Question about Electrical Supplies
Powermate coleman proforce 3125 watt portable generator manual
SOURCE: oil type and capacity
Use 10/30 weight oil fill till : " if it has a "dipstick" fill to middle of hash marks" if not, There in the hole for the oil filler cap their is a knotch cut out of the theads for that cap. fill to just below the top of that knotch . drain plug on bottom of crankcase
Posted on Sep 01, 2008
  • 13 Answers
SOURCE: Powermate PM0535000-01 Manual
powermate went out of business , but this might help let me know http://www.powermate.com/contact.php
Posted on Sep 27, 2008
  • 252 Answers
SOURCE: need manual for my Coleman Powermate generator
Get model number and go to: http://www.powermate.com/productmanuals.php?cat_id=3
Posted on Mar 11, 2009
protek480
  • 1723 Answers
SOURCE: My coleman powermate generator will start but will not generate.
The voltage regulator controls the output. You will need to check that first.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Aug 01, 2009
  • 905 Answers
SOURCE: Coleman Generator not Making Power
actually, it sounds like the diodes are blown. Check our diodes.
As for checking stator, find the two wires, typically labeled L1 and L2 that are going to it. Measure with a multimeter. If there is no visual signs of damage, continuity can indicate a good stator. You should not have continuity between either wire and the stator frame.
The same goes for the rotor as well. The resistance measurements will not be the same for each one though.
Unfortunately, Powermate is out of business, and service information is scarce.
Posted on Aug 25, 2009
Coleman Powermate 6750
You will need to check the resisitance of the stator and rotor windings, and also each rotor/ring to ground (IE rotor shaft) All tests to ground should be 0 M ohms, stators vary but typically around 1ohm or so, and rotors approx 20-30ohms
Nov 20, 2013 | Coleman Powermate Proforce 6,000 Watt 12...
What size of spark plug do i need for powermate pm0301010
Champion RN14YC, Gap is 0.28/0.31
This is per the owners manual for your specific machine. Hope this helps.
Aug 26, 2010 | Coleman Powermate Proforce 6,000 Watt 12...
PF 2500 watt generator... Need plug and oil
30wt oil, probably a Champion RN4C plug. Could give link to a manual if part / model number of generator was provided.
May 17, 2010 | Coleman Powermate Proforce 6,000 Watt 12...
Is it Honda the engine or the generator Proforce
Coleman usually uses Briggs& Stratton engine
Jul 07, 2009 | Coleman Powermate Proforce 6,000 Watt 12...
Spark Plug location for Powermate Proforce Generator #PM0102500?
Hi
Try to see where is the had of the engine.
best regards savumihai71
Dec 22, 2008 | Coleman Powermate Proforce 6,000 Watt 12...
Technical Question
A: Running watts are the continuous watts needed to keep items running. Starting watts, are extra watts needed for two or three seconds to start motor-driven products like a refrigerator or AC unit.
Aug 27, 2008 | Coleman Powermate Proforce 6,000 Watt 12...
Electrical Supplies Logo
374 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
