are you saying that there are two red wires? Generally most radios these days require two power sources. The yellow wire for most after market goes to a constant power source and the red wire goes to ignition or switched power source. Both wires need to be hot in order for the radio to work.
Mar 03, 2013 | Metra Ibr-whgm2 Wiring Harness For Most...
How do i get the security code for my kenwood kdc 108 car radio?
what if the faceplate doesn't light up but I can get the eject button for cds to work?
Sep 02, 2012 | Kenwood Car Audio & Video
Kenwood excelon kdc 994 protect mode
Try checking all of your speakers and speaker wires for shorts and/or grounds. If they all check out, try resetting the deck. If that doesn''t work, you may have a bad internal output ic.
May 06, 2012 | Car Audio & Video
Radio works but face plate shows nothing
You have two possibilities. You can try cleaning the contacts on the back of the radio and on the subpanel with qtips and rubbing alcohol or a pencil eraser. If that doesn't work, you may have bad solder connections on some surface mount resistors inside of the radio. If you are good at soldering they should be on the right front of the radio, you will have to remove the cd mechanism to get to them.
Mar 14, 2012 | Kenwood KDC-MP4028 CD Player
I bought a car with a KDC BT945U Audio Radio, but no manual. All it does is blink "Protect". It has a remote but pressing buttons on it doesn't change anything. Where can I get an...
The manul for the KDC-BT945U is available from Kenwood: http://www.kenwoodusa.com/Car_Entertainment/2010_Car_Entertainment/KDC-BT945U . Click on the Manuals tab. The direct link to the English version of the manual is http://manual.kenwood.com/files/4c3ba7ba66e53.pdf .
When Protect is blinking in the display, there is a short circuit in the speaker wire. Make sure that it is correctly installed and that the wire is not touching the chassis. Insulate the wire if needed. Then press the Reset button which is on the front of the main part of the unit (rotate the faceplate down) on the left side. (It's about where the source button is on the faceplate.) See page 70 of the manual for the wiring diagram and page 4 for a picture of the Reset button.
If the Protect message continues, you need to take it in to a service center.
I hope this helps.
Oct 08, 2011 | Kenwood Kdc-bt945u
My kdc-mp335 is on protect i need to know how to get it off
First check your speakers and speaker wires to make sure you have no shorts and/or grounds. If your speakers and speaker wires are fine, try pressing the reset switch if there is one. It should either be a pencil tip sized indentation somewhere on the face (it will not be marked) or behind a small hole on the subpanel behind the face. If there is no reset switch, you can reset it by disconnecting power to the radio for a few seconds. You can do this by disconnecting one of the battery cables if you can't get to the back of the radio. If that doesn't work you probably have a bad output ic.
Sep 29, 2011 | Kenwood KDC-MP335 CD Player
Security Code for Protect mode
Turn on the car so the radio is flashing "Protect." Look on the front / removable face of the stereo. On it you will find a small round hole - that's a reset button. Find a small paper clip, unfold the clip and stick it gently into the hole. The "Protect" will stop flashing, and Kenwood will be displayed. Unfortunately all your settings/presets will be gone, but at least the stereo is working again!
Apr 30, 2008 | Kenwood KDC-W3534A CD Player
Kenwood car stereo KDC-W3534 : warning message PROTECT
i had the same problem and i just disconnect the battery and and reconnect it and everything works fine!! try it
Dec 19, 2007 | Kenwood KSC-310CCS Center Channel Speaker...
Car Audio & Video Logo
26 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
