Question about Microwave Ovens
JVM1440WA I do not believe I have power to the lights underneath the microwave
I checked power at the first clip going to the actual light sockets and did not have it checked the second clip that is inside the unit and had it could one of the clips be out?
  • 35 Answers
SOURCE: GE SpaceMaker JVM XL1800
Sounds like the ERC board failed. It maybe covered under warranty, check that first cause a new ERC could cost around $150-$200. Anything electric can cause the .."what the*^&% just happened syndrome.
Posted on Dec 09, 2007
reg501
  • 413 Answers
SOURCE: Microwave Arcing
The metal shelf that comes with most microwave ovens must NEVER come in contact with any surface of the cavity wall or arcing will occur. (this is why its is mounted on plastic clips). IF you are not using the shelf to cook multiple items (as most people don't)....Remove the shelf and store somewhere else until needed.
Posted on Jun 07, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Kenmore Microwave Model 721.67601790 lights don't work!
This seems to be happening to this model a lot!
We see (and repair) this a lot. The problem is on the control panel, whichwe regularly repair nationwide by mail for $39.95 postpaid in about a week.
Atour site, we have a video available showing how to remove a typicalover the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filamentshorts, or when the bulbs are removed or installed without firstunplugging the oven from the power line. Either can cause such afailure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Nov 21, 2008
  • 52 Answers
SOURCE: panasonic microwave no power or light
I must have suggested this 20 time today. if you open the casing you will find several fusees that the manufacturers don't want you to know about.
you have a 10 ampish large fuse that protects the power circuits ( transformer/magnatrons) smaller fuses for control circuits also might want to look atand reset the thermal cutouts. if it overheatedprior to failure
Posted on Feb 21, 2009
praky16
  • 744 Answers
SOURCE: The microwave oven does not have power to the panel.
HI, this will require the skilled hands of a qualified GE tech. the damaged part here is the Magnetron assembly. this is a very sensitive part that creates radiation and the heating process as well. you will need to replace this device asap if possible.
Posted on Jul 02, 2009
JVM1340WW 003 heard pop now bottom lights do not work.
MAKE this test and fix it. God bless you
  1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
Nov 01, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
The light has gone out.
make this test and fix it. God bless you
Oct 31, 2013 | Whirlpool Microwave Ovens
Interior light bulb burned out
make this test and fix it. GOD BLESS YOU
Oct 31, 2013 | Samsung SMH8165STE Microwave Oven
Microwave heats, but the turntable and lights don't work
see the chart for light 1)
  • Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  • Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction
  • 2) the carousel inside your microwave won't turn when you run it, the small motor that operates it may be broken.
    God bless you
    Sep 30, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
    The lights wont come on
    test this and fix it. God bless you
    Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#6#ixzz2aavxew74
    Jul 30, 2013 | Microwave Ovens
    Light bulb
    follow this steps and fix it. God bless you
  • Jul 29, 2013 | GE JES1384SF Microwave Oven
    Whirlpool oven g2p 62f ss
    see the diagram attached, and fix it. God bless you
    Jul 08, 2013 | Neff Microwave Ovens
    Light bracket in over the stove ge microwave XL
    You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
    Dec 06, 2008 | GE JVM1630 Microwave Oven
    BROKEN GLASS COVER UNDER NIGHT LIGHT
    SAME PROBLEM FOR ME...I REMOVED THE BOTTOM COVER AND FOUND THAT ONE LIGHT WAS NOT FIXED AND WAS LOOSE AND WAS TOUCHING THE GLASS. THIS HEAT WAS WHAT BROKE THE GLASS COVER. CLOSED INSPECTION SHOWED THE LIGHT SOCKET WAS TOO LARGE FOR THE CLIPS AND WERE NOT SECURED WHEN PURCHASED. I GOT SMALL SCREW AND NUT, BENT CLIPS SO THE SOCKET HOLE MATCHED THE HOLE MADE BY THE CLIP AND SECURELY ATTACHED THE SOCKET. THIS WILL SECURE THE LIGHT AND KEEP IT FROM TOUCHING THE GLASS..........IF I CAN EVER FIND A GLASS REPLACEMENT....MAY JUST HAVE ONE CUT. NOW THE PROBLEM IS TO REPLACE THE LIGHT AND MICROWAVE FUSE WHICH WAS BLOWN WHEN THE GLASS BROKE.
    May 21, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
    Bulb replacement
    WAIT!!! Before you just take the lamp cover off and try to replace the bulb that way, which would MAKE SENSE!!!, stop! All you'll do is snap the bulb off, leaving the metal screwy end of the bulb in the socket. Believe me - it happened to me. Twice.
    The only way to ensure that you'll be able to get the entire bulb out, because the only way you can actually SEE what you're doing, is to remove the bottom cover of the microwave. It's about 6 screws along the underneath surface of the unit. After removing the screws, the front of the cover will hang down and the rear will stay nested in a groove at the back. At this point, you'll be able to see the backs of the light sockets. Remove the two screws on either side of the sockets, and you can gently pull the bulbs out of the housing so you can actually see and work with them.
    Chances are, the bulbs have been GLUED into the sockets with silicone, which GE says it does to prevent moisture from getting into the sockets. Right. Then why is it that the replacement lamps work just fine without being glued in?! Anyway - GE actually instructs in the manual to "run a knife around the edge of the socket" to break the silicone seal. Hmmm..Sounds safe to me.
    So, after you've eliminated the silicone one way or another, just gently unscrew the lamp like you would any other.
    Trust me - you do not want to try to remove the lamps without removing the bottom cover. Oh, yeah - most importantly, unplug the microwave first! Good luck.
    Jan 04, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
    Microwave Ovens Logo
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
