Question about Dryers
Samsung dv431ag dryer preset sensors not working
The Manual Time Cycle on the gas dryer works fine. The preset cycles such as Towels, Normal, Sanitize, turn off within 5 minutes. I think the sensor might not be working. How do I figure out what the problem is and how to fix it? It isn't the lint trap. I clean that every time.
catriver
  • 878 Answers
SOURCE: Whirlpool GEW9200LQ0 Gas Dryer
Andeb, 90% of the time long dry times are caused by blocked vents. If you are sure that this is not the case there are a couple of things to check. First check the sensor; press the more time button and less time button 4 times until 88 shows in the display.(more time,less time, more time, less time). Open the door and you will hear a beep and a see a code. On the inside just below the vent screen is the moisture sensor. Moisten your finger and lay it across the sensor strips covering both. If you hear a beep, the sensor is good. Sometimes they build up with fabric softner and need to be sanded lightly. Another issue might be the burner coils. Remove the bottom panel and check to see that the burner is igniting and remaining lit. Sometimes these coils become week and will not sustain the flame. I will attach a diagram, look at number 13 and 14 on the picture. These are the coils. Catriver..post back.
Posted on Sep 18, 2006
  • 148 Answers
SOURCE: I have a Kenmore 110.74812200
its the flame sensor,or the coils on your gas valve
Posted on Jul 08, 2008
  • 5 Answers
SOURCE: Samsung dryer DV218AEW stuck on cool down cycle
pcb damaged
Posted on Sep 12, 2009
heatman101
  • 43501 Answers
SOURCE: My Kenmore Elite Dryer (Model
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There a few other things that can shut it off also...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
TheMobilian
  • 8220 Answers
SOURCE: RES7648KQ0 Roper dryer takes for
See that white skinny component by the blower? That is the thermal fuse
Below it is the control T-stat. Now when that filter housing is clogged
The temps rise considerably faster. This control turns the heating element on and off during the drying session. So if you have this:
The autodry feature is not gonna work so good. Why?
See that orange wire attached to the high limit thermostat?
That feeds power to the timer motor if the heater element is not on.
Bad control thermostat AND/OR air restrictions are the Autodry type dryer's worst enemy.
Try first cleaning the dryer and see if that makes a difference.
If it still has problems then change out the control thermostat.
Videos and service manual is HERE
Posted on Aug 10, 2011
I have Samsung gas dryer model DV410. no heat, replaced two thermal fuse and hi low limit. Now it only works with timed cycle mode. the rest mode, it runs only for least the 5 minutes and shut off.
timed cycle mean dryer not on sensor dry mode. check wire connection on moisture sensor bars (i think you forget to put 2 wire connector put together). when you use other cycle dryer use moisture sensor to dry cloths so sensor not working dryer will stop in 5 minutes or so because dryer think there are no wet cloths to dry. hope this help you.
May 02, 2017 | Samsung Dryers
Samsung frontload gas dryer DV218AG moisture sensor doesn't work properly. Dryer adds minutes to drying cycle even when cloths are completely dry.
Clean the sensors with windex or like cleaner. Farbic soften can build up on the sensors and cause you trouble, Also, the time displayed is an estimate not actual drying time.
Jan 26, 2014 | Samsung Dryers
Whirlpool GGW9250PW Automatic Cycle not working
We are sorry to hear of the problem with your Whirlpool dryer. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Reviews@Whirlpool.com with your name, phone number, address and the model and serial number for your refrigerator.
Apr 04, 2017 | Whirlpool GGW9250PL Gas Dryer
It takes far too long to dry towels.
The igniter is supposed to go on and off during the cycle. There is a sensor that could be replaced, but is rarely the problem in this instance. 99% of the time when the dryer is taking too long to dry, it is an air restriction. Usually lint is plugged up somewhere, or the vent run is too long.
Mar 13, 2009 | LG DLG5988 Gas Dryer
DRYER RACK DOES NOT DRY CLOTHES
try timed dry cycle instead of the auto-sensing setting. In your drum if you have auto dry such as less dry normal dry and more dry, There is a sensor sometimes in the drum and sometimes in the exhaust right after the blower. If in the drum then your clothes brush by this and if moisture is sensed then it keeps on drying. With your rack the clothes can't touch the sensor so it tells your dial to turn and that items are dry which in fact are not. Try this and see how it does.
Feb 17, 2009 | Samsung 7.3 Cu. Ft. 9-Cycle Electric Dryer...
Samsung Electric Dryer
This may be a problem with your moisture sensor or the control that read the sensor. If it is under warranty have Samsung fix it for free. Make sure the cycle settings are correct before tinkering. First make sure the electronics are not too dusty. You could blow them off or vacuum them. Dirt particles can conduct electricity and make it read wrong. Next check the electrical connection for the moisture sensor. See if its location is in the manual. If it doesn't work after some tinkering asked the service for the dryer about possibly replacing the sensor but first try hard to get it to work.
Jun 13, 2008 | Samsung 7.3 Cu. Ft. 9-Cycle Electric Dryer...
LG DLG2532 Gas Dryer will only dry on manual setting
If you use dryer sheets, LG recommends no.  Dryer sheets cause a film that will not allow the sensors to feel the clothes moisture during the drying process thereby causing the computer to countdown the timer quickly.  To clean out the sensors, use a green pad and scrub the sensor bars inside the dryer drum.  That should remove the film left by the dryer sheets.
Mar 12, 2008 | LG DLG2532 Gas Dryer
Dryers Logo
32 people viewed this question
Top Dryers Experts
