Question about Electronics - Others
Xantrex sw4548e shutdown
Fan has failed and the inverter shuts down, what is the solution
  • 4 Answers
SOURCE: Intermittent operation. Appears thermostat
No solution so far. But wanted to tell you that I'm having the same problem. I went through a lot of time, money and effort without success. Xantrex has abandoned me not responding to my e-mails anymore.
There could be a problem with the way it is (or not) grounded. I'm still experimenting.
I'm using a cheap $39.00 westmarine as a replacement. A bit noisy but so far much more reliable!
Richard
Posted on Feb 14, 2010
  • 4 Answers
SOURCE: Problem with Xantrex XS400 Sine Wave Inverter. I
What makes you think that the GFCI is faulty.
Are you getting a green inverter light on?
Richard
kel1guy2002
  • 3740 Answers
SOURCE: I got an error of ER 05. What does that mean?
Hi and welcome to FixYa, I am Kelly.
E05: Flashing Fault LED: Flashing Alarm: Beeping = Output on inverter is shortcircuit
- Disconnect your output terminals and see if you still have the code. This is telling you there is an external short.
- If you still have the error with the output terminals disconnected start looking for internal inverter shorts to the output connector. (Chaffed wire / hot wire signs / internal + lead ground)
- If you have Circuit Breakers / fuses on your output side open all the CB/s or remove all fuses then turn on the CB's / install fuses one at a time until you note the Er05 error. Then troubleshoot the shorted circuit with an Ohm Meter.
Thanks for choosing FixYa,
Kelly
Posted on Mar 19, 2011
SOURCE: Xantrex Prosine 1800i "DCDC Shutdown" when connecting AC Load
Hi
Did you find a fault or get it repaired as I have a very similar fault with a Statpower (Xantrex) Prosine 24v 1800i 230v inverter the only difference is that mine faults out with no load on it
Thanks
Posted on Aug 24, 2011
garymax2
SOURCE: Grundfos Pump On Xantrex Modified Sine Inverter?
SOME MOTORS HAVE TROUBLE, starting on Modified sine wave power. Grundfos is a high quality unit, you could try an other motor driven load to see how it is handled by your power supply.
Posted on Nov 18, 2012
Still need answer abouy my xantrex inverter showing fault reading fo2 n beeping
E-02 Inverter low DC/Battery voltage shutdown Battery voltage has dropped below 10 VDC for 12-volt units or 20 VDC for 24-volt units.
Mar 13, 2015 | Inverter Electronics - Others
Tip
Xantrex inverter error codes
This information expands upon the error code information contained in the Link 2000 Owner?s Manual.
E-01 Inverter high DC/Battery voltage shutdown Battery voltage has risen above 15.5 VDC for 12-volt models or 31 VDC for 24-volt models.
E-03 Inverter or Charger overtemp shutdown Unit will reset automatically after it has cooled sufficiently.
E-04 Battery overload Caused by excessively discharged batteries. See section in inverter owner?s manual titled ?Charging overdischarged batteries.?
E-05 AC Backfeed AC power from an outside source has been fed to the AC output of the inverter. Potentially damaging to the unit. Disconnect incoming AC power and correct the situation.
E-06 Electronic Overload Inverter overload caused by too large a load or a short circuit. Reset by cycling power switch or connecting incoming AC power.
E-07 Triac control error Triac has overheated. Shut down unit and allow to cool.
E-08 High battery voltage shutdown during charge mode Check all charging sources for proper voltage. Reset by cycling the power switch.
E-09 Spare
E-10 Link 2000 de-powered This indicates that power was removed and restored to the Link 2000.
E-11 Spare
E-12 Battery #1 voltage sense leads open Blue wire is not connected to battery #1.
E-13 Battery #2 voltage sense leads open Violet wire is not connected to battery #2. E-14 Inappropriate Charged V selected for sensed voltage This value defaults to 13.2 for a 12-volt system, 26.4 for a 24-volt system. If this setting is above the voltage limits of the charging source, this error code will be displayed. Please refer to page 9 of the Link 2000 Owner?s Manual
E-15 Incoming AC polarity reversed Check incoming AC wiring for a reverse polarity condition.
CCC Indicates battery being charged. Displayed when Time remaining is selected. LO BAT More than 50% of declared capacity of battery 1 or battery 3 has been consumed.
OL Meter reading out of range U xx Designates a user setup CEF. Please read the sections pertaining to CEF on pages 19?22. A Designates Alternator output current on a Link 2000-R. is a number from 1?200. P Indicates Percent of charge mode selected. is a number from 1?100.
on May 14, 2015 | Xantrex Technology Electronics - Others
Xantrex inverter/ charger smells like burning electrical
I would call or e-mail the manufacturer of the inverter. The dealer or dealers may know the issue but likely the manufacturer will be more help.
Some devices like an inverter will have a smell in the beginning, power supplies are like that. You said that the inverter didn't get hot but smell indicates something is hot.
Apr 13, 2017 | Xantrex Electronics - Others
Xantrex sw4548e
Define the issue better
May 14, 2013 | Electronics - Others
Hi Schnupfy,
Well, it may be advertised as 1800 watts, but that is a peak. While the 230 VAC may be dead on target, don't expect it to run a mig welder.
Sustained high output is totally dependent upon the power source. What it's doing is protecting itself. DCDC Shutdown indicated 'An overload or system Fault'
Possible problems that would cause this:
  • The load is too high (what is the load?)
  • The power source is intermittent or weak
  • The power source is run through a distribution panel or isolator (Voltage drop)
  • The wiring from the 12VDC source is too long for the gauge used
Click here for a PDF copy of the manual. It is quite well documented.
BEST REGARDS,
MIKE
Dec 18, 2009 | Xantrex Technology Xantrex Xantrex Prosine...
My prosine 2.5 charger inverter intermittent
First try blowing it out the unit with compressed air to see if there is large amounts of accumulated dirt inside, look for black soot on the center of the air outlet side.
Intermittent problems are the hardest to troubleshoot.
If you need more help contact me at sunyout@gmail.com
Thanks.
Sep 14, 2009 | Xantrex Technology XANTREX PROSINE 1800...
Richard
Jul 24, 2009 | Xantrex Technology RS400 Sine Wave...
Electronics - Others Logo
24 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
