Question about Garden
Wright stander wont move
Blades still turn but just stopped moving forward or reverse
SOURCE: Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
Posted on May 15, 2009
  • 3 Answers
SOURCE: john deere x340 wont move
there is a release usually behind the seat that has to be pulled in order to push it physically. make sure that the release is pushed in for the forward/reverse to work.
Posted on May 26, 2009
wadembly
  • 513 Answers
SOURCE: Craftsman LT 1000 won't go into reverse or forward
the hydrostat rearend or the belts to loose
Posted on Jun 07, 2009
  • 396 Answers
SOURCE: wont move forward or reverse-- transmission??
Does it have gears or a hydrostatic (automatic) transmission?
If it's a gear model, sounds like a loose drive belt.
If it's hydrostatic, it could be a belt problem or a problem inside the transmission. If it's a tranmission problem, this is not good. Many of the transmissions on riding lawn mowers are not serviceable - they are just replaced.
Posted on Oct 10, 2009
nova2nv
  • 197 Answers
SOURCE: my ariens 824 wont go forward or reverse
I would check your traction drive disc for wear or shredding.With low or little fuel in tank you can safely grab handle bars and lift machine up on it's auger housing.Then remove shield from under machine and inspect metal disc with rubber around it.If rubber looks worn you can get a replacement traction drive disc easily from most small engine repair shop's or go online and look for your nearest Ariens dealer.
Posted on Nov 18, 2009
Blades stopped turning while moving forward Will turn when holding rio button in & moving in reverse
Greetings, I read your question and I think Reliable-Store can help you in this. Here's the site link.
Best Manuals
Apr 20, 2016 | John Deere Riding Lawn Mower. D170 54 in....
Zero turn will not move forward reverse or turn
These units use Hydraulic pumps for motivation. If the unit stopped all at one time, I suspect a drive belt came off.
For both pumps to fail at the same time would be very odd. Check the v-belt driving the wheel pumps.
Apr 12, 2015 | Husqvarna Zero Turn Mower RZ4619
My shredder will not work. It makes sounds both forward and reverse, but the blades don't; turn. There's no jam signal. Help!!
Most likely one of the gears popped off or cracked. The blades are gear driven by a motor and it's pretty straight forward. If the blades aren't moving, then it's probably a gear problem since you said the motor runs.
Not much you can do without taking it apart.
Good luck. =)
Mar 10, 2015 | Shredder Office Equipment & Supplies
Craftsman LT2000 Does not move (wheels do not move). blade engages and works finr
I would lower the deck to the lowes setting and look between the frame and the deck toward rear wheels and check the drive belt it sounds like it is slipping or busted.
May 19, 2014 | Craftsman Garden
Blade engagement
PTO issue the blade should engage even if your not moving
Jun 21, 2013 | Cub Cadet 50 in. 23 HP Kawasaki Twin...
Troy-bilt riding mower won't move in forward or reverse
I had a similar problem with my TroyBilt 50 inch zero turn mower. Was cutting grass when it stopped going either forward or backward even though it would start and the PTO would move the cutting blades. Turned out the tensioner spring for the belt that drives the motors near the rear wheels had gone missing. Searched the yard where I had cut and moved the machine but couldn't find it. A new one cost me about $7.50. Put the new one on and it worked fine.
Apr 19, 2013 | Troy Bilt 175HP Manual 42" Riding Mower
When backing up the mower blades shut down and won't come back on when I try to go forward again.
on most riding lawn tractors you most first disengage the blades before going into reverse moving the tractor stop, put the tractor in a forward gear then re-engage the blades. if this dose not help please contact me. Thank you
Jul 06, 2011 | Garden
Cub cadet starts but won't move forward or reverse ? what should i try to do?
What model? I have a 1554, that I just took to the dealer, for repairs, for the same thing. The motor starts, the blades engage and cut, it just stopped moving forward, or reverse. If I remember, I'll get back on here and let you know, unless you already know?
Apr 12, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
177 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
