Question about Watches
Louis valentin watch 1277 water resistant 30m how do u change time bought in spain
2 Suggested Answers
SOURCE: How do I adjust my timex wr 30m watch stretch band?
It's very difficult. You have to take the decorative link covering off first, then continue with the actual stretch band by following these directions.
http://www.watchmaterial.com/How_to_size_a_watch_band.asp
Posted on Oct 18, 2009
How to set the time on timex WR30M watch?
hi Janet.
You may also need to change the time when traveling or to adjust for daylight saving time.
  1. What to Look For. Locate the MODE button, the SET/INDIGLO button and the START/STOP button on the side of your Timex Indiglo WR 30M.
  2. Setting the Hours. Press down the MODE button until "TIME" appears. ...
  3. Setting Minutes and Date
https://oureverydaylife.com/how-do-i-change-the-time-on-a-timex-indiglo-wr-30m-12421830.html
How to set the time on timex WR30M watch Google Search
Dec 13, 2017 | Timex Watches
How do you set a Aqualite field ranger (30M water resist) watch I seem to have ONLY military time
Usually, and yours may be different, but usually you are prompted with a choice of "12" or "24" hour time when setting the time. You wish to select 12. 24 is military timekeeping.
May 22, 2011 | Watches
I need to replace a battery in a Michele watch. Sometimes I am asked if I want the seal replaced which is expensive. DOn't i need that
Seals in water resistant timepieces go bad over time. This exposes the movement to moisture, dust, etc. which can damage your watch, costing expensive service or a new movement. If the watch is worn in the water often, the rule is to replace gaskets every 12 months. If it is occasionally worn in the water, they must be replaced every 18 to 24 months. The seals must be tested properly under the appropriate pressure for the rating of the watch by submerging the timepiece in a pressurized chamber. If your watchmaker is recommending this for a watch rated WR, water resistant, or 30M / 3 BAR don't bother. This should never be worn in the water. If it is for a higher rating (50M/100M+ 5BAR/10BAR+) and you wear it in the water, it may be worth the investment.
Jan 19, 2011 | Michele Watches
Watches T Touch Stainlesssteel case and bracelet sapphire crystal 30m water resistant men watch Watch for Men: I like it so much, ...
Link
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi Guest,
Please feel free to browse above link for the prices of your dream watch.
Thank you.
May 18, 2010 | Tissot T Touch Stainlesssteel Watch
Watches T Touch Stainlesssteel case and bracelet sapphire crystal 30m water resistant men watch Watch for Men: Very interesting sites., ...
Link
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi,
Please feel free to browse above link for your desired watches.
Thank you.
May 17, 2010 | Tissot T Touch Stainlesssteel Watch
Oil all over wrist watch - can it be cleaned?
hi, if the watch is water proof witch most watches are, if it is it should tell you something on the back like wr 30m or wr 10m if it says this on the back then this is telling you that the watch is water proof up to 10metres or what ever it says if this is the case then you can put it in the sink with only slightly warm soapy water then just rub it over gently with soft cloth whilst under water.
How ever if it says water resistent then this dont mean its water proof this just means its rain proof but not made for going under water unless it says water resistent to 30m then this can be washed in the sink also if it dont say this then you cant put it in the sink you can only wipe over it with a damp cloth to remove as much oil as possible.
But if you can get it clean and its not water proof then the watch is going to have to be taken apart to clean the outer casing that is only if the oil has not got inside the watch.
Oil wont short the watch out put it can cause problems if you have any buttons on the watch so your best bet would be taking it into a watch shop and get it cleaned that way.
Let me know how you get on or if you need further assistance ok
Jan 27, 2010 | Watches
Lost instructions to set my solo digital watch
I think I have the same watch and was just looking here to see if I could find how to stop the alarm going off every hour! However, I think I do know how to change the time: press the mode button three times (the first one brings up something like the stopwatch, the second brings up what may be an alarm time). On the third press you should get the time appearuing with the seconds flashing on the far right of the display. You can then change the second by pressing the"start" button. To change the minutes or hours, oress the "reset" button until they start flashing and use the start button again. pressing the reset button again will bring up the date to change. keep pressing until nothing is flashing any more and poress mode and it should bring you back to the current time. hope you can follow this and it works!
Jan 11, 2009 | Bulova Watch
How to stop chimes on Louis Valentin waterproof digital watch
Press and hold the lower right button to display the date, then press the lower left button. If now all the weekdays are turned off, the hourly signal is turned off too. If the weekdays are turned on by this operation, the signal is turned on.
Btw: does anybody have some information about the vendor of these watches?
Nov 12, 2008 | Bulova Watch
Acqua Indiglo water resistant watch with alarm 30m
Press and hold the MODE button (bottom left) for approximately 3 seconds.
When the Alarm set time starts flashing, press the MODE button once more. Now the seconds for the watch time should be flashing.
Use the START/STOP button (top right) to move bewteen items and the SPL/RESET button (bottom right) to change the item.
Moving between all items, it will take you through: seconds, minutes, hours, month, date, day of the week. Simply press MODE when your settings are complete.
Jul 25, 2008 | Watches
Watches Logo
107 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
