Question about Cycling
New balance 10k 5500 upright bike
9v power
I need to install a 9v battery in my Kenmore Elite upright freezer and I don't know where the battery compartment is.
Please expalin to me what this battery powers, i have been a appliance repair technician for over 30 years and have NEVER seen a battery used to power any component, i know manufactures come out with new stuff all the time so i would like to know what this battery does
Jul 23, 2011 | Kenmore 20.6 cu. ft. Upright Freezer 24092
CAN I PUT TRAINING WHEELS ON THIS BIKE FOR MY SON?
kdmouse81, The simple, literal answer is yes, because you can put training wheels on anything. But you probably want to know if they are readily available. No, they aren't. This is a bad, dangerous idea. For his own safety, he should learn how to balance a manual bike before he tries to ride a powered bike. If he has a disability that prevents him from riding a manual bike, I suggest helping him to ride this razor (or a manual bike) by holding it upright for him and trotting along with him. When he can balance well enough, turn on the power.
Dec 07, 2010 | Razor MX350 DIRT ROCKET - BLUE
Is there a certain brand or weight of oil I should be using in my 06 sporster 1200 custom?
20w/50 synthetic
04-up is 3 qts.
Drain oil hot, r&r filter, put in oil,........let a couple ounces drain out of the hose to bleed the air out to prevent cavitation inside the oil pump.... run engine about 10 minutes, shut off & let sit for about 2 minutes. Check oil level with bike upright, oil should be at top mark on dipstick, fill as needed.
Don't forget about the Primary Oil...1 qt.
Also remember, there is WAY more to maintaining your bike than just an oil change, belt tension, throttle cable lube and adjustment, clutch adjustment, clutch cable lube and adjustment, primary chain adjustment, brake inpsection, tire pressures, fork oil every 10k miles, steering neck bearing lube and adjustment every 10k miles, etc.
May 27, 2010 | 2006 Harley Davidson XL 1200 C Sportster...
Vibration at 5500 RPM
Is this when you are riding? If so check tire balance. If not, make sure your motor mounts are good and tightened to the correct torque
May 16, 2010 | 2005 Hyosung GT 250
99 gsxr 750 losing power after 10k rpm if you have
The carburetor jets, there are 3 bands; A low, mid range and high range rpms. 10k would fall in the Mid range power. I would let the bike warm up a little bit and tweak the middle knob on the left side of the bike and keep in mind you need the right mixture so turn it quarter turn one way at a time per testing the mid range rpms while riding, tweaking 1/4 turns in between tests. If it gets worse, turn it the other direction until you find that sweet spot in the mixture of fuel/oxygen. The carburetor jets, there are 3 bands; A low, mid range and high range rpms. 10k would fall in the Mid range power. I would let the bike warm up a little bit and tweak the middle knob on the left side of the bike and keep in mind you need the right mixture so turn it quarter turn one way at a time per testing the mid range rpms while riding, tweaking 1/4 turns in between tests. If it gets worse, turn it the other direction until you find that sweet spot in the mixture of fuel/oxygen. The carburetor jets, there are 3 bands; A low, mid range and high range rpms. 10k would fall in the Mid range power. I would let the bike warm up a little bit and tweak the middle knob on the left side of the bike and keep in mind you need the right mixture so turn it quarter turn one way at a time per testing the mid range rpms while riding, tweaking 1/4 turns in between tests. If it gets worse, turn it the other direction until you find that sweet spot in the mixture of fuel/oxygen.
Mar 07, 2010 | 2007 Suzuki GSX-R 600
What type of ac adaptor do i need to a proform gl 125 interactive trainer
Hi
Mine says on back - Plug in class 2 Transfromer -
Input:AC 120v - 60 Hz 150mA Output:DC 9V -1A
Hope this helps
Dixie
Feb 21, 2010 | Proform GT 85 x Upright Bike at GNC
Computer Speaker , Logietech Z 5500 best price
Hello, unfortunately it wont work unless you get a transformer also for to change the 110 to 230V or a different power supply to suite it. Going byt he weight, shipping and messing around with new transformer, i think you might be better of just getting the one you knows will work and have warranty on???
Best of luck Ganx
Jul 14, 2009 | Audio Players & Recorders
Can't get any power running on my 5500 hr life cycle
You have to start pedaling to get it to start up, some times you have to pedal pretty fast to get it to start up
May 27, 2009 | Life Fitness 9500RHRT Recumbent Bike
Change the battery. It is a 9v battery behind the small door on the back of the display panel.
Mar 15, 2009 | Life Fitness 9500RHRT Recumbent Bike
Cycling Logo
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
