Question about Sewing Machines
Babylock BL4-428 repair manual
Upper blade broke when I started to sew after machine was unused for only a few months. I had used it regularly for about 3-4 years then stored a few months. Before that it had been stored for probably nearly a decade and worked like a charm right away. repair person said that the lower blade was not in position by maybe 1/8 inch, and it could not be fixed. seems odd to me, would love to get it back to working again, don't like to throw things out. any fix ideas or manual available? thanks!!
SOURCE: machine jams after a few stitches
Take a few stitches and look for where the thread is hanging as the loop slides over the bobbin case. If there is a rough spot causing it to hang, smooth it out with very fine steel wool make certain to remove all remains of the steel wool when you are finished. If the thread is catching between the bobbin case and some other surface, the clearance between the surfaces needs to be set and you should take it to a qualified repairman.
Posted on Dec 10, 2007
  • 298 Answers
Have you changed the needle lately
akylas
  • 26 Answers
SOURCE: Top tread bird nesting.
When you say top thread nesting, I supose you mean that the thread is messed up at the top of the needle plate.
If so,
1st, either your bobbin thread is completely loose, or the bobbin thread is not held under the bobbin case spring,
or lint has been accumulated under the bobbin case spring.
2nd, the top thread is very tight,
or both.
Posted on Jun 11, 2008
  • 32 Answers
SOURCE: Elna Pro 5DC Serger
Sound to me you should get it serviced. Your timing is off. It also could be your needle make sure you use serger needles
Posted on Aug 08, 2009
  • 30 Answers
SOURCE: Babylock Serger loosing power
Your problem is probably the stitch length adjustment cam (located on the left side of the machine) To fix this problem you will need to remove the small plastic cap (with red arrow) covering the screw securing the cam. It is usually also necessary to remove the connecting rod/sleeve that the cam rides in. Once both of these parts have been removed, you will need to carefully separate them and resurface the inside of the sleeve. This can be done with a very fine (500grit or higher) emery paper. Once the cam fits inside the sleeve without binding, reassemble using sewing machine oil or lithium grease and adjust feed dog timing.
Posted on May 17, 2011
How do I oil my babylock serger
That depends on the model. The Babylock Triumph (BLETS8) does not get oiled by the user. However, the Babylock Diana (BL480A) needs to be oiled at 4 different points. See the picture on page 63 (page 64 of the PDF) of the manual. Babylock has the manual here: https://babylock.com/resources/5148/download . Current Babylock sewing machine and serger model manuals are available here: https://babylock.com/support/machine-support .
Please add a comment with your serger model. I'll try to find the oiling diagram, if the machine needs regular lubrication. Do not oil any sewing/serger machine unless the manual recommends that as part of the maintenance of the machine. Some Babylock sewing machine dealers will provide you with the manual, if it is available for a small fee. The Babylock serger that I have access to didn't come with a manual. However, we were able to get one from the dealer.
I hope this helps.
Apr 03, 2018 | Sewing Machines
I need owners instruction manual for baby lock companion 1550 sewing machine.pls help where can i download free manual.
You can check with a Baby Lock dealer an online sewing machine parts vendor, or even eBay. However, it may be difficult to find a manual for your machine due to its age and perhaps even less chance of success for finding a free manual.
Baby Lock Manuals
http://www.sewingpartsonline.com/babylock-sewing-machine-instruction-manuals.aspx
Babylock Sewing Machine Manuals Instruction and Repair Manuals
Babylock Sewing Machine Manual PDF and CD
Nov 27, 2016 | Baby Lock Sewing Machines
Hi. Do somebody know the part number of lower looper holder I bought the ea 605 babylock and do not have it. Thanks for help.
If you need a replacement blade, they can be found on many internet web sites:
Baby Lock Serger Blades Knives
If you need a part that holds the knife, you could probably contact or go to a sewing repair shop or a Babylock dealer.
Jul 01, 2016 | Sewing Machines
Babylock BL4-428 Serger
I think I would get another opinion. Sometimes you run across lazy technicians or those who would like to talk you into buying a new machine. Of course, if your machine is older, it could be difficult to locate replacement parts, but getting that info from another technician will confirm the first opinion.
Nov 18, 2017 | Janome MyLock 634D Mechanical Sewing...
How to replace the upper cutter on the baby lock? which screws to release the old blade?
I also have a babylock eclipse BLE1DX serger & here's how my book says to do it
to replace the upper cutting blade
1.open the front panel
2.remove the screw holding the upper blade
remove the upper blade
3.position the new blade in the blade slot, replace the screw.as you tighten the screw, hold the blade up in it's highest position
4.close blade cover. close front cover
hope this helps you
good luck
Sep 12, 2011 | Baby Lock Eclipse Serger
If my machine is not cutting right do I need to replace both blades
not necesarily, can you see a knick in either of the two blades? use a magnifying glass and see if you can see any damage first.
Then try changing the fixed bottom blade only first, you may have got a replacment top blade in your accessory bag new with the machine.
The blades themselves are very high grade steel just like scissor blade so should last for quite a long time, provided they don't come into contact with a pin.
You can buy the bottom blade for your machine here http://www.sewingpartsonline.com/lower-knife-babylock-60544.aspx along with the top blade and other spares.
Also, remember to clean the blades of lint regularly and give them a wipe with a cloth moistened with a little clear sewing machine oil from time to time.
Jul 06, 2011 | Simplicity Serge Pro SW432 Mechanical...
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
