Question about SprayTECH Ep2205 Airless Paint Sprayer
How can I operate this machine a Spray TECH Ep2205
How to clear the usage counter?
From Samsung site:
1. Press MENU # 1 9 3 4 in sequence rapidly. The LCD panel should now display TECH.
2. Press MENU, and then press ENTER. The LCD panel will display Tech Mode.
3. Press the left arrow (<) button once. The operator panel will display NEW CARTRIDGE.
4. Press ENTER. The operator panel will display [YES].
5. Press ENTER. The toner warning message should be gone.
6. To exit TECH MODE, press MENU # 1 9 3 4 in rapid succession, as if you were dialing a phone number. The operator panel should no longer display TECH.
Oct 18, 2014 | Samsung 5pk - Scx-4521 Scx-4321 Scx-4521d3...
Rug doctor will not spray what should I do?
check your spray pump is working a little pump inside machine is operating .check switch is working as well
Sep 02, 2014 | Rug Doctor Mighty Pro X-3 Ready Pack...
How do I set the coffee dose?
Too detailed for direct answer. Get operator's manual for dose instructions. Some machines may require programing key (service tech only)
Sorry for this answer as the dosing control is in-bedded with all dosing variances which is considerable. Though with practice it's possible to set it. Have you service tech walk you though the 'operator' or 'customer' programing steps.
Dec 30, 2013 | Espresso RMI La Cimbali Espresso Machine
Water not circulating in dishawasher
I have this same dishwasher, bought it May 31, 2011 and the water won't spray. I called Samsung, and they oh so nicely said they would send a tech to take a look at it. I asked for free....lady says yes. Tech gets here and say it's a $69.00 fee just to run the onboard diagnosis.
Mar 30, 2013 | Samsung DMT800RHS Dishwasher
New replacement pump on Bissell ProHeat Protech not working
Not sure if I have the same model but this is what I found on mine this morning - wire to switch in the handle came off. Un-plug power cord. Unscrew top two screws on upright handle and remove the front cover above the trigger. see if wires are connected. top connector is not used - if you do solution will spray all the time. Good luck!
Jul 09, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Horizontal/vertical hold is off, picture is moving fom left to right Mitsubishi big screen vs-60607
You better take this fellow to a doctor. You have a stamp size IC with about 250 pins that is bad. Only a tech can replace this or reinstall a remanufactured board into this TV. You may ask the tech to use a freeze spray to find this IC first and then he wil decide how to operate!l
Jan 24, 2010 | Mitsubishi VS-60607 TV
Kenmore HE5 error code F28 on spin cycle
F28 is a serial bus error from the CCU (Central Control Unit) to the MCU (Motor Control Unit).
All you need is some Electronics contact cleaner spray and a 1/4 inch socket to remove the top of the machine and the back of the machine.
The CCU is the computer looking box at the top front right hand corner.
Find connector M13, (has red marking on it and only 3 wires) disconnect it by pushing the retainer tab back and pulling gently on the connector.
Spray the contacts of the connector and computer with connector cleaner.
Then re-assemble connector.
The MCU is in the back lower left corner.
Find the connector with 3 wires and red mark, and remove this connector in the same way you did the other, spray it and re-install.
Put the back and top back on.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 25, 2009 | Kenmore Elite 45986 Front Load Washer
GE PDW7800J15BB Dishwasher, Spray arm removal
Dear friend,
ngfam at you service! happy to assist!
this takes experience and tech knowledge!
You have atop of the line dishwasher and its not easy to repair this hi-tech GE Profile machine, better left to the service tech.
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 26, 2008 | GE 24 in. Profile PDW7800 Built-in...
Jet spray nozzle not spraying water.
If no water is coming out at all, it might be that the inlet filter is clogged or the Est. time shows the code IE. To clean out the inlet filters, unplug the washer, turn off the water, open the valves, take a filter cap thing and try rinsing it out. To put it back to operational use, reverse the steps above.
Mar 26, 2008 | LG WM2688HWM TROMM SteamWasher
Bernette 75 only backwards
check the motor it is deffected the brushes neeeds to be change.call a tech.good luck
May 02, 2007 | Bernina Bernette 75
SprayTECH Ep2205 Airless Paint Sprayer Logo
29 people viewed this question
Top SprayTECH Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a SprayTECH Air Tool and Compressor Expert? Answer questions, earn points and help others
