Question about Kenmore Refrigerators
Refrigerator Ice bucket #363-9504785 what part does the stirrup solenoid oem fits into off wall two pins fit into plastic square w/pin slotted it carry 2 screws the solenoid # is AP2064215 Thanks
My email Serluck1@aol.com
SOURCE: refrigerator model 106 57404600 the
whirlpool ref???
Posted on May 10, 2008
Illeagle
  • 525 Answers
SOURCE: replacement ice maker
Sounds like you may have gotten a wrong kit, or a mislabled kit. Take it back and ask the salesperson to correct the error. Ask them for some advice if they try to say it is the right one. They made a profit on the sale so they need to make it right with you.
If you get nowhere, which is likely to happen, post me back and I can help you come down legal on them.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 19, 2008
  • 111 Answers
SOURCE: GE GSS25LGM Ice maker not dispensing ice
You have one of three things wrong. The auger motor is frozen up, the ice bucket is broken or you need to dump out any ice, run warm water through the entire ice bucket, dry it out and try again with fresh cubes. My guess is the auger motor is frozen. You can buy a vinyl boot that covers the auger motor to prevent moisture buildup and freezing from GE Parts at 1-800-626-2002
Posted on Dec 16, 2008
SOURCE: Whirlpool Refrigerator Shelf falling off support pins regularly
I got a new refrigerator that has the same problem. I solved it by cutting a triangular pencil grip for children's pencils down so they extend out just past the pegs on both sides (making them longer). The grips fit on snug, just like on a pencil, you don't have to screw the shelves in permanently which allows them to be taken off and moved. Works like a charm and holds the shelves in very snug.
PAM
Posted on Apr 05, 2009
SOURCE: pin hole in 1/4" copper tubing feeding refrigerator
i have a lil hole in the lower panel seperating the fridge frm the freezer, what do i use to fill it up nd stop the gas leaking out
Posted on Aug 19, 2009
My shaved ice won't work on my Kenmore Elite but all other options do
Be sure the metal bar under the ice bucket is fed into the 'stirrup' at the back of the freezer, if it is in place, hold the freezer light switch down while the door is open, and press the ice dispense paddle to observe auger operation and see if the 'stirrup' is pulled upward by the solenoid that operates it... Crushed Cubed Ice Solenoid WR62X23154
May 23, 2016 | Kenmore Refrigerators
Amana side by side ice maker quit. verified water
Hi andy and wlecome to Fixya. There is usually a semi white plastic line that runs up the back of your refrigerator. Here are some steps you can do to verify that the water valve is actually working
You will need an old power cord or cheap extension cord with 2 female bayonet terminals on it. (Make one if you have to.)
1. Unplug the unit.
2. gain access to the water valve and disconnect the wire terminals 2 ea from the solenoid.
3. Connect the cord you made to the solenoid making sure that the 2 terminal connections will not come off or touch together.
4. Get a bucket and gently pull the plastic line from the bulkhead connector in the upper area of the back of your unit and place it in a bucket.
5. Plug the cord into the wall outlet and HOPE that water flows into the bucket.
If the water does NOT flow then the water valve is clogged and will need cleaned or replaced. Many of these water valves have a hose type inlet connector fitting from the water SOURCE. Before attempting to remove any water lines turn the water source OFF. That fitting can be removed and you can check for a clogged screen.
Just remember to remove your test cord and re-connect the chassis harness to the solenoid when your done. Also put the plastic line on the back of the unit back into the bulkhead connector.
If you have water flow thru the line then the bulkhead connector fitting to the icemaker is froze up and you can thaw that out with a hair dryer (quickly) or a fan (Slower) with the unit unplugged.
This should give you some direction on what to do. Best of luck!
Jan 25, 2010 | Refrigerators
LG ice maker only dispenses crushed ice not whole cubes
Very problematic issue with this model .Try unplugging and plugging the fridgerator which resets the board.The board is located on top under a removeable panel where the power cord enters....there is a reset/diagnostic button on the board itself.Contact LGUSA.com for any possible warranty and complain like crazy to avoid spending $300 on this board which can be purchased from andrewselectronics.com who is a factory authorized parts provider.Keeping that ice maker going will make you pull your hair out which is unfortuante for such a stylish and expensive fridge.good luck
Jun 28, 2009 | LG LSC26905TT Side by Side Refrigerator
Ice in bucket freezes into a lump, mechanism freezes
it sounds like the ice chute door is stuck open. on this model it can slip off the "hinge pin" or the plastic that holds the pin can break. if the flap is broken it is replacable. the pin can be put back in. if the plastic that holds the pin is broken, you need to replace the whole door. expect to wait 6-8 weeks for a new door, sooner if lucky. cost is $400 +++ more for stainless.I hope the pin fell out. hope this helps
Jun 16, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Switch on ice maker not changing from crush ice to cube
on your ice bucket there is probably a bent thin metal bar that extends to the back of your refrigerator. if you remove the bin you will see a white plastic square hanging just behind the metal rear panel. Hold your light switch(s) closed while looking at the plastic square ahnger then give your refrigerator a "reach around" and cycle the ice dispenser in both the crushed and the cube settings. in one of the settings the square should move. if it does not.... try putting a blow dryer in front of the small square opening for about 10 minutes on high heat and repeat the process. if it still dosent move order a auger solenoid. 888-995-9956 is our number for parts (mod/ser. numbers required.) the blow dryer will probably solve the problem.
May 22, 2009 | Hotpoint Refrigerators
WE HAVE A GE REFRIGERATOR THAT IS ONE YR OLD AND IT WILL NOT CRUSH ICE. WE'VE REPLACED THE ICE MAKER AND IT STILL WILL NOT CRUSH. IS THE SOLENOID OUT BEHIND THE ICEMAKER ARM IN THE FRIG WALL? GE MODEL...
You may be on the right track. Remove the ice bucket and check the square hole behind the ice bucket in the back wall of the freezer. You should be able to move the horizontal rod in it up and down with your finger. If not, it may be frozen in one position. If so, just warm the area a bit with a hair dryer to free it. Replace ice bucket and test. Another thing which may cause that is the ice auger itself may have separated from the drive shaft. (The icemaker itself has nothing to do with making "crushed" ice. It only makes cubes. The cubes are dispensed or crushed and dispensed at the front of the ice bucket using the auger and the metal parts there.) You might also want to verify that the long metal rod (which extends past the ice bucket and into that square hole) is able to move. (it is spring loaded)
Feb 03, 2009 | Refrigerators
Ice dispenser
The solenoid that controls the blades on the ice bucket is either froze up or defective. Remove the ice bucket and use a hair dryer on the back wall of the freezer where the bar on the ice bucket would go into the back wall. That plastic square in that hole should line up with the hole. Not be up inside the hole. Use the hair dryer on the back wall just above the hole with the plastic square inside it. The solenoid behind that wall is what controls the cubed and crushed ice. If that doesn't fix your problem replace the solenoid, Part Number 5304404333.
Let me Know how you Make out with your repair.
Thank you,
Bill
Apr 14, 2008 | Frigidaire FRS-26DR7D Side by Side...
Ice crusher has stopped crushing
There is a little bar that is on the ice bucket. That bar has to go into the middle of the plastic square that is on the back wall of the freezer. Try Pulling out the ice bucket, get a hair dryer and run the hair dryer on the back wall of the freezer right above the hole where that little bar goes. After you run the hair dryer for about 10 minutes or so put your finger in the hole and pull down on the plastic square. Make sure when you put the ice bucket back in the freezer, the bar goes inside the square hole, not under it, not over it. In it. If that doesn't fix the problem you probably just need a new solenoid. Part number 5304404333
Let me know how you make out. Good Luck
Bill
Jan 13, 2008 | Frigidaire FRS-26DR7D Side by Side...
Ice dispenser
On the bottom of the ice bucket it has a metal rod that fits into a square hole in the back of the freezer.  Behind that square hole is a solenoid that actuates the rod on the bucket.  Take the bucket out, shut the door and press for ice.  If you hear a loud clunk noise then that is the solenoid moving up and down.  If you don't hear that noise then replace the solenoid.  Sometimes when the bucket gets taken out and put back in the rod is underneath that solenoid and doesn't let it actuate the rod.  If you find the solenoid is working make sure the solenoid is in the down position then put the bucket back in.  Let me know what you find.
Oct 16, 2007 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
14 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
