Question about Crock Pots & Slow Cookers
Ultrex 8qt pressure cooker model 42018 manual
SOURCE: Ultrex Slow Cooker
Anwser NO! My Roasting pan craked at 4OO degrees cooking a Chicken!
Posted on Dec 13, 2007
SOURCE: I can't open my new Ultrex 2 Pressure cooker model 11302
It's almost certainly due to atmospheric pressure. Warm it slightly and it will open.
I had the same problem with an underwater dive torch. Left Johannesburg (1000 metres above sea level) and went to Mauritius (10 metres above sea level) and I couldn't open torch!
Posted on Apr 20, 2008
  • 5 Answers
SOURCE: ultrex pressure cooker model innova 14240
Pressure cookers are only slightly more complicated than crock pots. In fact, you can think of them as the opposite of Crock pots. Where a crock pot needs 2-3 times as long to cook something, the pressure cooker needs only 1/2 to 1/3 of the time.
These are not that complicated and haven't changed in the last 50 years. The only real hard part is being sure is doesn't explode; not that hard: don't cook things that would foam, like pasta or potatoes. Just read some recipes on the internet or get a recipe book at a bookstore, used book store (super-cheap)or the library. My best advice is to make sure you use the lowest possible heat that still allows steam to escape at a whisper. That will keep things from burning (or scorching) on the bottom, which can give a harsh taste and make clean-up more work. Just do it.
Posted on Feb 21, 2009
SOURCE: i HAVE AN ULTREX 8QT. SLOW COOKER 9QT, ROASTER.
Innova, Inc.
P 800-767-5160
F 913-541-8561
info@innova-inc.com
Ultrex Slowster 8 qt slow cooker 9 qt roaster Model 08393
Posted on Mar 28, 2009
SOURCE: ultrex pressure cooker manual
where do i get a tower pressure cooker manual from?
Posted on Nov 01, 2009
Has the ULtrex II been recalled or is it dangerous?
Yes it would appear it has! However, it doesn't mention the II
HSN LP Recalls Ultrex-Brand Pressure Cookers Due to Burn Hazard ...
https://www.cpsc.gov/Recalls/.../hsn-lp-recalls-ultrex-brand-pressure-cookers-due-to-b...
Nov 30, 2006 - HSN LP Recalls Ultrex-Brand Pressure Cookers Due to Burn Hazard. The following product safety recall was voluntarily conducted by the firm in cooperation with the CPSC. Consumers should stop using recalled products immediately unless otherwise instructed. It is ******* to resell or attempt to resell a ...
CPSC, HSN LP and Innova, Inc. Announce Expansion of the Recall of ...
https://www.cpsc.gov/Recalls/.../cpsc-hsn-lp-and-innova-inc-announce-expansion-of-t... Oct 16, 2003 - The following product safety recall was conducted voluntarily by the firm in cooperation with the CPSC. Consumers should stop using the product immediately unless otherwise instructed. It is ******* to resell or attempt to resell a recalled consumer product. Name of Product: Ultrex Thermal/Double Wall ...
Recall: Ultrex-brand Pressure Cookers - WeMakeItSafer
wemakeitsafer.com > ... > Kitchen & Dining > Cookers, Steamers & Fryers Nov 30, 2006 - This was the 2nd recall of products in the Cookers, Steamers & Fryers category in 2006. Since 2005, there have been approximately 20 similar recalls, involving about 2 million product units. Check My Pressure Cooker ' See Other Recalled Cookers, Steamers & Fryers. Ultrex-brand Pressure Cookers.
Info on Recalled Ultrex brand Pressure Cookers
Mar 11, 2018 | Ultrex Crock Pots & Slow Cookers
I have an electric ultrex pressure cooker. What temperature should I set it to cook a 4.25 pounds corned beef
It goes by minutes under steam pressure. You likely will need about 1 hours in the pressure cooker to make it tender.
Mar 16, 2017 | Ultrex Crock Pots & Slow Cookers
I need control cord for ultrex electric pressure cooker
Check with an appliance parts stroe or on the internet.
Jan 12, 2015 | Ultrex Crock Pots & Slow Cookers
Where can i find a manual for ultrex pressure cooker?
The company had a major recall and went out of business. No manuals appear to be available on the web.
Here are some general instructions you can use:
1 Set up your cooker. Place your Ultrex Pressure Cooker on the stove. Remove the lid and pour in no more than 2 inches of water. Depending on what you are cooking the amount of water will vary. More water will ultimately cook larger amounts of food, but you will need to refer to your specific model's instructions on this matter.
  • 2 Put in the food you wish to cook. Close and lock the lid firm to the pot. Make sure it is locked securely so none of contents boil out of the top.
  • 3 Turn on your burner to high heat for approximately ten minutes. Allow the water to boil.
  • 4 Turn the stove down to a low setting after the water is boiling in the cooker. Flip the pressure valve closed and allow your food to simmer.
  • Set the pressure valve to ten pounds. For vegetables, cook 30 to 45 minutes. For meats, cook 45 to 60 minutes.5
  • 6 Open the pressure valve and allow the pressure to discharge. Unlock and remove the lid to find your fully cooked meal.
  • Aug 25, 2014 | Ultrex Crock Pots & Slow Cookers
    The recalled 8 qt ultrex ll pressure cooker model # 11302c will the lid come off on its own or does it just not lock while under pressure?
    Halt, do not use this pressure cook. The lid is suspose to lock. This means the lid become a dangerous fly object if it came off under pressure, plus extremely hot boiling water and the contents of the pressure cooker. Beside possible dying from the lid, and if one survives the flying lid, one will be will scalded by the contents of the pressure cooker. Another pressure cooker manufactured in China. Sorry, GB...stewbison
    Sep 12, 2011 | Ultrex 2-in-1 (9qt) 8-Quart
    8qt.slow cooker/9qt.roaster problem
    electrical shops sell them like comet or many places online like ebay ect
    Oct 01, 2009 | Ultrex 2-in-1 (9qt) 8-Quart
    Bought a new Ultrex II 6-quart non-stick pressure cooker
    I found numerous recipes on 'About.com' Type in the receipe that you are wanting and add pressure cooker to the search. I have also found recipes on other search engines.
    Dec 19, 2008 | Ultrex 2-in-1 (9qt) 8-Quart
    Ultrex pressure cooker manual
    Apr 21, 2008 | Crock Pots & Slow Cookers
    Crock Pots & Slow Cookers Logo
    Top Crock Pots & Slow Cookers Experts
    tsalagi152
    charles
    Irene Tulloch
    Are you a Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
