Question about Garden
Pro Concept lawn mowers
We have a push lawn mower made by "Pro Concept". It is a 135cc and it starts up great, but after about three minutes it shuts itself off. We have put in new spark plugs, so that's not the issue. I need to get manual for this thing, but I can't find who made it.
  • 5 Answers
SOURCE: Poulan 6.75 Lawn mower will not start
trouble shooting tips: oil is too full
fuel jet and float are plugged
spark plug lead wire may be damaged inside and needs to be replaced.
Posted on May 02, 2009
  • 10865 Answers
SOURCE: Its starts but will cut off
The problem you are having is due to dirt and gunk in the carbeurator. Spray a carbeurator cleaner into the air chamber [remove the air filter] and run it a couple of times then let it sit for two hours while the carbeurator cleaner does its job of dissolving any debris. Then start it up. IF this does it, great, if not repeat the cleaning technique.
If all of this doesn't do it, then the carbeurator will have to be removed and either replaced or rebuilt.
Posted on May 06, 2009
  • 69 Answers
SOURCE: My Toro lawn mower starts good, but it only runs
Sounds like you need a carb cleaning. Also install some Seafoam gas additive in your gas tank to clean out the gunk that builds up. Do not use ethanol gas.
Posted on May 18, 2009
  • 88 Answers
SOURCE: no spark from spark plug in honda lawn mower
the pionts could be bad try changing them
Posted on Aug 30, 2009
SOURCE: Our Toro Personal pacer Model 20031 lawn mower will not start;
i turn the key and it grinds
Posted on Dec 06, 2009
Find parts for carburator
Shop for parts for carburetor lawn... on Google
How to Fix a Lawn Mower Carburetor - YouTube ? 12:48
www.youtube.com/watch?v=s2NcBVRMvKs
May 24, 2013 - Uploaded by eReplacementParts.com Get the lawn mower parts you need here: http://www.ereplacementparts.com/ This tutorial will show you how
Sep 16, 2015 | Garden
What causes a Poulon Pro riding mower with a 19.5 HP Briggs to shut down after only running for about 15 minutes?
Will it start rite back up?
Check to see if you have a low oil sensor,
Sometimes the oil sensor wills me it shut off when it's a little low on oil.
May 17, 2015 | Poulan Pro 19.5HP Lawn Tractor 960420123
Help globalpowerbrands com
look up a lawn mower shop they might be abel to match a blade to it not unless you go on line to dealer and mail order it will 3 or4 times regular price and shipping would go to the lawn mower shop and have them to match a blade to the one you have in your hand it will be cheaper alot cheaper
Sep 04, 2014 | Garden
What is wrong with my push mower?
Sounds like something relating to the engine is overheating and the heat sensor switches off the machine.
Jun 18, 2014 | Briggs & Stratton LawnBoy 20Inch 65 HP Gas...
My lawnmower won,t start
Three things I know to check. 1. check for broken kill switch wire or loose connection on same wire. 2. check for loose or corroded wires on switch. 3.If this unit has a stator and mag polish the surfaces of both and check clearances.
Jun 21, 2012 | Tecumseh Lawn Boy Push Mowers Insight...
Huskee 16 hp Tecumseh starts and runs great but
When it shuts down check it for spark. You sound like you may have a weak coil. OR
You might have water in your fuel and it only runs until it hits the water level in the carb. You can try draining your carb *(do this when mower is cold...never drain gas from a hot mower!) and see if the mower runs longer. While you are draining your fuel you can check the float level too. A float that closes too early or that is partially obstructed might only let in enough fuel to run for short periods. Then, your three minutes of sitting is just to let the carb bowl refill. When you remove the carb bowl let the float hang down and note the fuel flow. Is it fast? Or is it just a slow drip? If it seems slow you should work the float up and down a few times to see if the flow improves. If it does improve consider draining all the fuel out and cleaning the gas tank.
Good luck and be careful!
Jul 16, 2010 | Garden
Was cutting grassstopped for maybe three minuts then tried to start mower but it wouldnt . Refueld and a new plug got nothing but tired of pulling any suggestions
check for spark...if the mower runs for three minutes it might be failing because it looses spark as soon as the ignition module heats up.
If your mower cuts out and the spark check indicate no spark then you know you need a new module. While you are changing the module you can check for animal nesting in the cooling fins under the motor cover.
Its usually how lawn mower ignitions get baked in the first place. You cant see it from the outside....so you cant fault yourself for missing it.
good luck and be careful!
Jun 26, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
Where is the fuel filter on a Yardmachine Mod.#11A-41MY229? The mower has only about 36 hrs on it. It seems that its not getting enought fuel. could the carbon cannister have something to do with not...
There is no fuel filter, maybe a screen in the tank. Running good for 20 minutes then shuts down sounds like a coil getting hot then not sparking. Next time it quits check for spark.
Mar 14, 2010 | Yard Machines 158cc Push Lawn Mower #11a...
Weedeater lawn mower shuts off, but still has 3/4 tank of gas
On some mowers...if the gas cap vent is not working properly, it will run fine for about 15 or 20 minutes, start spitting and sputtering, if you loosen the cap, and let air back into the tank it starts running normally again.
Apr 05, 2009 | Garden
Garden Logo
311 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
