Question about Radio Communications
Sonic rider bluetooth pairs but won't make calls
It falls out of pairing and now it will pair with my Blackberry but it won't allow me to make calls by voice command
nokurajesh
  • 101 Answers
SOURCE: I need help with pairing H350 Bluetooth with Blackberry cell
After pairing goto optins and connect with the BTHEADset.
Posted on Aug 09, 2008
zohail
  • 1223 Answers
SOURCE: pairing H710 bluetooth to my Blackberry 8120
it is universal procedure to pair up all devices like this
first if ur hedset is switched on switch it OFF by long pressing the main button in the centre it will blink blue light twice or thrice and will switch OFF after that u can touch any button it will not respond with blinking lights
Now press again that centre main button long press for like 10 sec until that blue light comes on and become STABLE when it is stable it means it is ready to pair up with any bluetooth phone now go to ur phone switch the bluetooth ON and select search u will find ur headset with its model like H710 just select and when asked for pairing code enter 0000 Zero four times or try 8888 if it doesnt work , now u will see that ur headset light will start blinking and u will see a headset sign on the screen of ur mobile phone it means now it is paired up
now u can try to talk thru headset make a test call any number for voulume control there are two buttons on headset on upper sie with arrows u can select them to increase headset sound
pls rate me well for help ! Fixya rating is encouraging !
Posted on May 03, 2009
SOURCE: jabra 2050 wont pair with blackberry storm
hi all any1 can help me plzz?
i bought an Jabra 2050
i connect it at my phone
my phone is sony erycson K850i
i can speack on moboly with it...all are good
but how i can listen music on the Jabra 2050?
Posted on Mar 04, 2010
award462
  • 395 Answers
SOURCE: bluetooth won't pair
Did you try this?
http://www.fixya.com/support/r5009033-put_most_bluetooth_headsets_into_pairing
Posted on Jun 02, 2010
bendarden
  • 984 Answers
SOURCE: Motorola hs850 bluetooth headset won't pair with g five mobile
How to place a Motorola HS 850 bluetooth headset into paring mode:
  1. Close the boom to turn the unit off.
  2. Hold down the call button until the blue light comes on.
  3. While holding down the call button, swing the boom open.
  4. (Now you can let go of the call button.)
The headset is now in pairing mode, and you can search for it using your phone. When it asks for a PIN, use 0000.
Posted on May 14, 2012
Plantronics voyager pro plus is connected and paired with blackberry tour. when a call is coming in, I cannot answer or hang up the phone from the bluetooth headset.
Make sure that your Blackberry's headset mode is activated. If the headset mode is turned on in the Blackberry menu and settings, you may also need to re-pair the headset to your phone to make sure that it has a good connection. Before running through the pairing process, be sure to totally delete the headset from the Blackberry's menu. You may want the headset turned off for this process.
Once you make your Blackberry discoverable, then put the Plantronics Voyager Pro headset into pairing mode by holding the power button until the headset flashes red and blue. Here is the link below for the Voyager Pro pairing instructions.
Plantronics Voyager Pro Pairing Instructions
Good luck from Headsets Direct!
Mar 09, 2011 | Plantronics Voyager PRO Bluetooth Headset
Cannot 'pair' the HPBLU H1 to my Blackberry..? Not 'finding' it... need a users Guide... where can I get one...?
Instructions
Pair Your Blackberry with a Bluetooth Headset
Turn on Bluetooth headset and Blackberry hand-held.
Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.
Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window.
Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list.
Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically.
Use your Bluetooth Headset with your Blackberry
Make sure the Bluetooth radio on your Blackberry is turned on before you try to use your Bluetooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the handheld.
Tips & Warnings
Pair your Blackberry with any Bluetooth-enabled device using the same steps as those for connecting a Bluetooth headset.
Remove your Bluetooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Feb 23, 2011 | Cellular Innovations HFBLUH1 Bluetooth...
I AM NOT ABLE TO PAIR JABRA BT135 WITH MY BLACKBERRY 9700. WHAT SHALL I DO?
Hi,Instructions on how to pair blue tooth device with black berry.
Tips & Warnings
Have a nice day .
Feb 16, 2011 | Jabra BT125 Headset
How do I connect my blackberry cel phone to my bluetooth ce0678
Hi, you can use this instruction to pair your blue tooth with your cell phone:
Instructions
Tips & Warnings
Good luck to you..
Feb 01, 2011 | Cell Phones
My blackberry bold phone does not locate my Plantronics VBH-300 bluetooth headset whilst trying to pair them. It was paired with a previous nokia phone,which I no longer have.
Hi,you will have to delete the previous paired phones first before you can be able to pair the blackberry phone with your blue tooth device.
You can use the below steps to know how to pair properly:
Instructions
Tips & Warnings
Hope it helped.
Thanks for usingf ixya..
Jan 13, 2011 | Plantronics Explorer 320 Wireless Headset
Blackberry 8530 cannot find / pair with bluetooth Samsung stereo headset. Tried putting both into discoverable mode, no help. This headset will pair with my Blackberry 8320 phone, but the music speeds...
1. Turn on Bluetooth headset and Blackberry hand-held.
2. Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.
3. Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window
4. Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list
5. Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically
1. Make sure the Bluetooth radio on your Blackberry is turned on before you try to use your Bluetooth headset 2. Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
3. Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Dec 03, 2010 | Insignia Bluetooth Wireless Headphones...
How do I use the loud speaker on a Blackberry pearl?
Hi there
Although the Blackberry pearl does not come with a speakerphone, you can still set up this function by using a Bluetooth device.
HERE IS WHAT YOU SHOULD DO
Power on your Blackberry using the On/Off button in the lower right-hand corner of the device
Turn on Bluetooth
Find the Bluetooth option. In the main menu, select "device options."
Enable Bluetooth radio. Click on the trackwheel to scroll down until you see the option "Enable Bluetooth". Select this function (click the trackwheel) to turn on Bluetooth compatibility. If you have completed this step correctly, you will now see a "Bluetooth icon" on your Blackberry screen. If you want, you can later turn off Bluetooth by repeating Steps 1 to 3 and then selecting "disable Bluetooth".
Pair your Blackberry with a Bluetooth speakerphone
Power on your Bluetooth speakerphone device using its On/Off switch or button.
Find the Bluetooth option in the main menu by again selecting "device options" and then using the trackwheel to scroll down until you see Bluetooth. Select this by clicking the trackwheel.
Add your Bluetooth device. Click on the trackwheel to scroll down until you see "Add Device." Then click on the trackwheel to select this function.
Enter the name and passkey of your Bluetooth device. When prompted, scroll down with the track wheel until you see the name of your Bluetooth device. Your Blackberry automatically detect your Bluetooth speakerphone if it is within 10 meters. If it does not, enter the name of the device, then type in the passkey provided by the manufacturer of the speakerphone.
Enter the passkey on your Bluetooth speakerphone. Your Blackberry and Bluetooth speakerphone can now communicate with one another.
To use the speaker during a call all you need to do is;
Dial a number and hit the send key. Make sure that your Bluetooth speakerphone is on, and that you have already set your Blackberry to "Enable Bluetooth." If you see the "Bluetooth icon" you have already done this step.
Activate your Bluetooth device. When the call has connected, click on the trackwheel until you see the option "Bluetooth Device". Then click on the trackwheel to activate the Bluetooth function. Your Blackberry will now route your call to the Bluetooth Speakerphone.
Turn on the speakerphone. Depending on which Bluetooth Speakerphone you have purchased, you may need to click on the "speakerphone" button to enable this function. Once the speakerphone is on, you may continue with your phone call.
Sep 19, 2010 | Cell Phones
I have blackberry 8110 and it ask me for a passkey
Blackberry 8110
Bluetooth technology troubleshooting:
Common Problems
I cannot type a passkey on a Bluetooth enabled device
If you cannot type a passkey on a Bluetooth® enabled device, the passkey might already be defined.
On your BlackBerry® device, in the Enter passkey for <device name> field, try typing 0000.
My list of paired Bluetooth enabled devices does not appear
Try performing the following actions:
• Verify that Bluetooth® technology is turned on.
• Verify that you have added Bluetooth enabled devices to the paired Bluetooth enabled devices list.
I cannot pair with a Bluetooth enabled device
• Verify that your BlackBerry® device is compatible with the Bluetooth® enabled device. For more information, see the documentation that came with the Bluetooth enabled device.
• Allow the Bluetooth enabled device to discover your BlackBerry device. In the Bluetooth setup application, click Allow another device to find me.
• Turn off encryption for Bluetooth connections between your BlackBerry device and the Bluetooth enabled device. In the device options, click Bluetooth. Click a Bluetooth enabled device. Click Device Properties. Change the Encryption field to Disabled. Press the Menu key. Click Save.
I cannot share contacts with a paired Bluetooth enabled device
• Verify that your BlackBerry® device is paired with the Bluetooth enabled device.
• Verify that, in the Bluetooth options, the Address Book Transfer field is not set to Disabled.
• Verify that your BlackBerry device is connected to a Bluetooth enabled device that supports the Handsfree profile or the Object Push profile. For more information about supported profiles, see the documentation that came with the Bluetooth enabled device.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thank you.
Feb 01, 2010 | RIM BlackBerry ® 8830 Cellular Phone
Pairing my bluetooth
pair my wireless s9 headphones to my blackberry
Jan 20, 2008 | Plantronics 510SL Headset Voyager...
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
