Am-06 5/6 rpm cw/ccw 50/60 hz 4w - Washing Machines
5 Suggested Answers
catriver
  • 878 Answers
SOURCE: removing tub
counter clockwise. Catriver
Posted on Sep 20, 2007
aasc
  • 1606 Answers
SOURCE: Which way does the spanner nut turn..CW or CCW?
CCW to remove , CW to tighten .
Posted on Sep 20, 2009
SOURCE: will not spin fast, only goes cw and ccw at medium
I took the stainless steel basket out and found the aluminum spider to be rotted. The basket was dragging and that made the motor overload.
I made up a stainless steel plate, took the original shaft and pressed it in.
Re-assembled and now is fine
Posted on Nov 15, 2009
tattootech2
  • 72 Answers
SOURCE: will not spin during spin portion of cycles. it
It's either a bad door switch, or motor control board. Definitely easier and cheaper to try changint he door switch first, as it fails much more often. Part number is 131763202
Posted on Apr 07, 2010
My microwave oven works, but the turntable stopped turning. How can I repair this?
turntables are turned by a rubber belt from a small motor
have an appliance service center check it out and get a quote
Dec 24, 2015 | LG Microwave Ovens
The motor is not working in this Halloween accessory On the motor it says AM03
unless you have a transformer feeding it that should be 120 volts a.c it says it draws 3.7 watts running at 3 rpm with a clockwise rotation.
Aug 31, 2015 | Heating & Cooling
Have a small safe with a three number combination. I am not sure how the numbers should be rotated.
Depending on the unit,, Make , Model etc.
It is usually CCW, CW, CCW sometimes 4 rotations to clear
go to first number, then 3 rotations CW to the next number, then 2 rotations CCW to the last number, rotate CW till the tumbler stops,
Then pull the handle to open, if in doubt,
Call a local locksmith who sells or services the unit and ask the
procedure for that model ,
They may be able to set you straight
Aug 22, 2014 | Home Security
Cae2743bq will not turn on all lights on and lid lock is lit up
Try this, worked for me! :)
New WHIRLPOOL Top Load Washer
Model #'s CAE2743BQ, CAE2763BQ
Cycle Selector Knob key dance: [CCW=Counter Clockwise and CW = Clockwise]
Start On "NORMAL"
1 step CCW (Left)
2 steps CW (Right, Right)
1 step CCW (Left)
1 step CW (Right)
Stay on "HEAVY DUTY"
(If unsuccessful LEDs will not flash, and you must return the selector to the Normal Cycle position and
wait 4-5 seconds before retrying. )
If you are successful in the process, all LEDs will be flashing
Toggle between HEAVY DUTY and NORMAL until ONLY the RINSE light is on, then press the
START button for about 30 seconds. Machine will then enter CALIBRATION mode for about 2 - 4
minutes. DO NOT RAISE THE LID
Sep 01, 2013 | Whirlpool Washing Machines
. How do I wire this for forward and reverse use
you can reverse the rotation CCW to CW if you reverse the wiring on the brushes
Jan 09, 2011 | Dayton Universal Ac/Dc Open Motor 1 Hp...
Using way to much oil
This is a Husky 455 Operator's Manual (May 2009)
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2009/HOUS2009_1151382-95.pdf
Page 37 explains the oiler adjustment. CAUTION: is has only 3 positions, forcing it to far CW or CCW will damage your saw. Against the CW stop is the minimum oil position.
You can find the correct manuals here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
HTH
Lou
Jan 11, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Diagnostic complete
Your washer apparently did not complete diagnostics. The display indicates that it stopped at the segment of the test where it was attempting to fill by using the hot water solenoid. The diagnostic test segments check the following:
C:00 - Door Lock
C:01 - Flow Meter, Cold Water Solenoid
C:02 - Dispenser Motor, Dispenser Contacts
C:03 - Hot Water Inlet Valve
C:04 - Motor rotates CW at wash speed
C:05 - Heater & NTC (Heater Sensor)
C:06 - Drain Pump
C:07 - Motor rotates CCW at 35 to 90 rpm within 15 seconds
C:08 - Motor rotates CCW at max. speed.
If there is an error associated with any portion of the diagnostics, the washer will shut down, an audible alarm will be heard, and an error (F) code will be displayed. Sometimes the washer will experience momentray glitches during testing, however. I would recommend unplugging the washer for at least 30 minutes to reset the Central Control Unit (CCU). The is the main "brain" of the washer. Upon reset, attempt diagnostics again and let me know the results. I hope this helps you.
Oct 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Defective rotating grill motor
I have found the manufacturer of the motor in China and have ordered a replacement part.
Thanks,
Canadiano1
Jul 28, 2008 | Kitchen Appliances - Others
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
