Question about Black & Decker Black Decker NPP2018B 18 Volt Cordless Pole Chain Saw Bare Tool (No Bat
How to tighten chain on black and decker cordless pole saw
  • 25 Answers
SOURCE: Hello! I have a Black
You need to know the size pitch and brand of the chain. See if it has a name on it anywhere. It may have a pitch # stamped on the side. My remington uses a Oregon chain.
Check the chains at walmart and see if they look the same. You may find a cross ref on the package that will give you another part#
Another option is to replace the bar and chain with a new Oregon Replacement Bar & Chain Combo kit.
See this site for examples.
try this cross ref chart
Posted on Jan 14, 2009
dontbother10
  • 2220 Answers
SOURCE: how do you get the safety lock off the chain saw
No repy to clarification.
Posted on Feb 18, 2010
dontbother10
  • 2220 Answers
SOURCE: lost maintainance instructions for NNP 2018 pole
It sounds as though you have bent drive links? I would probably replace the chain. Burrs we can help, see Chain Repair here:
http://www.fixya.com/support/r4146814-chainsaw_chain_installation
The instruction sheet is available here:
Black & Decker
Go To “ServiceNet/” link
Bottom of center column “Need a Manual?” Enter model number, “YourModel” in window.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 02, 2010
jyackle5
  • 8197 Answers
SOURCE: We require a manual for
You can get the manual on the link below.
http://servicenet.blackanddecker.com/documents/English/Instruction%20Manual/90560838,CCS818.pdf
Posted on Apr 20, 2011
wentlanv
  • 710 Answers
SOURCE: I have a B &
The chain is part #623382 00 and can be purchased at toolpartsdirect.com for one place. I like this place as they ship quickly and aren't overpriced.
Use a 5/32" sized-file to sharpen the chain at 30°.
The correct size chain is a 3/8" pitch, gauge 0.043.
The brand Oregon offers these chains also. You might find one at your local outdoor equipment place or chainsaw place.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Posted on Jun 05, 2011
Black & Decker Cordless Pole SawNPP2018 Chain
hi
no much that we can help you now
it look's like you need a new motor and trigger switch
or may be more cheaper to buy a new one try a different make or model this time
Oct 24, 2013 | Black & Decker Garden
How do I put the saw on the pole
1. Remove battery from chain saw.
2. Separate main handle from chain saw
power head by pressing both release
buttons on main handle and pulling
apart. The release buttons are just in
front of the trigger.
3. Align rib on chain saw power head with
groove in power head adapter on pole.
4. Slide power head into power head
adapter until units "snap" together.
IMPORTANT: Both release
buttons on power head adapter must be
fully engaged.
5. Align rib on handle adapter on pole
with groove in main handle.
6. Slide main handle into handle adapter
IMPORTANT: Both release buttons
on main handle must be fully
engaged.
7. Slide battery onto main handle until
release buttons "snap" together.
Be sure the battery is charged.
To extend the pole:
1. Loosen the clamping
lever. Pole will slide
freely.
2. Pull inner pole section out to desired
length of extension.
3. To lock pole in position, tighten clamping
lever.
Sep 12, 2011 | Remington Cordless 18-Volt 8-Inch Cordless...
I do not have a manual.... I can't adjust the tension. It looks like I have too much chain, the screw is as tight as I can get it. Help!! I have a Cordless Chain Saw, model CCS818 TYPE 1.
the bar should also raise and lower when you apply tension onto the blade - one way or the other it shoudl allow you to tighten the blade.,.. If it is still loose after that, you may be more safe to grab a new blade if this is from wear or use.
Also another fyi: If you get these blades hot and too tight, when they cool, they can warp your bar... I always loosen the chain on mine (per owners manual) immediately after use so it will not do any damage when it cools down..
Did you try to find an owners manual at black and decker dot com?
Best regards
Ck
Mar 08, 2011 | Black & Decker CCS818 Chain Saw
WHERE CAN I BUY THE CRIMP BULLET PLUGS ON THE EXTENSION POLE 622891-00
Try Go to this LINK and find the part/diagram that can help you.
Please thumbs back if help is fine,thanks!
Nov 03, 2010 | Black & Decker NPP2018 18 Volt Cordless...
Lost maintainance instructions for NNP 2018 pole pruning saw Chain jammed some teeth are out of line
Black & Decker
Lou
Mar 02, 2010 | Black & Decker NPP2018 18 Volt Cordless...
Hello! I have a Black & Decker Cordless 18 V Pole saw and I need a replacement chain. In the Instruction manual it's listed as: Replacement chain # 62338200 I can't find it in any site.
Jan 14, 2009 | Black & Decker 18 - Volt Pole Pruning Saw
Black & Decker Black  Decker NPP2018B 18 Volt Cordless Pole Chain Saw  Bare Tool (No Bat Logo
16 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
